Strange "invalid memory address or nil pointer dereference" with custom build
2.4.5 built with Better fix for #142; patches 335551df · caddyserver/certmagic@88b8609 · GitHub
systemctl start caddy
# caddy.service
# for your installation.
# https://www.freedesktop.org/software/systemd/man/systemd.unit.html
# No more than StartLimitBurst service start during StartLimitIntervalSec period
StartLimitIntervalSec=500
StartLimitBurst=5
# https://www.freedesktop.org/software/systemd/man/systemd.service.html
# Wait RestartSec before an auto restart on-failure
Restart=on-failure
RestartSec=5s
Type=notify
(log) {
        output file {args.0} {
            roll_size     100MiB
        level DEBUG
        format json
        format filter {
            wrap json
            fields {
                common_log delete
                resp_headers>Content-Security-Policy delete
                request>remote_addr ip_mask {
                    ipv4 24
                    ipv6 32
    #Bind admin endpoint on all interfaces
    admin 0.0.0.0:2019
    on_demand_tls {
        ask http://localhost:8000/api/cname/validate
    # Workaround to prevent on_demand being enabled on all domains
    # see https://github.com/caddyserver/caddy/pull/4128
    email security+caddy@lempire.co
    import log /var/log/caddy/default_req.log
    # Reduce caddy reload grace_period to 3 min (default was 20 min) to improve reload
    # See https://caddy.community/t/hangs-on-reload/12010/35
    # Because of websockets long cnx, reload always took grace_period duration
    grace_period 3m
# Redirect any accesses using an IP instead of a domain name
# hackerone report: https://hackerone.com/reports/723126
51.91.128.49:80,
91.121.37.140:80,
147.135.229.201:80,
51.254.243.65:80,
54.36.18.249:80,
46.105.54.36:80
    redir https://app.lemlist.com{uri}
(cloudflare_matchers) {
    remote_ip 103.21.244.0/22
    remote_ip 103.22.200.0/22
    remote_ip 103.31.4.0/22
    remote_ip 104.16.0.0/13
    remote_ip 104.24.0.0/14
    remote_ip 108.162.192.0/18
    remote_ip 131.0.72.0/22
    remote_ip 141.101.64.0/18
    remote_ip 162.158.0.0/15
    remote_ip 172.64.0.0/13
    remote_ip 173.245.48.0/20
    remote_ip 188.114.96.0/20
    remote_ip 190.93.240.0/20
    remote_ip 197.234.240.0/22
    remote_ip 198.41.128.0/17
    remote_ip 2400:cb00::/32
    remote_ip 2606:4700::/32
    remote_ip 2803:f800::/32
    remote_ip 2405:b500::/32
    remote_ip 2405:8100::/32
    remote_ip 2a06:98c0::/29
    remote_ip 2c0f:f248::/32
(front_servers) {
    to localhost:42001
    to localhost:42002
    to localhost:42003
    to localhost:42004
    to localhost:42005
    to localhost:42006
    to localhost:42007
    to localhost:42008
    health_uri /api/ping
    health_interval 1s
    health_timeout 5s
(badbots_filter) {
    @badbots {
        header_regexp User-Agent "(?i)Fuzz Faster U Fool.*"
    header @badbots {
        X-Cache-Debug "bbf"
        Server ""
    respond @badbots "Access denied" 403
# Main application
app.lemlist.com,
app2.lemlist.com
    import log /var/log/caddy/front_req.log
    # route keyword is mandatory to force Caddy to keep our
    #   directives order instead of using the Caddy builtin order
    route {
        request_body {
            max_size 20MB
        @from_cloudflare {
            import cloudflare_matchers
        @not_from_cloudflare {
            not {
        # pass all api lempire (e, i) requests to one
        #   dedicated Meteor app process
        @api_e_i {
            path /api/lempire/*
        header @api_e_i {
            X-Cache-Debug "app.api_e_i"
            Server ""
        reverse_proxy @api_e_i {
            to localhost:8000
        # pass all api requests to Meteor api process
        @api {
            path /api/*
        header @api {
            X-Cache-Debug "app.api"
            Server ""
        reverse_proxy @api {
            to localhost:42100
        # Caches
        # must be after /api routes or https://app.lemlist.com/api/froala/files/*.jpg will not be served by meteor
        @cache_app {
            path *.svg *.woff2 *.eot *.ttf *.woff *.jpg *.jpeg *.png *.gif *.ico *.html
        header @cache_app {
            # 1d expiration
            Cache-Control max-age=86400
            X-Cache-Debug "app.cache"
            Server ""
        file_server @cache_app {
            root /opt/lemlist/app/programs/web.browser/app
        @cache_app2 {
            path_regexp ^/lib/.*\.(map|js|css)$
        header @cache_app2 {
            # 1d expiration
            X-Cache-Debug "app.cache2"
            Server ""
        file_server @cache_app2 {
        @cache_version {
            path_regexp ^/[0-9a-z]+\.(js|css|map).*
        header @cache_version {
            # 1d expiration
            X-Cache-Debug "app.cache_version"
            Server ""
        file_server @cache_version {
            root /opt/lemlist/web.browser
        # Anything else goes to Meteor fronts
        header @from_cloudflare {
            X-Cache-Debug "app.main.cf"
            Server ""
        reverse_proxy @from_cloudflare {
            header_up X-Real-IP {http.request.header.CF-Connecting-IP}
            header_up X-Forwarded-For {http.request.header.CF-Connecting-IP}
            header_up Lb-Hash {http.request.header.CF-Connecting-IP}:{remote_port}
            import front_servers
            lb_policy header CF-Connecting-IP
        header @not_from_cloudflare {
            X-Cache-Debug "app.main"
            Server ""
        reverse_proxy @not_from_cloudflare {
            header_up Lb-Hash {remote_host}:{remote_port}
            lb_policy ip_hash
        handle * {
            respond 404
    handle_errors {
        @errors {
            expression {http.error.status_code} == '502'
        rewrite @errors /{http.error.status_code}.html
        file_server {
            root /var/www
    #dev only : to work on laptop localhost
    #tls internal
# Custom domains
(custom_domains) {
    import log /var/log/caddy/custom_{args.0}_req.log
    route {
        import badbots_filter
        # render a special page when on root so the user can see if
        #   its custom domain is correctly setted up
        header / {
            X-Cache-Debug "custom.cname_ok"
            Server ""
        file_server / {
            root /var/www/lemlist_cname_ok
        # pass all requests "track open/click" to track
        @track {
            path_regexp ^/api/(t/c|track/open|reply)/
        header @track {
            X-Cache-Debug "custom.track"
            Server ""
        reverse_proxy @track {
            to localhost:42160
        # pass all requests "images + pages" to images
        @images {
            path /*
        header @images {
            X-Cache-Debug "custom.images"
            Server ""
        reverse_proxy @images {
            to localhost:42140
        handle * {
            respond 404
# WARNING : DO NOT add any other site address than :443 here
:443
    import custom_domains on_demand
        on_demand
        issuer acme {
            dir https://acme.zerossl.com/v2/DV90
            eab ...
        issuer acme {
            dir https://acme-v02.api.letsencrypt.org/directory
pages.lemlist.com
    import custom_domains predefined
# WARNING : DO NOT add any other site address than :80 here
:80
    import custom_domains port80
# public direct access to service
(public_passthrough) {
    {args.0}
        import log /var/log/caddy/public_passthrough_{args.0}_req.log
        route {
            request_body {
                max_size 20MB
            header * {
                X-Cache-Debug "{args.0}.main"
                Server ""
            reverse_proxy * {
                to localhost:{args.1}
import public_passthrough api.lemlist.com 42100
import public_passthrough img.lemlist.com 42150
# https://front.lempire.co -> admin
import public_passthrough front.lem.ovh 8000
# private direct access to services
(private_passthrough) {
    front.lem.ovh:{args.0}
        import log /var/log/caddy/private_passthrough_{args.0}_req.log
        route {
            @cache_version {
                # 1d expiration
                X-Cache-Debug "direct.cache_version"
                Server ""
            header * {
                X-Cache-Debug "direct.main"
                Server ""
            reverse_proxy * {
        basicauth * {
            zzz ....
# Fronts
import private_passthrough 43001 42001
import private_passthrough 43002 42002
import private_passthrough 43003 42003
import private_passthrough 43004 42004
import private_passthrough 43005 42005
import private_passthrough 43006 42006
import private_passthrough 43007 42007
import private_passthrough 43008 42008
# API
import private_passthrough 43100 42100
# Cron
import private_passthrough 43130 42130
# Images Front
import private_passthrough 43150 42150
# Track
import private_passthrough 43160 42160
# Images
import private_passthrough 43140 42140
Got 2 crashes in one week, not sure both are related… But I never got crashes with previous versions, using caddy for 6 months.
For the 1st crash, the service stopped.
Strangely the 2nd one was “only” a panic, the process was running, but sites were 408
May be let focus on 2nd one, as logs are interesting:
There is this very strange log line where removing_subjects is empty, same for removing_hash
"msg":"cache full; evicting random certificate","removing_subjects":[],"removing_hash":"","inserting_subjects":["pages.csmagency.ie"],"inserting_hash":"185532f43cf6f805e14cb7a035742456aadb0d6e400d578c8ecde2cfe1c090f4"
a bit more logs until the panic occured in removeCertificate():
{"level":"debug","ts":1633549994.4163284,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["custom.lemlist.com"],"managed":true,"expiration":1640822399,"hash":"a2fcedd5f125596efefa7c1021fa5d074e41d028876e084c4636ecd1da512122"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.421294,"logger":"http.handlers.file_server","msg":"sanitized path join","site_root":"/var/www/lemlist_cname_ok","request_path":"/","result":"/var/www/lemlist_cname_ok"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4213588,"logger":"http.handlers.file_server","msg":"located index file","filename":"/var/www/lemlist_cname_ok/index.html"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4213848,"logger":"http.handlers.file_server","msg":"opening file","filename":"/var/www/lemlist_cname_ok/index.html"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4240758,"logger":"tls.handshake","msg":"choosing certificate","identifier":"trail.lemlist.com","num_choices":1}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4241347,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"trail.lemlist.com","subjects":["trail.lemlist.com"],"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"26c05f9b2e8d127a6fe949a1145302a843f44089c7567ae9e2c1ce1c8a854013"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4241555,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["trail.lemlist.com"],"managed":true,"expiration":1640822399,"hash":"26c05f9b2e8d127a6fe949a1145302a843f44089c7567ae9e2c1ce1c8a854013"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4276536,"logger":"tls.cache","msg":"cache full; evicting random certificate","removing_subjects":[],"removing_hash":"","inserting_subjects":["pages.csmagency.ie"],"inserting_hash":"185532f43cf6f805e14cb7a035742456aadb0d6e400d578c8ecde2cfe1c090f4"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4280682,"logger":"http.handlers.file_server","msg":"sanitized path join","site_root":"/var/www/lemlist_cname_ok","request_path":"/","result":"/var/www/lemlist_cname_ok"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4281065,"logger":"http.handlers.file_server","msg":"located index file","filename":"/var/www/lemlist_cname_ok/index.html"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4281197,"logger":"http.handlers.file_server","msg":"opening file","filename":"/var/www/lemlist_cname_ok/index.html"}
2021-10-06 21:53:14
{"level":"debug","ts":1633549994.4286802,"logger":"http.stdlib","msg":"http: panic serving 212.102.49.131:44993: runtime error: invalid memory address or nil pointer dereference\ngoroutine 71579125 [running]:\nnet/http.(*conn).serve.func1(0xc04fa35540)\n\t/usr/local/go/src/net/http/server.go:1824 +0x153\npanic(0x16d7ac0, 0x25baad0)\n\t/usr/local/go/src/runtime/panic.go:971 +0x499\ngithub.com/caddyserver/certmagic.(*Cache).removeCertificate(0xc0004808c0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc0359e7e00, ...)\n\t/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/cache.go:281 +0x419\ngithub.com/caddyserver/certmagic.(*Cache).unsyncedCacheCertificate(0xc0004808c0, 0xc04e1d6180, 0x3, 0x4, 0x17d61c0, 0xc03321f800, 0x0, 0x0, 0x0, 0xc01f65ee00, ...)\n\t/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/cache.go:227 +0xbfd\ngithub.com/caddyserver/certmagic.(*Cache).cacheCertificate(0xc0004808c0, 0xc04e1d6180, 0x3, 0x4, 0x17d61c0, 0xc03321f800, 0x0, 0x0, 0x0, 0xc01f65ee00, ...)\n\t/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/cache.go:184 +0x98\ngithub.com/caddyserver/certmagic.(*Config).CacheManagedCertificate(0xc01570c820, 0xc047fa69a8, 0x12, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, ...)\n\t/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/certificates.go:114 +0x1a5\ngithub.com/caddyserver/certmagic.(*Config).getCertDuringHandshake(0xc01570c820, 0xc008bea780, 0x300000101, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, ...)\n\t/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/handshake.go:271 +0x17a6\ngithub.com/caddyserver/certmagic.(*Config).GetCertificate(0xc01570c820, 0xc008bea780, 0x12, 0xc000205600, 0x7f959a6d2878)\n\t/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/handshake.go:66 +0x118\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ConnectionPolicy).buildStandardTLSConfig.func1(0xc008bea780, 0x410018, 0xb8, 0x1834fe0)\n\t/home/vagrant/caddy/modules/caddytls/connpolicy.go:185 +0x10f\ncrypto/tls.(*Config).getCertificate(0xc000701380, 0xc008bea780, 0xc008bea780, 0x18, 0x20)\n\t/usr/local/go/src/crypto/tls/common.go:1017 +0x3cb\ncrypto/tls.(*serverHandshakeState).processClientHello(0xc00e981968, 0xc000269380, 0x59a605)\n\t/usr/local/go/src/crypto/tls/handshake_server.go:223 +0x2c8\ncrypto/tls.(*serverHandshakeState).handshake(0xc00e981968, 0xc000b55400, 0x0)\n\t/usr/local/go/src/crypto/tls/handshake_server.go:64 +0x37\ncrypto/tls.(*Conn).serverHandshake(0xc00ab4f880, 0xc00299b6e0, 0x14)\n\t/usr/local/go/src/crypto/tls/handshake_server.go:58 +0x14b\ncrypto/tls.(*Conn).Handshake(0xc00ab4f880, 0x0, 0x0)\n\t/usr/local/go/src/crypto/tls/conn.go:1391 +0xc9\nnet/http.(*conn).serve(0xc04fa35540, 0x1bcc958, 0xc0008f5020)\n\t/usr/local/go/src/net/http/server.go:1840 +0x1a5\ncreated by net/http.(*Server).Serve\n\t/usr/local/go/src/net/http/server.go:3013 +0x39b"}
I read carefully the certmagic/cache.go code, I cannot explain how is it possible to have an empty cert.Names
I grep “subject:"” in logs from start to the panic, the only occurence is the “evicting random certificate” line (I was expecting an occurence from a “added certificate to cache” log). So it seems no badly formed certificate have been pushed to the cache in 1st place.
