I have a subdomain “udpservice, xyz,com” i am forwarding it to a server address with registration.
I use it as a gameserver and it communicates via the udp port.
I want to hide the IP address is it possible?
And can someone tell me how to do it step by step?
I think caddy is for http proxy only, you may need to check vpn or port forwarding for udp proxy.
This plugin proxies UDP: GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy
