1. Output of caddy version
docker
docker compose up -d
version: "2.1"
image: caddy:2.3.0
- 444:443
- ./caddy/site:/srv
- ./caddy/caddy_data:/data
- ./caddy/caddy_config:/config
- caddy
portainer:
image: portainer/portainer-ce
container_name: portainer_ce
- ./portainer_data:/data
restart: always
- caddy
homer:
image: b4bz/homer:latest
container_name: homer
- PUID=1000
- PGID=1000
- ./homer_assets/:/www/assets
restart: always
caddy_data:
external: true
caddy_config:
email email@address.com
jellyfin.domain {
reverse_proxy 192.168.86.60:8096
portainer.domain {
reverse_proxy portainer:9000
photoprism.domain {
reverse_proxy 192.168.86.60:2342
audioshelf.domain{
reverse_proxy 192.168.86.60:13378
md.domain, element.md.domain, matrix.md.domain {
# creates letsencrypt certificate
# tls your@email.com
# Enable HTTP Strict Transport Security (HSTS) to force clients to always connect via HTTPS
# Prevent some browsers from MIME-sniffing a response away from the declared Content-Type
# Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "DENY"
# X-Robots-Tag
X-Robots-Tag "noindex, noarchive, nofollow"
encode zstd gzip
reverse_proxy http://192.168.86.72:81 {
header_up X-Forwarded-Proto {http.request.scheme}
suddenly stopped working. i was just restarting my server and after that i noticed i couldn’t access jellyfin. direct ip was working so i realized it was a caddy issue. unable to go through caddy to any of my services. if i try to access them, the request times out. it’ll keep loading for awhile until it says timed out. i’ll put a snippet below the dockers logs.
INF ts=1670382965.1011183 msg=using provided configuration config_file=/etc/caddy/Caddyfile config_adapter=caddyfile
INF ts=1670382965.1080086 logger=admin msg=admin endpoint started address=tcp/localhost:2019 enforce_origin=false origins=["localhost:2019","[::1]:2019","127.0.0.1:2019"]
INF ts=1670382965.1099286 logger=tls.cache.maintenance msg=started background certificate maintenance cache=0xc0003ca000
INF ts=1670382965.1108608 logger=http msg=server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS server_name=srv0 https_port=443
INF ts=1670382965.1108844 logger=http msg=enabling automatic HTTP->HTTPS redirects server_name=srv0
INF ts=1670382965.112319 logger=http msg=enabling automatic TLS certificate management domains=["element.md.domain","matrix.md.domain","portainer.domain","wireguard.domain","jellyfin.domain","photoprism.domain","audioshelf.domain","md.domain"]
WRN ts=1670382985.1328013 logger=tls msg=stapling OCSP error=no OCSP stapling for [element.md.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:52056->127.0.0.11:53: i/o timeout
WRN ts=1670383005.145432 logger=tls msg=stapling OCSP error=no OCSP stapling for [matrix.md.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:37205->127.0.0.11:53: i/o timeout
WRN ts=1670383025.1496916 logger=tls msg=stapling OCSP error=no OCSP stapling for [portainer.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:43486->127.0.0.11:53: i/o timeout
WRN ts=1670383045.1563635 logger=tls msg=stapling OCSP error=no OCSP stapling for [wireguard.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:35658->127.0.0.11:53: i/o timeout
WRN ts=1670383065.1666393 logger=tls msg=stapling OCSP error=no OCSP stapling for [jellyfin.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:37986->127.0.0.11:53: i/o timeout
WRN ts=1670383085.1866305 logger=tls msg=stapling OCSP error=no OCSP stapling for [photoprism.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:36015->127.0.0.11:53: i/o timeout
WRN ts=1670383105.1930833 logger=tls msg=stapling OCSP error=no OCSP stapling for [audioshelf.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:37515->127.0.0.11:53: i/o timeout
WRN ts=1670383125.2059655 logger=tls msg=stapling OCSP error=no OCSP stapling for [md.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:36209->127.0.0.11:53: i/o timeout
INF ts=1670383125.212933 msg=autosaved config file=/config/caddy/autosave.json
INF ts=1670383125.2129765 msg=serving initial configuration
INF ts=1670383125.2275429 logger=tls msg=cleaned up storage units
INF ts=1670383438.923854 msg=using provided configuration config_file=/etc/caddy/Caddyfile config_adapter=caddyfile
INF ts=1670383438.9287724 logger=admin msg=admin endpoint started address=tcp/localhost:2019 enforce_origin=false origins=["localhost:2019","[::1]:2019","127.0.0.1:2019"]
INF ts=1670383438.9300244 logger=tls.cache.maintenance msg=started background certificate maintenance cache=0xc000436e00
INF ts=1670383438.9313545 logger=http msg=server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS server_name=srv0 https_port=443
INF ts=1670383438.9313731 logger=http msg=enabling automatic HTTP->HTTPS redirects server_name=srv0
INF ts=1670383438.9334924 logger=http msg=enabling automatic TLS certificate management domains=["portainer.domain","wireguard.domain","jellyfin.domain","photoprism.domain","audioshelf.domain","md.domain","element.md.domain","matrix.md.domain"]
INF ts=1670383438.9750254 logger=tls msg=cleaned up storage units
WRN ts=1670383458.9485354 logger=tls msg=stapling OCSP error=no OCSP stapling for [portainer.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:41198->127.0.0.11:53: i/o timeout
WRN ts=1670383478.953822 logger=tls msg=stapling OCSP error=no OCSP stapling for [wireguard.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:43660->127.0.0.11:53: i/o timeout
WRN ts=1670383498.957152 logger=tls msg=stapling OCSP error=no OCSP stapling for [jellyfin.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:40503->127.0.0.11:53: i/o timeout
WRN ts=1670383518.9601293 logger=tls msg=stapling OCSP error=no OCSP stapling for [photoprism.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:36090->127.0.0.11:53: i/o timeout
WRN ts=1670383538.9715683 logger=tls msg=stapling OCSP error=no OCSP stapling for [audioshelf.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:51031->127.0.0.11:53: i/o timeout
WRN ts=1670383558.981097 logger=tls msg=stapling OCSP error=no OCSP stapling for [md.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:46498->127.0.0.11:53: i/o timeout
WRN ts=1670383578.9904218 logger=tls msg=stapling OCSP error=no OCSP stapling for [element.md.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:59288->127.0.0.11:53: i/o timeout
WRN ts=1670383599.0029407 logger=tls msg=stapling OCSP error=no OCSP stapling for [matrix.md.domain]: making OCSP request: Post "http://r3.o.lencr.org": dial tcp: lookup r3.o.lencr.org on 127.0.0.11:53: read udp 127.0.0.1:55137->127.0.0.11:53: i/o timeout
INF ts=1670383599.0101924 msg=autosaved config file=/config/caddy/autosave.json
INF ts=1670383599.0102413 msg=serving initial configuration
The connection has timed out
An error occurred during a connection to jellyfin.domain
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
ports are at 84/444 since that’s what i had working before and that’s what my router has. tried 443 but that didn’t work. tried to go back to caddy:2.3.0, that didn’t work either. tried redownloading latest images as well. having a hard time figure out what the issue is.