May be it’s related to the fact that I built caddy myself …
How I built caddy on a fresh ubuntu 18.04 VM
sudo apt-get update
sudo apt install -y gcc
# Install go
wget https://golang.org/dl/go1.16.2.linux-amd64.tar.gz
sudo tar -C /usr/local -xzf go1.16.2.linux-amd64.tar.gz
export PATH=$PATH:/usr/local/go/bin
git clone https://github.com/caddyserver/caddy.git
cd caddy
go get -d -v github.com/caddyserver/certmagic@88b8609b4d8fb8c7b1865322602606b85240c80d
cd cmd/caddy/
go build
For records I also put the 1st crash logs
syslog:
goroutine 74613350 [running]:
panic: interface conversion: interface {} is nil, not acme.Authorization
github.com/mholt/acmez.(*Client).ObtainCertificateUsingCSR(0xc024ed9788, 0x1bcc958, 0xc0156e44b0, 0xc036e2fd18, 0x5, 0xc01d01f0c0, 0x1, 0x4, 0x1, 0x0, ...)
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/acmemanager.go:315 +0x1b3
github.com/caddyserver/certmagic.(*ACMEManager).doIssue(0xc028225600, 0x1bcc958, 0xc0156e44b0, 0xc008e18fc0, 0xc021a53601, 0xc005b046a0, 0x410018, 0x100, 0x188eb80)
/home/vagrant/go/pkg/mod/github.com/mholt/acmez@v1.0.0/client.go:137 +0x1d88
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/acmemanager.go:244 +0xd6
github.com/caddyserver/certmagic.(*ACMEManager).Issue(0xc028225600, 0x1bcc958, 0xc0156e44b0, 0xc008e18fc0, 0x0, 0xc00013d4c0, 0x19)
github.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue(0xc000638ea0, 0x1bcc958, 0xc0156e44b0, 0xc008e18fc0, 0x1, 0x1, 0xc04a271900)
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/async.go:106 +0x239
github.com/caddyserver/certmagic.doWithRetry(0x1bcc920, 0xc0156e44b0, 0xc025de0d20, 0xc005b056a0, 0x1, 0x1)
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/config.go:739 +0x373
github.com/caddyserver/certmagic.(*Config).renewCert.func2(0x1bcc958, 0xc0156e44b0, 0x0, 0x0)
/home/vagrant/caddy/modules/caddytls/acmeissuer.go:234 +0xd4
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/handshake.go:614 +0xd1c
created by github.com/caddyserver/certmagic.(*Config).renewDynamicCertificate
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/handshake.go:582 +0x12b
github.com/caddyserver/certmagic.(*Config).renewDynamicCertificate.func3(0x1bcc920, 0xc027acfec0, 0xc03b71a150, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, ...)
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/config.go:643
github.com/caddyserver/certmagic.(*Config).RenewCertAsync(...)
