{system.hostname}: subject does not qualify for certificate
I want to use the same Caddyfile for several physical servers and the servers hostname should be part of one of the Site blocks. Since every physical server has a different hostname, I thought I want to use {system.hostname}.example.com { but I get the below error.
The page Conventions — Caddy Documentation says “The following placeholders are always available:” and also lists {system.hostname}.
$ ./caddy run
2023/07/25 15:13:25.557 INFO    using adjacent Caddyfile
Error: adapting config using caddyfile: subject does not qualify for certificate: '{system.hostname}.arm.stbu.net'
Downloaded from Download Caddy with two extra features:
  • github.com/caddyserver/transform-encoder
  • github.com/ueffel/caddy-tls-format
  • Oracle Linux 8.8
  • Linux instance-20221129-1409 5.15.0-102.110.5.1.el8uek.aarch64 #2 SMP Sat Jun 10 18:23:55 PDT 2023 aarch64 aarch64 aarch64 GNU/Linux
./caddy run
not applicable
        http_port 18080
        https_port 18443
        #       local_certs
        skip_install_trust
localhost:18080, localhost:18443, {system.hostname}.arm.stbu.net {
        # This would work:
        ##localhost:18080, localhost:18443, {$HOSTNAME}.arm.stbu.net {
        log
        respond "Welcome"
Since {$HOSTNAME}.example.com would be working, I think this is a bug and I can file an Issue at Github - unless this is done intentionally. If I enable local_certs it would be working with {system.hostname}.example.com as well. For me, it looks like the validation whether a site block name qualifies for public certificates should try to resolve {system.hostname} first, just like “local_certs”.
Placeholders can’t be used for site addresses. Site addresses must be known at config-adapt time to properly configure the server.
{$HOSTNAME} works because it’s a special case in the Caddyfile for replacing environment variables. But placeholders in general will not work.
Thank you very much, again.
