Strange Redirect issue with Reverse Proxy
So I’m using the Reverse proxy in caddy to direct a custom domain with SSL using Caddy. The original site looks something like this:
The original site is hosted at page.example.com/dashboard1, page.example.com/dashboard2 and so on and if a user visits page.example.com (the root without /path), they’re automatically directed to www.example.com
And so with the caddy, I wish to accomplish Reverse proxy with SSL with the domain abc.firstdomain.com where abc.firstdomain.com directs to page.example.com/dashboard1 and xyz.seconddomain.com redirects to page.example.com/dashboard2
(Caddyfile attached below)
The SSL works successfully and is issued but for some strange reason, when abc.firstdomain.com is entered in the browser, instead of displaying contents from page.example.com/dashboard1, the page is redirected to www.example.com
Since I’m using a React JS app with React router configured as follows, is this an expected issue?
No errors but page redirects
I installed on EC2 using serverless:
 #!/bin/bash -xe
 sudo wget -O /usr/bin/caddy "https://github.com/tobilg/aws-caddy-build/raw/main/releases/aws_caddy_v2.6.2_linux"
sudo chmod +x /usr/bin/caddy
sudo groupadd --system caddy
sudo useradd --system --gid caddy --create-home --home-dir /var/lib/caddy --shell /usr/sbin/nologin --comment "Caddy web server" caddy
Amazon 2 Linux
Command above
See the commands above
        order rewrite after forward_auth
        admin off
        on_demand_tls {
                ask {env.DOMAIN_SERVICE_ENDPOINT}
        storage_clean_interval 90d
        log
        respond /health "Im healthy" 200
        log
:443 {
        tls {env.EMAIL} {
                on_demand
        forward_auth {env.ENDPOINT} {
                uri /?sourceHost={host}&extraUri={uri}
                copy_headers Pathroute Domainroute Domainhttpsroute
        rewrite * {header.Pathroute}
        try_files {path} /index.html
        reverse_proxy {header.Domainroute}:443 {
                header_up Host {http.reverse_proxy.upstream.host}
                header_up User-Custom-Domain {host}
                header_down Cache-Control max-age=5184000
                health_timeout 5s
                        tls
        log
forward_auth endpoint file with hardcoded values for testing:
exports.handler = async (event) => {
    let statusCode;
    let pathRoute = '';
    if (event.queryStringParameters && event.queryStringParameters.hasOwnProperty('sourceHost')) {
      const extraUri = event.queryStringParameters.extraUri;
      if(extraUri==='/' || !extraUri || extraUri===''){
        pathRoute = '/dashboard1';
      else{
        pathRoute = extraUri
      statusCode = 200;
    } else {
      statusCode = 400;
    return {
        headers: {
          'Pathroute': pathRoute,
          'Domainroute': 'page.example.com',
          'Domainhttpsroute': 'https://page.example.com',
        statusCode: 200,
If your JS is redirecting, then obviously it’ll redirect. Don’t do that then.
But based on my assumption when doing a reverse proxy with caddy for a site page.example.com/dashboard1, does it not fetch the results from that page and directly send it over to abc.firstdomain.com or it only builds after fetching?
I don’t understand the question.
Okay to put it more elaborately, in the above code, I’ve ensured that when a request to the caddy server comes from abc.firstdomain.com, for the first time the page should be proxied to page.example.com/dashboard1, it must serve that specific route in the React application (as you can see in the forward_auth config, I append /dashboard1 for the first request)
But the opposite seems to happen, the result appears the same regardless of whether I do the condition check and by default the React app seems to serve the page for ‘/’ path instead of doing it for ‘/:wallUrl’ since the first time the rewritten URI would be page.example.com/dashboard1
TLDR; Both page.example.com & page.example.com/dashboard1 when proxied through Caddy show the same page while it should present different results. Is this peculiar to React since React-Router is used? Or is it the default behavior of Caddy?
Do you see debug logs for rewrite happening?
Yeah I do but never mind I found a workaround for this just by writing the appropriate “Route” logic in the React app since the routing happens on client side