/home/vagrant/go/pkg/mod/github.com/caddyserver/certmagic@v0.14.6-0.20210922202800-88b8609b4d8f/config.go:788 +0x445
github.com/caddyserver/certmagic.(*Config).renewCert(0xc0044d4320, 0x1bcc920, 0xc027acfec0, 0xc013822bd0, 0x14, 0x0, 0x0, 0x0)
caddy logs:
{"level":"debug","ts":1632957714.5587342,"logger":"http.handlers.file_server","msg":"sanitized path join","site_root":"/var/www/lemlist_cname_ok","request_path":"/","result":"/var/www/lemlist_cname_ok"}
{"level":"debug","ts":1632957714.558773,"logger":"http.handlers.file_server","msg":"located index file","filename":"/var/www/lemlist_cname_ok/index.html"}
{"level":"debug","ts":1632957714.558793,"logger":"http.handlers.file_server","msg":"opening file","filename":"/var/www/lemlist_cname_ok/index.html"}
{"level":"debug","ts":1632957714.5610003,"logger":"tls.handshake","msg":"choosing certificate","identifier":"custom.lemlist.com","num_choices":1}
{"level":"debug","ts":1632957714.5610418,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"custom.lemlist.com","subjects":["custom.lemlist.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"bbd009380caa15dcd0d5b4916d04f4ea597646e09dbb338b5c7ae3f4e664f1e8"}
{"level":"debug","ts":1632957714.5610566,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["custom.lemlist.com"],"managed":true,"expiration":1635596077,"hash":"bbd009380caa15dcd0d5b4916d04f4ea597646e09dbb338b5c7ae3f4e664f1e8"}
{"level":"debug","ts":1632957714.562655,"logger":"http.handlers.file_server","msg":"sanitized path join","site_root":"/var/www/lemlist_cname_ok","request_path":"/","result":"/var/www/lemlist_cname_ok"}
{"level":"debug","ts":1632957714.5627108,"logger":"http.handlers.file_server","msg":"located index file","filename":"/var/www/lemlist_cname_ok/index.html"}
{"level":"debug","ts":1632957714.5627244,"logger":"http.handlers.file_server","msg":"opening file","filename":"/var/www/lemlist_cname_ok/index.html"}
{"level":"debug","ts":1632957714.564746,"logger":"tls.handshake","msg":"choosing certificate","identifier":"trail.lemlist.com","num_choices":1}
{"level":"debug","ts":1632957714.5647938,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"trail.lemlist.com","subjects":["trail.lemlist.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"8184623789b794200d766df624c4b3a1b94ce92057f0ba2c47da846111bfb332"}
{"level":"debug","ts":1632957714.5648077,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["trail.lemlist.com"],"managed":true,"expiration":1635596077,"hash":"8184623789b794200d766df624c4b3a1b94ce92057f0ba2c47da846111bfb332"}
{"level":"debug","ts":1632957714.5663855,"logger":"http.handlers.file_server","msg":"sanitized path join","site_root":"/var/www/lemlist_cname_ok","request_path":"/","result":"/var/www/lemlist_cname_ok"}
{"level":"debug","ts":1632957714.5664387,"logger":"http.handlers.file_server","msg":"located index file","filename":"/var/www/lemlist_cname_ok/index.html"}
{"level":"debug","ts":1632957714.5664504,"logger":"http.handlers.file_server","msg":"opening file","filename":"/var/www/lemlist_cname_ok/index.html"}
{"level":"debug","ts":1632957714.6416004,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42100","request":{"remote_addr":"141.101.68.0:11840","proto":"HTTP/2.0","method":"OPTIONS","host":"app.lemlist.com","uri":"/api/linkedin/updateUser","headers":{"Sec-Fetch-Mode":["cors"],"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-Dest":["empty"],"X-Forwarded-Proto":["https"],"Origin":["chrome-extension://khnbclggeggefodgimdekejhipkeobnc"],"Accept-Language":["fr,en;q=0.9,fr-FR;q=0.8,en-US;q=0.7"],"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip"],"Cf-Ipcountry":["FR"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Access-Control-Request-Headers":["content-type"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.61 Safari/537.36"],"Cf-Connecting-Ip":["2a01:cb00:3e8:7500:74d4:179:5a51:8372"],"X-Forwarded-For":["2a01:cb00:3e8:7500:74d4:179:5a51:8372, 141.101.68.135"],"Cf-Ray":["6968f3546c533b13-CDG"],"Accept":["*/*"],"Access-Control-Request-Method":["POST"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"app.lemlist.com"}},"headers":{"Content-Type":["application/json"],"Access-Control-Allow-Headers":["*"],"Access-Control-Allow-Origin":["*"],"Date":["Wed, 29 Sep 2021 23:21:54 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["2"]},"status":200}
