I am trying to install and configure Nextcloud-AIO on my server, behind a Caddy reverse proxy. I already have Caddy, using the caddy-docker-proxy plugin—I’d link that plugin here, but I’m running afoul of the max number of allowed links—running in a separate container for my domain, and it correctly directs traffic to other subdomains; for instance, recipes.xanderwhart.us.
I can get the Nextcloud-AIO container up and running, but in its configuration flow, it asks for the domain that the instance will use. When I enter and submit “cloud.xanderwhart.us”, I get the following message in the UI:
Domain does not point to this server or the reverse proxy is not configured correctly.
My logs for nextcloud-aio-mastercontainer also contain error messages, corresponding with the times when I click “submit domain”, which I have pasted below in section 2.
Because of this TLS issue, I am posting for help here, because this appears to be, at least in part, a TLS/proxying issue.
Many of the guides I’ve seen for installing Nextcloud-AIO behind Caddy suggest running an instance of Caddy within the same container; however, because I have other hosted services that I wish to proxy, I don’t believe this would work. My standalone Caddy container is listening on 80 and 443 already.
All that said, I am way out of my depth here, and what I want most is for it to work:
- Nextcloud-AIO properly installs at
cloud.xanderwhart.us - Other services (at
xanderwhart.usand subdomains) can be accessed correctly as well
From nextcloud-aio-mastercontainer logs:
nextcloud-aio-mastercontainer | NOTICE: PHP message: The response of the connection attempt to "https://cloud.xanderwhart.us:443" was:
nextcloud-aio-mastercontainer | NOTICE: PHP message: Expected was: 49401199e9d5ff73c176ba30245b59673e46bae182b49e60
nextcloud-aio-mastercontainer | NOTICE: PHP message: The error message was: TLS connect error: error:0A000438:SSL routines::tlsv1 alert internal error
The Docker log for the Caddy container can be found here, since it is a very long log file and I want to preserve people’s scroll wheels in this thread.
Installed from image lucaslorentz/caddy-docker-proxy:2.8.4-alpine
- Operating system: OpenMediaVault 7.4.16-1 (Sandworm), which is based on Debian 12 (Bookworm)
- Architecture: x86_64
- Docker version: 27.4.0
Running Caddy via Docker Compose; see below
image: lucaslorentz/caddy-docker-proxy:2.8.4-alpine
- "443:443/udp"
- CADDY_INGRESS_NETWORKS=caddy
- caddy
- nextcloud-aio
#- ./site:/srv
- caddy_data:/data
- caddy_config:/config
external: true
nextcloud-aio:
external: true
caddy_data:
caddy_config:
Caddyfile:
https://cloud.xanderwhart.us:443 {
reverse_proxy nextcloud-aio-apache:11000 {
tls_insecure_skip_verify
e. Nextcloud-AIO compose file:
# https://github.com/nextcloud/all-in-one
# For custom configuration consult -> https://github.com/nextcloud/all-in-one/blob/main/compose.yaml
nextcloud-aio-mastercontainer:
image: nextcloud/all-in-one:latest
init: true
restart: always
container_name: nextcloud-aio-mastercontainer
- nextcloud_aio_mastercontainer:/mnt/docker-aio-config
# - APACHE_ADDITIONAL_NETWORK=caddy
- APACHE_PORT=11000
- APACHE_IP_BINDING=0.0.0.0
- NEXTCLOUD_DATADIR=/akhet/system/appdata/nextcloud_data
- caddy
external: true
# https://wiki.omv-extras.org/doku.php?id=omv7:docker_in_omv
- Nextcloud-AIO installation instructions for installing behind a reverse proxy
- My post on the Nextcloud forums regarding this
I would provide one more (a link to the OpenMediaVault community wiki page with instructions for installing and setting up Docker and Nextcloud-AIO), but I have reached the limit of links I can add
Thank you for all the help you can provide.
Edit history
- Corrected accidental port in Caddyfile (was 5050, is now 443)
