So I am trying to get a SSL cert for the Lan IP 192.168.0.101:8080 which I am using as a webdav server.
I have tried specifying the https protocol, but it checks for the certificate online, which of course, fails.
And when I try to use basic Auth for the webdave server over Lan, window’s 10 is unable to connect as the server supposedly is rejecting the connection.
You can’t get valid SSL for a private IP address via ACME. (You’ll be hard-pressed to get valid SSL for an IP address, period.)
You will need to specify your certificate (tls cert key) or use a self-signed one (tls self_signed).
As of a few releases ago, SNI mismatch will result in Caddy causing a TLS error by refusing to send a certificate. That means that a provided certificate must have the hostname you’re using over LAN (e.g. 192.168.0.101) as one of its names; or, for a self-signed certificate, that hostname must be the site label.