{"level":"debug","ts":1632957714.6615615,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42100","request":{"remote_addr":"3.88.135.0:57638","proto":"HTTP/1.1","method":"POST","host":"api.lemlist.com","uri":"/api/unsubscribes/msturdivant%40needld.org","headers":{"User-Agent":["Zapier"],"Authorization":["Basic dGVhX2FOeEM2YzdTZGhjbWJaRkw4OmM1MmJkNjQwZDc0ZGJjNzk4MjNlMTNmZjgwM2E4ZDAw"],"Accept":["*/*"],"Content-Length":["0"],"Accept-Encoding":["gzip,deflate"],"X-Forwarded-For":["3.88.135.41"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"api.lemlist.com"}},"headers":{"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["97"],"Retry-After":["2"],"X-Ratelimit-Limit":["20"],"X-Ratelimit-Remaining":["19"],"X-Ratelimit-Reset":["Thu Sep 30 2021 01:21:56 GMT+0200 (Central European Summer Time)"],"Content-Type":["application/json"],"Date":["Wed, 29 Sep 2021 23:21:54 GMT"]},"status":200}
{"level":"debug","ts":1632957714.666391,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42160","request":{"remote_addr":"104.28.94.0:12822","proto":"HTTP/1.1","method":"GET","host":"trail.subkit.co","uri":"/api/track/open/usr_jEKd39rHekHWyg9xk/tsk_aYRWtcNjiMyAAY69d","headers":{"X-Forwarded-For":["104.28.94.168"],"Accept":["image/webp,image/png,image/svg+xml,image/*;q=0.8,video/*;q=0.8,*/*;q=0.5"],"Accept-Language":["en-US,en;q=0.9"],"X-Forwarded-Proto":["http"],"Accept-Encoding":["gzip, deflate"],"User-Agent":["Mozilla/5.0"]}},"headers":{"Keep-Alive":["timeout=5"],"Content-Length":["42"],"Content-Type":["image/gif"],"Date":["Wed, 29 Sep 2021 23:21:54 GMT"],"Connection":["keep-alive"]},"status":200}
{"level":"debug","ts":1632957714.7614925,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42160","request":{"remote_addr":"66.102.7.0:52132","proto":"HTTP/1.1","method":"GET","host":"trail.summercollabs.com","uri":"/api/reply/data-ll-tsk_vdTBHbLBuSmzrcytY","headers":{"X-Forwarded-For":["66.102.7.82"],"X-Forwarded-Proto":["http"],"User-Agent":["Mozilla/5.0 (Windows NT 5.1; rv:11.0) Gecko Firefox/11.0 (via ggpht.com GoogleImageProxy)"],"Accept-Encoding":["gzip, deflate, br"]}},"headers":{"Date":["Wed, 29 Sep 2021 23:21:54 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["42"],"Content-Type":["image/gif"]},"status":200}
{"level":"debug","ts":1632957714.7891092,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42160","request":{"remote_addr":"146.112.163.0:31964","proto":"HTTP/1.1","method":"GET","host":"track.betterthanaletter.co","uri":"/api/reply/data-ll-tsk_R5W3z42rwibrSNnY6","headers":{"X-Forwarded-For":["146.112.163.34"],"X-Forwarded-Proto":["http"],"Pragma":["no-cache"],"Cache-Control":["no-cache"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) HeadlessChrome/90.0.4430.212 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Accept-Encoding":["gzip, deflate"]}},"headers":{"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["42"],"Content-Type":["image/gif"],"Date":["Wed, 29 Sep 2021 23:21:54 GMT"]},"status":200}
{"level":"debug","ts":1632957714.9001927,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42100","request":{"remote_addr":"141.101.68.0:11840","proto":"HTTP/2.0","method":"POST","host":"app.lemlist.com","uri":"/api/linkedin/updateUser","headers":{"Cdn-Loop":["cloudflare"],"Cf-Ipcountry":["FR"],"X-Forwarded-For":["2a01:cb00:3e8:7500:74d4:179:5a51:8372, 141.101.68.135"],"Cf-Ray":["6968f3549c6e3b13-CDG"],"Content-Length":["5080"],"Sec-Ch-Ua":["\"Chromium\";v=\"94\", \"Google Chrome\";v=\"94\", \";Not A Brand\";v=\"99\""],"Origin":["chrome-extension://khnbclggeggefodgimdekejhipkeobnc"],"Accept-Encoding":["gzip"],"X-Forwarded-Proto":["https"],"Accept":["application/json"],"Sec-Ch-Ua-Platform":["\"macOS\""],"Sec-Fetch-Site":["cross-site"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.61 Safari/537.36"],"Sec-Fetch-Dest":["empty"],"Accept-Language":["fr,en;q=0.9,fr-FR;q=0.8,en-US;q=0.7"],"Cf-Connecting-Ip":["2a01:cb00:3e8:7500:74d4:179:5a51:8372"],"Content-Type":["application/json"],"Sec-Fetch-Mode":["cors"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"app.lemlist.com"}},"headers":{"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["2"],"Content-Type":["application/json"],"Access-Control-Allow-Headers":["*"],"Access-Control-Allow-Origin":["*"],"Date":["Wed, 29 Sep 2021 23:21:54 GMT"]},"status":200}
