In reading through the install instructions for Caddy on OPNsense I noticed the following:
There is no TCP/UDP stream and WAF (Web Application Firewall) support in this plugin. For a business grade Reverse Proxy with WAF functionality, use os-OPNWAF. For TCP/UDP streaming, use either os-nginx or os-haproxy.
Does this mean that HTTP3 support is not yet in Caddy, since there is no TCP/UDP support? Has this changed since these instructions were published?
@Monviech can answer for the OPNsense integration, but as for Caddy, it definitely supports HTTP/3 both downstream and upstream (in the latest version).
Thanks Matt…makes sense. I was getting confused with the terminology. I just wanted to make sure I was not going to have issues with using HTTP3 in OPNsense and it looks to be working.
