Systemctl error
I’m trying to start caddy with systemctl so that it can run in the background properly.
I’ve tried various things and read many tutorials but nothing seems to work.
I’ve also read this topic: Starting with systemd: Failed at step NAMESPACE spawning /usr/local/bin/caddy: No such file or directory
I’m using ubuntu 16.04 VPS.
This is the error I get:
     ● caddy.service - Caddy HTTP/2 web server
       Active: failed (Result: exit-code) since Mon 2019-02-18 23:53:51 CET; 19h ago
         Docs: https://caddyserver.com/docs
     Main PID: 1164 (code=exited, status=226/NAMESPACE)
    Feb 18 23:53:51 ubuntu systemd[1]: Started Caddy HTTP/2 web server.
    Feb 18 23:53:51 ubuntu systemd[1]: caddy.service: Main process exited, code=exited, status=226/NAMESPACE
    Feb 18 23:53:51 ubuntu systemd[1]: caddy.service: Unit entered failed state.
    Feb 18 23:53:51 ubuntu systemd[1]: caddy.service: Failed with result 'exit-code'.
And this is how my caddy.service file looks like:
    After=network-online.target
    Restart=on-abnormal
    User=www-data
    Group=www-data
    ; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
    ExecStart=/usr/local/bin/caddy -log stdout -agree=true -conf=/etc/caddy/Caddyfile -root=/var/tmp
    ExecReload=/bin/kill -USR1 $MAINPID
    ; Use graceful shutdown with a reasonable timeout
    KillMode=mixed
    KillSignal=SIGQUIT
    ; Unmodified caddy is not expected to use more than that.
    ; Use a minimal /dev (May bring additional security if switched to 'true', but it may not work on Raspberry Pi's or other devices, so it has been disabled in this dist.)
    PrivateDevices=false
    ProtectHome=true
    ; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
    ;   This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
    ReadWriteDirectories=/etc/ssl/caddy
    ; They further restrict privileges that can be gained by caddy. Uncomment if you like.
    ;CapabilityBoundingSet=CAP_NET_BIND_SERVICE
    ;AmbientCapabilities=CAP_NET_BIND_SERVICE
    ;NoNewPrivileges=true
Any ideas?
Hi @Petar_Peric,
Throw us the output of which caddy from the shell, and also try it with PrivateTmp=true commented in the unit file.
Here’s the output of which caddy:
Commenting PrivateTmp=true didn’t make a difference.
OK, hmmmm…
I’m assuming that /etc/ssl/caddy exists and is writable by www-data user or group.
The only other things that occur to me to change are alternately (AND/OR):
  • Commenting out all of PrivateTmp, PrivateDevices, ProtectHome, and ProtectSystem
  • Uncommenting CapabilityBoundingSet, AmbientCapabilities, and NoNewPrivileges
These are the permissions of caddy folder in /etc/ssl/, do they look ok to you?
drwxrwx--- 2 root www-data 4096 Feb 19 18:47 caddy
I’ve tried changing the lines you suggested and reloading the systemctl deamon but still get the same error :confused:
Yeah, looks good (group rwx for www-data).
What distro are you running it on?
Ubuntu 16.04
Oh, whoops, you mentioned that in the OP, I should have re-read it.
Yeah, I’m stumped. systemd is black magic to me, and searches for 226/NAMESPACE don’t give a great result other than a bunch of threads we’ve had on it in the past.
If I had time I’d spin up a fresh 16.04 VPS somewhere and go through the process of installing Caddy and its unit file from scratch to check whether it’s a problem inherent with the latest Caddy or unit file.
I’ve tried it on a fresh VPS and get the same error, don’t know what I’m doing wrong. Any other ideas?
Also, what would be the next best way to run caddy in the background, as an alternative to systemd?
I use Docker for the vast majority of services I run. It brings containers up at boot if they were up at shutdown, pending what you set the container restart policy to. But it’s very much not just a swap-in for an init system; it’s worth treating as a whole other beast if you’re not familiar with containers.
You could also try downloading Caddy with the service plugin and see if the unit file it installs works for you: https://caddyserver.com/docs/hook.service
Running with the service plugin worked, thanks!