{"level":"debug","ts":1632957714.9680083,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42140","request":{"remote_addr":"66.102.7.0:39262","proto":"HTTP/1.1","method":"GET","host":"trail.summercollabs.com","uri":"/api/files/Files/fil_LAAbat2tpdxyz6Lg9.png","headers":{"X-Forwarded-For":["66.102.7.82"],"X-Forwarded-Proto":["http"],"User-Agent":["Mozilla/5.0 (Windows NT 5.1; rv:11.0) Gecko Firefox/11.0 (via ggpht.com GoogleImageProxy)"],"Accept-Encoding":["gzip, deflate, br"]}},"headers":{"Content-Length":["55482"],"X-Content-Type-Options":["nosniff"],"Access-Control-Allow-Origin":["*"],"Content-Type":["image/png"],"Date":["Wed, 29 Sep 2021 23:21:54 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"]},"status":200}
{"level":"debug","ts":1632957715.1272316,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42140","request":{"remote_addr":"20.53.104.0:13378","proto":"HTTP/1.1","method":"GET","host":"track.luckemasks.com","uri":"/favicon.ico","headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36"],"Accept":["*/*"],"Referer":["http://track.luckemasks.com/api/t/c/usr_tv6BfosizmjxEKRcb/tsk_kuxuosEgnNnAt5gLo/ZW5jX1UyRn"],"Accept-Encoding":["gzip, deflate"],"Accept-Language":["en-US,en;q=0.9"],"X-Forwarded-For":["20.53.104.64"],"X-Forwarded-Proto":["http"]}},"headers":{"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["DENY"],"Content-Security-Policy":["default-src 'self' blob: https://zapier.com https://*.zapier.com https://*.linkedin.com https://chefsimon.co https://*.hotjar.com;"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"]},"status":404}
{"level":"debug","ts":1632957715.216518,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42140","request":{"remote_addr":"67.247.235.0:52520","proto":"HTTP/1.1","method":"GET","host":"trail.macproductsusa.co","uri":"/api/image-templates/itp_2ndXvWPAdGhmQLnfG/lea_vAXa3xm5fAr69f9Pv?t=1632941597056&r=9ay5QYHiscdobc3AC","headers":{"X-Forwarded-For":["67.247.235.149"],"Accept":["image/webp,image/png,image/svg+xml,image/*;q=0.8,video/*;q=0.8,*/*;q=0.5"],"Accept-Language":["en-us"],"X-Forwarded-Proto":["http"],"Accept-Encoding":["gzip, deflate"],"User-Agent":["Mozilla/5.0 (iPhone; CPU iPhone OS 14_7_1 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Mobile/15E148"]}},"headers":{"Access-Control-Allow-Origin":["*"],"Content-Type":["image/jpeg"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["56466"]},"status":200}
{"level":"debug","ts":1632957715.2320747,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42160","request":{"remote_addr":"67.247.235.0:52521","proto":"HTTP/1.1","method":"GET","host":"trail.macproductsusa.co","uri":"/api/reply/data-ll-tsk_jzpsRmPgMxBQDJSSB","headers":{"Accept":["image/webp,image/png,image/svg+xml,image/*;q=0.8,video/*;q=0.8,*/*;q=0.5"],"Accept-Language":["en-us"],"X-Forwarded-Proto":["http"],"Accept-Encoding":["gzip, deflate"],"User-Agent":["Mozilla/5.0 (iPhone; CPU iPhone OS 14_7_1 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Mobile/15E148"],"X-Forwarded-For":["67.247.235.149"]}},"headers":{"Date":["Wed, 29 Sep 2021 23:21:55 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["42"],"Content-Type":["image/gif"]},"status":200}
{"level":"debug","ts":1632957715.2842534,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42100","request":{"remote_addr":"35.175.221.0:41316","proto":"HTTP/1.1","method":"GET","host":"api.lemlist.com","uri":"/api/unsubscribes/msturdivant%40needld.org","headers":{"Authorization":["Basic dGVhX2FOeEM2YzdTZGhjbWJaRkw4OmM1MmJkNjQwZDc0ZGJjNzk4MjNlMTNmZjgwM2E4ZDAw"],"Accept":["*/*"],"Accept-Encoding":["gzip,deflate"],"X-Forwarded-For":["35.175.221.227"],"X-Forwarded-Proto":["https"],"User-Agent":["Zapier"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"api.lemlist.com"}},"headers":{"X-Ratelimit-Reset":["Thu Sep 30 2021 01:21:56 GMT+0200 (Central European Summer Time)"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"],"Keep-Alive":["timeout=5"],"Content-Length":["64"],"Retry-After":["1.353"],"X-Ratelimit-Limit":["20"],"X-Ratelimit-Remaining":["18"],"Content-Type":["application/json"],"Connection":["keep-alive"]},"status":200}
