2.4.3
Installed using apt and started using systemd.
Debian 11
systemctl start caddy
Type=notify
domain.com, www.domain.com {
bind 999.888.777.666
reverse_proxy https://111.222.333.444 {
health_uri /
health_interval 10s
health_timeout 10s
health_status 2xx
header_up X-Real-IP {remote}
dial_timeout 10s
response_header_timeout 10s
expect_continue_timeout 10s
tls
tls_insecure_skip_verify
tls_timeout 10s
keepalive off
compression off
on_demand
import error.conf
My reverse proxy is working fine in general, but when the backend server itself has a cron job which runs the WordPress cron job file (wp-cron.php?doing_wp_cron) on the server I get a timeout.
Everything else works great and no errors except for this one.
Any suggestions?
Sep 01 19:35:12 reverse-proxy caddy[522]: {"level":"error","ts":1630517712.9930885,"logger":"http.log.error","msg":"error handling handler error","request":{"remote_addr":"111.222.333.444:59262","proto":"HTTP/1.1","method":"GET","host":"domain.com","uri":"/wp-cron.php?doing_wp_cron","headers":{"User-Agent":["Wget/1.19.5 (linux-gnu)"],"Accept":["*/*"],"Accept-Encoding":["identity"],"Connection":["Keep-Alive"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"domain.com"}},"duration":10.044065007,"error":"{id=8ii24ymig} fileserver.(*FileServer).notFound (staticfiles.go:495): HTTP 404","first_error":{"msg":"http2: timeout awaiting response headers","status":502,"err_id":"wxcnuxz8p","err_trace":"reverseproxy.statusError (reverseproxy.go:857)"}}
