Perhaps a non-issue but hoping somebody can advise about some behaviour I’m seeing with a Windows machine running Caddy v2.0.
I’m using Caddy as a reverse proxy for ~10 sites, however I’ve recently noticed that attempts to browse to my server via either it’s public IP address, or a hostname that points to it (but has no site defined in Caddy) returns an SSL error. The sites that are defined work perfectly fine, so it’s not a huge issue. I’m just wondering about the exception handling for somebody that might hit my server some other way.
Is this expected behaviour? I’m sure it used to do something more graceful when running v1?
PS C:\Caddy> .\caddy version
As a Windows service, using NSSM
Windows 10 v10.0.18362
nssm start caddy
N/A
Apologies for domain obfuscation but not really relevant to the issue.
# Site 1
site.1 {
output file C:/Caddy/logs/caddy.log
reverse_proxy http://localhost:8080 {
# Site 2
site.2 {
reverse_proxy http://localhost:7878 {
header_up X-Real-IP {http.request.remote}
header_up X-Forwarded-Proto {http.request.scheme}
header_up X-Forwarded-Ssl {on}
# Site 3
site.3 {
reverse_proxy http://localhost:8989 {
# Site 4
site.4 {
reverse_proxy http://localhost:5000 {
# Site 5
site.5 {
reverse_proxy http://localhost:8181 {
# Site 6
site.6 {
reverse_proxy https://localhost:4443 {
tls
tls_insecure_skip_verify
read_buffer 8192
# Site 7
site.7 {
reverse_proxy http://192.168.1.200 {
rewrite / /admin
# Site 8
site.8 {
reverse_proxy http://localhost:32400 {
# Site 9
site.9 {
reverse_proxy http://192.168.1.200:8020 {
# Site 10
site.10 {
reverse_proxy http://192.168.1.200:8050 {
# Site 11
site.11 {
reverse_proxy http://192.168.1.200:8060 {
rewrite / /cgi-bin/smokeping.cgi{uri}
# www redirect
www.site.12 {
redir https://site.12
If somebody hits my server with an HTTP request using either my public IP address or some other domain that points to my IP but isn’t defined in my Caddy File, then the request seems to be upgraded to HTTPS and the browser returns an HTTPS error. I’m almost certain before I upgraded to v2.0 that the web server handled this gracefully and returned a ‘Site doesn’t exist at this address’ error or something similar?
e.g. in Edge Chromium - ERR_SSL_PROTOCOL_ERROR
Not much, as I don’t really know where to start. Unsure how to extract logging from Windows machine for an undefined site?
N/A
