Hello, first post and complete noob here - sorry in advance for stating the obvious or for not providing enough information - I’m a designer, not a sysadmin!
I’m looking to set up a web server with an Amazon Linux EC2 machine but I’m stuck. Starting with a fresh instance and SSH’d in, I managed to get as far as:
sudo su curl https://getcaddy.com | bash
bash returned caddy: command not found
I confirmed the location of caddy with whereis
then did setcap cap_net_bind_service=+ep /usr/local/bin/caddy
Now I’m not sure where to go from here especially as the caddy command is not registered.
I’m tempted by Apache simply because it seems I can just use yum install httpd to get going. My end goal is to get Wordpress on my server but I had a recommendation for Caddy and also understand its advantages over existing solutions, including Apache and nginx. It would be great to receive some guidance with getting this set up as I’m bemused by the currently available information.
I’m trying to understand the Caddyfile documentation and now I’m really lost, haha. I’ll have to find more time to really understand this - right now, I’m just looking for a quick solution.
Hey Nik, thanks for trying Caddy! And sorry for the trouble; I don’t really have documentation for sysadmin-related tasks on purpose, since that varies widely based on the system, owner, etc.
To be able to run Caddy from anywhere, make sure /usr/local/bin is in your $PATH:
echo $PATH
If you see /usr/local/bin as one of the elements in the output, then you should be able to run caddy stand-alone and it will serve the current working directory. That should be all it takes to get Caddy installed.
You’re right that yum install httpd will get Apache up and running, but not PHP and MySQL. And same for Caddy, you’ll have to install PHP and MySQL separately if you want to run WordPress. Try this tutorial by @DenBeke for help with that!
You’ll be happy to know that we’re working on a web UI that should simplify some of these tasks for designers (and other less-technical users) and make it pretty intuitive.
