I am running a Django website using gunicorn in a container. I installed Caddy on the (Ubuntu) host and made a reverse proxy to the container
This works for my website, and it looks nice, however I use django-bootstrap and I see it loads the css etc from a url. When I go to the Admin interface though, there is no styling and Firefox reports:
The resource from “http://e6b1.ts.net/static/admin/css/base.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
The resource from “http://e6b1.ts.net/static/admin/js/nav_sidebar.js” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
The resource from “http://e6b1.ts.net/static/admin/css/dark_mode.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
The resource from “http:/e6b1.ts.net/static/admin/css/nav_sidebar.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
The resource from “http:/e6b1.ts.net/static/admin/css/dashboard.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
The resource from “http://e6b1.ts.net/static/admin/js/theme.js” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
Loading failed for the <script> with source “http://e6b1.ts.net/static/admin/js/theme.js”. admin:9:43
The resource from “http://e6b1.ts.net/static/admin/css/responsive.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
The resource from “http://e6b1.ts.net/static/admin/css/nav_sidebar.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
The resource from “http://e6b1.ts.net/static/admin/css/dashboard.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
admin
sudo apt install caddy
Ubuntu 24.04
Django runs in a podman container with gunicorn
sudo systemctl start caddy
rnaseqtracker:
build:
context: .
dockerfile: Containerfile
container_name: rnaseqtracker
- 127.0.0.1:8000:8000
- ./db:/app/db
# domain name.
#root * /usr/share/caddy
#file_server
reverse_proxy localhost:8000
# php_fastcgi localhost:9000
This is a relevant section of my Django config:
STATIC_URL = 'static/'
STATIC_ROOT = Path(BASE_DIR, STATIC_URL)
I have tried several things on the caddy side, but nothing seems to work. I do find the static folder in the root of my website inside the container, but perhaps caddy does not know how to reach it?