{"level":"debug","ts":1632957715.288194,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42160","request":{"remote_addr":"67.247.235.0:52522","proto":"HTTP/1.1","method":"GET","host":"trail.macproductsusa.co","uri":"/api/track/open/usr_nD5DBZ8bKN4TzR8xi/tsk_jzpsRmPgMxBQDJSSB","headers":{"X-Forwarded-Proto":["http"],"Accept-Encoding":["gzip, deflate"],"User-Agent":["Mozilla/5.0 (iPhone; CPU iPhone OS 14_7_1 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Mobile/15E148"],"X-Forwarded-For":["67.247.235.149"],"Accept":["image/webp,image/png,image/svg+xml,image/*;q=0.8,video/*;q=0.8,*/*;q=0.5"],"Accept-Language":["en-us"]}},"headers":{"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["42"],"Content-Type":["image/gif"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"]},"status":200}
{"level":"debug","ts":1632957715.2888951,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/(devel) CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["19998790"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["354"],"Content-Type":["application/json"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/19998790/649314478"],"Replay-Nonce":["0001llc0uGe6j3tJc_MV8emEdRZl1gOoBdu0LfSdPpURGeA"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
{"level":"debug","ts":1632957715.3359973,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42140","request":{"remote_addr":"67.247.235.0:52523","proto":"HTTP/1.1","method":"GET","host":"trail.macproductsusa.co","uri":"/api/froala/files/tea_omWQhMPnbLhiiadDb-63c0af79455b937d7734f85cc21e03d8","headers":{"User-Agent":["Mozilla/5.0 (iPhone; CPU iPhone OS 14_7_1 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Mobile/15E148"],"X-Forwarded-For":["67.247.235.149"],"Accept":["image/webp,image/png,image/svg+xml,image/*;q=0.8,video/*;q=0.8,*/*;q=0.5"],"Accept-Language":["en-us"],"X-Forwarded-Proto":["http"],"Accept-Encoding":["gzip, deflate"]}},"headers":{"Content-Type":["image/png"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Content-Length":["1442"],"X-Content-Type-Options":["nosniff"],"Access-Control-Allow-Origin":["*"]},"status":200}
{"level":"debug","ts":1632957715.3950064,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:42140","request":{"remote_addr":"20.53.104.0:13379","proto":"HTTP/1.1","method":"GET","host":"track.luckemasks.com","uri":"/favicon.ico","headers":{"X-Forwarded-For":["20.53.104.64"],"X-Forwarded-Proto":["http"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36"],"Accept":["*/*"],"Referer":["http://track.luckemasks.com/api/t/c/usr_tv6BfosizmjxEKRcb/tsk_kuxuosEgnNnAt5gLo/ZW5jX1UyRn"],"Accept-Encoding":["gzip, deflate"],"Accept-Language":["en-US,en;q=0.9"]}},"headers":{"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["DENY"],"Content-Security-Policy":["default-src 'self' blob: https://cdn.jsdelivr.net/gh/froala/design-blocks@master/screenshots http://*.google-analytics.com https://*.google-analytics.com https://zapier.com https://*.zapier.com https://*.linkedin.com https://chefsimon.co https://*.hotjar.com;"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"]},"status":404}
{"level":"debug","ts":1632957715.4222934,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/596702288","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/(devel) CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["19998790"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["106"],"Content-Type":["application/problem+json"],"Date":["Wed, 29 Sep 2021 23:21:55 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0001O5Ia0UYSzC-MsEbCSCI-g4IM5UrzB98keBeLXYOGFCs"],"Server":["nginx"]},"status_code":404}
{"level":"info","ts":1632957715.4223874,"logger":"tls.renew","msg":"releasing lock","identifier":"lemtrail.statrys.com"}
The panic seems to be coming from here:
and that should always be set as an Authorization type if the authorization is Invalid. But it’s nil. Hmm.
Are there any logs that say “added certificate to cache” where the “subjects” field is an empty array []? That could be helpful.
Hello,
nop.
I was also expecting this, but nothing, and I grep all logs from start to panic.
only occurence of *subjects":[] is the line I already pasted.
Odd. I will look into this more after the weekend.
Edit: Some other things came up, but this is still high on my list. Haven’t forgotten.
Has this error occurred again? I looked into it a little bit but wasn’t able to find an obvious code path that would cause this.
Hello, thanks for taking time to dig into the issue!
It did not happened again since then…
