Hi,
I’m having trouble connecting to websockets on iOS to a server running caddy while “plain https” works just fine. After spending some time debugging it, it seems to be due to a TLS cipher mismatch that happens only with websockets. More details below.
Fedora 35
# As root
cd /etc/caddy
the problem is the same when using a systemd service (i use both depending if i’m actively trying to debug or not)
N/A
weechat.partou.se {
reverse_proxy /weechat localhost:8001
I have trouble starting a websocket connection between my caddy server and my iOS device, both using Lith (a native weechat relay client) or using Safari and Glowing bear (a browser weechat relay client) due to a cipher mismatch.
The websocket endpoint is https://weechat.partou.se/weechat
Nevertheless, by doing a “plain HTTP” request with Safari on https://weechat.partou.se/ the TLS negotiation works without problem.
On the server side:
2022/02/22 06:22:12.808 DEBUG http.stdlib http: TLS handshake error from 94.109.184.121:28624: tls: no cipher suite supported by both client and server
On the client side:
Conection failed: SSLHandshake failed: -9824
Activating all ciphers on the caddy side
I tried to activate all the cipher suites that i could find in the documentation but it did not help
weechat.partou.se {
ciphers TLS_RSA_WITH_3DES_EDE_CBC_SHA TLS_RSA_WITH_AES_128_CBC_SHA TLS_RSA_WITH_AES_256_CBC_SHA TLS_RSA_WITH_AES_128_GCM_SHA256 TLS_RSA_WITH_AES_256_GCM_SHA384 TLS_AES_128_GCM_SHA256 TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256 TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
tcpdump on the server side
In last resort, here is the the “Client Hello” frame of a tcpdump i did on my server (tcpdump port 443 -w websocket.pcap
) visualized in wireshark.
I did this both on with the “plain HTTPS” and the websocket.
I can provide the raw pcap
if needed but i did not find a way to upload them on the forum.
We clearly see that when doing a websocket connection, the client supports less ciphers. But it still supports TLS_RSA_WITH_3DES_EDE_CBC_SHA
that is also in Caddy so i don’t understand why the negotiation fails.
Websocket
We can see that the client accepts 17 cipher suites (and the connection then fails)
wireshark output (17 suites)
Frame 3: 233 bytes on wire (1864 bits), 233 bytes captured (1864 bits)
Ethernet II, Src: Cisco_e7:6a:a7 (b0:c5:3c:e7:6a:a7), Dst: VMware_05:16:57 (00:50:56:05:16:57)
Internet Protocol Version 4, Src: 109.122.178.45, Dst: 178.32.41.106
Transmission Control Protocol, Src Port: 53483, Dst Port: 443, Seq: 1, Ack: 1, Len: 167
Transport Layer Security
TLSv1.2 Record Layer: Handshake Protocol: Client Hello
Content Type: Handshake (22)
Version: TLS 1.0 (0x0301)
Length: 162
Handshake Type: Client Hello (1)
Length: 158
Version: TLS 1.2 (0x0303)
Random: 62148444e4c7329975919223874f2cd6ed38401c9331debd54b84e7851949b0f
Session ID Length: 0
Cipher Suites Length: 34
Cipher Suites (17 suites)
Cipher Suite: TLS_EMPTY_RENEGOTIATION_INFO_SCSV (0x00ff)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (0xc024)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (0xc023)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027)
Cipher Suite: TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 (0x006b)
Cipher Suite: TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 (0x0067)
Cipher Suite: TLS_DHE_RSA_WITH_AES_256_CBC_SHA (0x0039)
Cipher Suite: TLS_DHE_RSA_WITH_AES_128_CBC_SHA (0x0033)
Cipher Suite: TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA (0x0016)
Cipher Suite: TLS_RSA_WITH_AES_256_GCM_SHA384 (0x009d)
Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA256 (0x003d)
Cipher Suite: TLS_RSA_WITH_AES_128_CBC_SHA256 (0x003c)
Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA (0x0035)
Cipher Suite: TLS_RSA_WITH_AES_128_CBC_SHA (0x002f)
Cipher Suite: TLS_RSA_WITH_3DES_EDE_CBC_SHA (0x000a)
Compression Methods Length: 1
Compression Methods (1 method)
Extensions Length: 83
Extension: server_name (len=22)
Extension: supported_groups (len=8)
Extension: ec_point_formats (len=2)
Extension: signature_algorithms (len=18)
Extension: status_request (len=5)
Extension: signed_certificate_timestamp (len=0)
Extension: extended_master_secret (len=0)
[JA3 Fullstring: 771,255-49188-49187-49200-49192-49191-107-103-57-51-22-157-61-60-53-47-10,0-10-11-13-5-18-23,23-24-25,0]
[JA3: 70623e36f44974e030ad5615c304b592]
Plain HTTPS
We can see that the client accepts 27 cipher suites (and the connection then succeeds)
wireshark output
Frame 4: 583 bytes on wire (4664 bits), 583 bytes captured (4664 bits)
Transmission Control Protocol, Src Port: 49496, Dst Port: 443, Seq: 1, Ack: 1, Len: 517
TLSv1.3 Record Layer: Handshake Protocol: Client Hello
Length: 512
Length: 508
Random: bb4748f644cbe9b421d27390050c5a1d207b8b42378771a0ed2bfe1cc07e2447
Session ID Length: 32
Session ID: 89ce72717f57277cb7e0689217f4b8f6bed88ad128b5faae59594f32b4ceb620
Cipher Suites Length: 54
Cipher Suites (27 suites)
Cipher Suite: Reserved (GREASE) (0x2a2a)
Cipher Suite: TLS_AES_128_GCM_SHA256 (0x1301)
Cipher Suite: TLS_AES_256_GCM_SHA384 (0x1302)
Cipher Suite: TLS_CHACHA20_POLY1305_SHA256 (0x1303)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (0xc02c)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 (0xcca9)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f)
Cipher Suite: TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 (0xcca8)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (0xc00a)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (0xc009)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013)
Cipher Suite: TLS_RSA_WITH_AES_128_GCM_SHA256 (0x009c)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA (0xc008)
Cipher Suite: TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA (0xc012)
Extensions Length: 381
Extension: Reserved (GREASE) (len=0)
Extension: renegotiation_info (len=1)
Extension: supported_groups (len=12)
Extension: application_layer_protocol_negotiation (len=14)
Extension: signature_algorithms (len=24)
Extension: key_share (len=43)
Extension: psk_key_exchange_modes (len=2)
Extension: supported_versions (len=11)
Extension: compress_certificate (len=3)
Extension: Reserved (GREASE) (len=1)
Extension: padding (len=177)
[JA3 Fullstring: 771,10794-4865-4866-4867-49196-49195-52393-49200-49199-52392-49188-49187-49162-49161-49192-49191-49172-49171-157-156-61-60-53-47-49160-49170-10,39578-0-23-65281-10-11-16-5-13-18-51-45-43-27-10794-21,39578-29-23-24-25,0]
[JA3: 742e9bf0c7a47c03cbfec3ce8e427841]
