Synology Permission Issues
I am trying to run Caddy (embedded within a Docker app) on my Synology device as a non-root account, however I am unable to do so. I am able to get Caddy to properly work when I use my root account. If I use a non-root account (even if it has full admin permissions) it does not work.
The Docker app within question is called Pocket ID:
I 100% understand this might be an issue with my Synology (due to how they do permissions) and NOT an issue with Caddy whatsoever but I figured I would ask. I should also reiterate that Pocket ID is currently working (so therefore Caddy is working).
Creating user and group...
passwd: password for pocket-id is unchanged
Changing password for pocket-id
New password:
Starting frontend...
Starting backend...
Starting Caddy...
2025/01/12 01:08:26 GeoLite2 City database is up-to-date.
WRN | ts=1736644106.8758528 msg=failed to set GOMAXPROCS error=open /sys/fs/cgroup/cpu/cpu.cfs_quota_us: no such file or directory
WRN | ts=1736644106.9430258 msg=failed to set GOMAXPROCS error=open /sys/fs/cgroup/cpu/cpu.cfs_quota_us: no such file or directory
INF | ts=1736644106.9432714 msg=using config from file file=/etc/caddy/Caddyfile.trust-proxy
INF | ts=1736644106.945159 msg=adapted config to JSON adapter=caddyfile
INF | ts=1736644106.946377 logger=admin msg=admin endpoint started address=localhost:2019 enforce_origin=false origins=["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]
WRN | ts=1736644106.9467092 logger=http.auto_https msg=server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server server_name=srv0 http_port=80
INF | ts=1736644106.9467788 logger=tls.cache.maintenance msg=started background certificate maintenance cache=0xc000052280
INF | ts=1736644106.9474592 logger=tls.cache.maintenance msg=stopped background certificate maintenance cache=0xc000052280
Error: loading initial config: loading new config: http app module: start: listening on :80: listen tcp :80: bind: permission denied
Error: caddy process exited with error: exit status 1
Listening on 0.0.0.0:3002
Within Pocket ID → v2.9.1
I am currently running Caddy within Pocket ID via Docker Compose (that was deployed with Portainer).
My Environment:
  • Portainer → 20.10.23 (API: 1.41)
  • DSM 7.2.2-72806 Update 2
  • Synology DS1621+
  pocket-id:
    image: stonith404/pocket-id  # or ghcr.io/stonith404/pocket-id
    env_file:
      - stack.env
      - "/volume1/docker/storage/pocket-id/data:/app/backend/data"
    # Optional healthcheck
    healthcheck:
      test: "curl -f http://localhost/health"
      interval: 1m30s
      timeout: 5s
      retries: 2
      start_period: 10s
The original discussion surrounding my problem:
They’ve already given you the correct answer:
However, you need to change the internal Caddy port to something above 1024. For example, 8080 looks like a nice number.
Only root can bind to ports below 1024.
