There is a strange epmd caddy zombie process and I have no idea how to find out what is causing it. Nor how to debug it and it is driving me crazy. Can anyone help?
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
caddy 6033 0.0 0.0 0 0 ? Zs 12:00 0:00 [epmd] <defunct>
v2.8.4
I downloaded caddy binary with cloudflare and crowdsec modules from here Download Caddy, then I followed step by step install guide from static binaries here Install — Caddy Documentation including creating of caddy user and systemd scripts.
Hetzner CAX31 Ampere aarch64 Cloud VPS with Ubuntu 24.04 LTS
It is starting through systemd so normally i use only this for regular maintanance
sudo vi /etc/caddy/Caddyfile
sudo caddy fmt -w /etc/caddy/Caddyfile
sudo caddy validate --config /etc/caddy/Caddyfile
sudo systemctl stop/start/reload/restart caddy.service
##########GLOBAL OPTIONS##########
acme_ca https://acme-v02.api.letsencrypt.org/directory
acme_dns cloudflare ****************************************
email name.surname@example.com
http_port 80
https_port 443
crowdsec {
api_url http://localhost:8080
api_key ****************************************
ticker_interval 15s
log default {
output stdout
format json
exclude http.log.access
roll_size 1gb
roll_keep 5
roll_keep_for 720h
##########PHP APPS##########
www.example1.com {
redir * https://example1.com{uri}
www.example2.com {
redir * https://example2.com{uri}
example1.com {
root * /srv/www/clients/example1.com/html/
Strict-Transport-Security max-age=63072000
X-Frame-Options "SAMEORIGIN"
Permissions-Policy "accelerometer=(), ambient-light-sensor=(), autoplay=(), battery=(), camera=(), cross-origin-isolated=(), display-capture=(), document-domain=(), encrypted-media=(), execution-while-not-rendered=(), execution-while-out-of-viewport=(), fullscreen=(), geolocation=(), gyroscope=(), keyboard-map=(), magnetometer=(), microphone=(), midi=(), navigation-override=(), payment=(), picture-in-picture=(), publickey-credentials-get=(), screen-wake-lock=(), sync-xhr=(), usb=(), web-share=(), xr-spatial-tracking=(), clipboard-read=(), clipboard-write=(), gamepad=(), speaker-selection=(), conversion-measurement=(), focus-without-user-activation=(), hid=(), idle-detection=(), interest-cohort=(), serial=(), sync-script=(), trust-token-redemption=(), window-placement=(), vertical-scroll=()"
Referrer-Policy "strict-origin"
Expect-CT "max-age=604800"
output file /srv/www/clients/example1.com/logs/caddy_access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
php_fastcgi unix//var/run/php/php8.3-fpm.sock
encode {
zstd
gzip
example2.com {
root * /srv/www/clients/example2.com/html/
output file /srv/www/clients/example2.com/logs/caddy_access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
encode {
zstd
gzip
db.example.com {
redir * https://db.example.com:8443{uri}
https://db.example.com:8443 {
output file /srv/www/admin/db.example.com/logs/caddy_access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
root * /srv/www/admin/db.example.com/html
X-Robots-Tag "noindex,nofollow"
encode {
zstd
gzip
https://nextcloud.example.com:8443 {
output file /srv/www/admin/nextcloud.example.com/logs/caddy_access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
encode zstd gzip
root * /srv/www/admin/nextcloud.example.com/html/
redir /.well-known/carddav /remote.php/dav/ 301
redir /.well-known/caldav /remote.php/dav/ 301
redir /.well-known/* /index.php{uri} 301 # Nextcloud front-controller handles routes to /.well-known
redir /remote/* /remote.php{uri} 301
redir /.well-known/webfinger /index.php/.well-known/webfinger 301
redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
Strict-Transport-Security max-age=31536000
Permissions-Policy interest-cohort=()
X-Frame-Options SAMEORIGIN
Referrer-Policy no-referrer
X-Robots-Tag: "noindex,nofollow"
X-Permitted-Cross-Domain-Policies none
X-Powered-By
php_fastcgi unix//var/run/php/php8.3-fpm.sock {
env front_controller_active true
env modHeadersAvailable true
@forbidden {
path /build/* /tests/* /config/* /lib/* /3rdparty/* /templates/* /data/*
path /.* /autotest* /occ* /issue* /indie* /db_* /console*
not path /.well-known/*
error @forbidden 404
@immutable {
path *.css *.js *.mjs *.svg *.gif *.png *.jpg *.ico *.wasm *.tflite
query v=*
header @immutable Cache-Control "max-age=15778463, immutable"
@static {
not query v=*
header @static Cache-Control "max-age=15778463"
@woff2 path *.woff2
header @woff2 Cache-Control "max-age=604800"
##########DOCKER###########
portainer.example.com {
redir * https://portainer.example.com:8443{uri}
https://portainer.example.com:8443 {
output file /srv/www/admin/portainer.example.com/logs/caddy_access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
reverse_proxy localhost:9000
analytics.example.com {
output file /srv/www/admin/analytics.example.com/logs/caddy_access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
reverse_proxy localhost:8000
N/A
