"Timeout during connect" when obtaining certificates (ISP block maybe?)
Caddy used to run fine until suddenly it did not. I did not touch anything, really. Not from the server, not from my router configuration. I figured out Caddy is now suddenly unable to get certificates from issuers.
After this happened I purged Caddy and reinstalled it. In the process, I deleted the contents of /var/lib/caddy, because I wanted to delete the certificate cache.
Now the problem is the same as before deleting that folder and reinstalling Caddy.
If I do an nmap 80,443, both ports show filtered, but I’ve tried disabling my router’s Firewall and it’s the same.
EDIT: I also added “admin 0.0.0.0:2020” to my Caddyfile (see below) because it said port 2019 was already being used.
EDIT2: doing a “curl -v” to any of my domains, leads to a timeout (both http and https) - could it be that my ISP is suddenly blocking something? How would I go about checking that and fixing it given the case?
sep 23 12:59:10 afir-server caddy[14163]: {"level":"error","ts":1695466750.1335347,"logger":"tls.obtain","msg":"will retry","error":"[afirplay.ddns.net] Obtain: [afirplay.ddns.net] solving challenge: afirplay.ddns.net: [afirplay.ddns.net] authorization failed: HTTP 0  -  (ca=https://acme.zerossl.com/v2/DV90)","attempt":5,"retrying_in":600,"elapsed":769.400081908,"max_duration":2592000}
sep 23 13:08:54 afir-server caddy[14163]: {"level":"info","ts":1695467334.1165738,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"afirplay-movies.ddns.net"}
sep 23 13:08:55 afir-server caddy[14163]: {"level":"info","ts":1695467335.1157572,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"afirplay-movies.ddns.net","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
sep 23 13:09:05 afir-server caddy[14163]: {"level":"error","ts":1695467345.8316135,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"afirplay-movies.ddns.net","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"83.43.69.222: Timeout during connect (likely firewall problem)","instance":"","subproblems":[]}}
sep 23 13:09:05 afir-server caddy[14163]: {"level":"error","ts":1695467345.8316858,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"afirplay-movies.ddns.net","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"83.43.69.222: Timeout during connect (likely firewall problem)","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/119461654/11119947834","attempt":1,"max_attempts":3}
sep 23 13:09:07 afir-server caddy[14163]: {"level":"info","ts":1695467347.0013647,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"afirplay-tv.ddns.net"}
sep 23 13:09:07 afir-server caddy[14163]: {"level":"info","ts":1695467347.2408235,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"afirplay-movies.ddns.net","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
sep 23 13:09:07 afir-server caddy[14163]: {"level":"info","ts":1695467347.5946667,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"afirplay-tv.ddns.net","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
sep 23 13:09:10 afir-server caddy[14163]: {"level":"info","ts":1695467350.1344507,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"afirplay.ddns.net"}
sep 23 13:09:10 afir-server caddy[14163]: {"level":"info","ts":1695467350.7265687,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"afirplay.ddns.net","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
I installed it doing:
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy
I edited the Caddyfile and reloaded through
sudo service caddy reload
Ubuntu 22.04.1 LTS
I have no idea what you want here.
        email rogermacaya@gmail.com
        admin 0.0.0.0:2020
# domain name.
        root * /usr/share/caddy
        # php_fastcgi localhost:9000
afirplay.ddns.net {
        handle_path /tv* {
                reverse_proxy 127.0.0.1:8989
        handle /movies* {
                reverse_proxy 127.0.0.1:7878
                reverse_proxy localhost:8096
afirplay-movies.ddns.net {
        reverse_proxy localhost:7878
afirplay-tv.ddns.net {
        reverse_proxy localhost:8989
Solved! It was a very weird thing with my router where the ports would appear as forwarded in its GUI, but they were actually not. The fix was to delete the port forwarding in the router page and create it again.
