SSL handshake failed Error code 525 for multiple cloudflare subdomains
I’ve been using caddy for several years as a reverse proxy.
I’ve recently bought a cloudflare domain and want to move my current pages from my ddns provider to subdomains in my cloudflare domain.
Cloudflare has all subdomains added as CNAMES to a single A entry smythstreet.com pointing to my current IP.
Cloudflare is setup with Full (not strict) SSL, cloudflare proxy enabled.
Oddly only one subdomain reverse proxy is working.
The arr.smythstreet.com subdomain is working for all paths, but any other subdomains receive the following error via browser:
They’re all setup the same in cloudflare so I’m unsure what’s wrong. Can you not use an API token for multiple subdomains?
Via Curl
curl -svo /dev/null https://ha.smythstreet.com --connect-to ::122.199.45.55 2>&1 | egrep -v "^{.*$|^}.*$|^* http.*$"
* Connecting to hostname: 122.199.45.55
*   Trying 122.199.45.55:443...
* Connected to (nil) (122.199.45.55) port 443 (#0)
* ALPN: offers h2,http/1.1
*  CApath: /etc/ssl/certs
* OpenSSL/3.0.13: error:0A000438:SSL routines::tlsv1 alert internal error
* Closing connection 0
My working subdomain
curl -svo /dev/null https://arr.smythstreet.com/radarr --connect-to ::122.199.45.55 2>&1 | egrep -v "^{.*$|^}.*$|^* http.*$"
* ALPN: server accepted h2
*  subject: CN=arr.smythstreet.com
*  start date: Aug 16 10:17:06 2024 GMT
*  expire date: Nov 14 10:17:05 2024 GMT
*  subjectAltName: host "arr.smythstreet.com" matched cert's "arr.smythstreet.com"
*  issuer: C=US; O=Let's Encrypt; CN=E5
Installed caddy as an LXC ttek script.
Followed
https://caddyserver.com/docs/build#package-support-files-for-custom-builds-for-debianubunturaspbian
to add a new custom build with cloudflare and dynamic dns checker added.
Proxmox Virtual Environment 8.2.4
Running as LXC container under Debian 12.
sudo systemctl start caddy
N/A
	email david.ratten@gmail.com
	dynamic_dns {
		provider cloudflare {env.CLOUDFLARE_AUTH_TOKEN}
		domains {
			smythstreet.com
		check_interval 15m
		versions ipv4
daveflix2.ddns.net {
		output file /var/log/caddy/jelly_access.log {
			roll_size 10mb # Set max size 10 MB
			roll_local_time # use local time in logs
			roll_keep 4 # Keep at most 4 log files
			roll_keep_for 1080h # Keep log files for 45 days
	reverse_proxy 192.168.1.6:8096
arr.smythstreet.com {
		dns cloudflare {env.CLOUDFLARE_AUTH_TOKEN}
		output file /var/log/caddy/server_access.log {
	reverse_proxy /radarr* 192.168.1.63:7878
	reverse_proxy /sonarr* 192.168.1.64:8989
	reverse_proxy /lidarr* 192.168.1.65:8686
	reverse_proxy /sabnzbd* 192.168.1.60:7777
	redir /qbt /qbt/
	handle_path /qbt/* {
		reverse_proxy 192.168.1.66:8090
ha.smythstreet.com {
		output file /var/log/caddy/hass_access.log {
	reverse_proxy 192.168.1.51:8123
hasshellbound.ddns.net {
df.smythstreet.com {
		output file /var/log/caddy/nxc_access.log {
	reverse_proxy 192.168.1.61:8096
Mainly followed this guide:
But also ran through multiple other pages
https://caddy.community/t/error-525-ssl-handshake-failed/11615
https://caddy.community/t/recommendations-for-caddy-and-cloudflare-proxy/18076
As well as the GitHub repos for both custom modules
What’s in your Caddy logs? Any cert issuance errors? Which proxy mode are you using in Cloudflare for your domains? Make sure they’re the same mode as your arr. domain I guess.
Supplemental and possibly related
That’s the odd thing, there’s nothing in the caddy logs at all when a call is made.
Not sure what you mean by proxy mode sorry, the proxy status is “Proxied” for all subdomains.
I’ve now turned off the cf proxy and removed the tls section in the caddyfile and the subdomain now works, but it’s just using the regular caddy generated cert. So I’m guessing there’s a problem with how the cloudflare plugin is interacting with cf?
There’s 4 different modes. You should probably be using “Full (Strict)” mode.
Ok, SSL is set to Full (strict). I also tried it with Full but no change
