v2.1.1
Caddy is started from systemd. Installed locally on physical machine.
It is only used for reverse_proxy.
Linux Mint 20
systemd - systemd 245 (245.4-4ubuntu3.2)
jimmy@mint:~$ caddy environ
caddy.HomeDir=/home/jimmy
caddy.AppDataDir=/home/jimmy/.local/share/caddy
caddy.AppConfigDir=/home/jimmy/.config/caddy
caddy.ConfigAutosavePath=/home/jimmy/.config/caddy/autosave.json
runtime.GOOS=linux
runtime.GOARCH=amd64
runtime.Compiler=gc
runtime.NumCPU=16
runtime.GOMAXPROCS=16
runtime.Version=go1.14.4
os.Getwd=/home/jimmy
sudo nano systemctl start caddy
# caddy.service
# for your installation.
After=network.target
User=jimmy
Group=jimmy
ExecStart=/usr/bin/caddy run --environ --config /home/jimmy/caddy/Caddyfile
ExecReload=/usr/bin/caddy reload --config /home/jimmy/caddy/Caddyfile
tautulli.mysrvr.me {
gzip
proxy / localhost:8181 {
#sonarr
sonarr.mysrvr.me {
gzip
proxy / localhost:8989 {
#radarr
radarr.mysrvr.me {
gzip
proxy / localhost:7878 {
#ombi
ombi.jsuttinger.com {
gzip
proxy / localhost:5000 {
#portainer
portainer.mysrvr.me {
gzip
proxy / localhost:9000 {
#jellyfin
jellyfin.mysrvr.me {
gzip
proxy / localhost:8096 {
websocket
#nextcloud
nextcloud.jsuttinger.com {
gzip
proxy / localhost:8823 {
websocket
#airsonic
audio.mysrvr.me {
gzip
proxy / localhost:4040 {
#bookstack
wiki.mysrvr.me {
gzip
proxy / localhost:6875 {
#app
#app.mysrvr.me {
# encode gzip
# reverse_proxy localhost:port
I accidentally got fat fingered and moved ~/caddy/Caddfile to a new location. Ooops! I noticed later and moved it back to the original location, ~/caddy/ Since, I am unable to start it with systemd.
● caddy.service - Caddy
Active: failed (Result: exit-code) since Fri 2020-07-31 14:32:26 EDT; 2s ago
Process: 71351 ExecStart=/usr/bin/caddy run --environ --config /home/jimmy/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 71351 (code=exited, status=1/FAILURE)
Jul 31 14:32:26 mint caddy[71351]: JOURNAL_STREAM=9:647671
Jul 31 14:32:26 mint caddy[71351]: {"level":"info","ts":1596220346.9619558,"msg":"using provided configuration","config_file":"/home/jimmy/caddy/Caddyfile","config_adapter":""}
Jul 31 14:32:26 mint caddy[71351]: {"level":"info","ts":1596220346.9641256,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["127.0.0.1:2019","localhost:2019","[::1]:2019"]}
Jul 31 14:32:26 mint caddy[71351]: 2020/07/31 14:32:26 [INFO][cache:0xc000804b40] Started certificate maintenance routine
Jul 31 14:32:26 mint caddy[71351]: {"level":"info","ts":1596220346.9645755,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jul 31 14:32:26 mint caddy[71351]: {"level":"info","ts":1596220346.9645998,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 31 14:32:26 mint caddy[71351]: {"level":"info","ts":1596220346.9699855,"logger":"tls","msg":"cleaned up storage units"}
Jul 31 14:32:26 mint caddy[71351]: run: loading initial config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: address already in use
Jul 31 14:32:26 mint systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jul 31 14:32:26 mint systemd[1]: caddy.service: Failed with result 'exit-code'.
I have tried to adjust the permissions on the Caddyfile, tried 755. It’s currently back at 644.
I have tried to restart systemd, restart server, restart caddy, caddy reload
I have tried changing the ExecStart and ExecReload paths to use ~/ or env variable $USERDIR
I have tried changing the user and group in the caddy.service systemd file
I have tried deleting and re-creating the caddy.service systemd file.
None of these have provided different results.
source of systemd: dist/init/caddy.service at master · caddyserver/dist · GitHub
