I tried to proxy directly from a domain to the server IP, adding tcp/ infront of the final proxy location, … but it would always refuse to work - is there any way to achieve what sslh does with caddy v2 reverse proxying?
Awesome to hear, though from that I assume there is no way on caddy “yet” and it’s in its early steps so far, so not anytime soon even if reached with the sponsor goal?
Not trying to belittle it, just trying to understand if that’s a feature-set soon to be expected (assuming sponsor goal reached) or if it is a giant sub-project in itself that needs a lot more time, as I lack the understanding of the task size.
Nah, it’s still new, but it’s fully functional. I’m already multiplexing TLS, SSH, and HTTP with it. Sponsors are already using it, too. I hope you’ll consider sponsoring, then you can use it right away! It’ll also help accelerate development and make it better.
Thanks for clarifying! though for me personally the sponsor entry level tier is too high to afford and I was more curious if I was just doing something wrong for it to not work.
