I have two DNS records in cloudflare
- an explicit CNAME record for
plex.mydomain.compointing to the full tailscale name of my device - a CNAME record for
*.h.mydomain.comalso pointing to the same tailscale device
On caddy’s side I have
plex.mydomain.com, plex.h.mydomain.com, {
reverse_proxy 192.168.1.120:3000
import cloudflare
where cloudflare is the usual:
(cloudflare) {
dns cloudflare SOME_TOKEN
When I try accessing https://plex.h.mydomain.com everything works correctly and I get the SSL certificate. but when I use https://plex.mydomain.com I can access the server but my browser is not happy about the SSL certificate.
When I look at the logs I see
http.auto_https skipping automatic certificate management because one or more matching certificates are already loaded
for plex.mydomain.com
what makes the problem go away is adding the global:
auto_https ignore_loaded_certs
so I think the problem is related to caddy using some old certificates or getting confused about the wildcard certificates.
Am I doing something obviously wrong?
v2.9.0 h1:rteY8N18LsQn+2KVk6R10Vg/AlNsID1N/Ek9JLjm2yE=
Downloaded caddy + cloudflare plugin and saved the binary
ubuntu + systemd
