1. Output of caddy version
a. System environment: Docker
I run with docker-compose
version: '3'
image: caddy:alpine
hostname: caddy
- 443:443
104.237.252.57 {
root * /usr/share/caddy
It generates certificate for my IP Address, but it’s only valid for one day:
Subject Alternative Names: IP Address:104.237.252.57
Valid From: November 28, 2022
Valid To: November 28, 2022
I checked the issued certificate in /data
from Certificate Decoder - Decode certificates to view their contents.
{"level":"info","ts":1669661966.5556698,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["104.237.252.57"]}
{"level":"info","ts":1669661966.5573916,"logger":"tls.obtain","msg":"acquiring lock","identifier":"104.237.252.57"}
{"level":"info","ts":1669661966.5604575,"logger":"tls.obtain","msg":"lock acquired","identifier":"104.237.252.57"}
{"level":"info","ts":1669661966.5610628,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"104.237.252.57"}
{"level":"info","ts":1669661966.5824776,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1669661966.5829363,"msg":"serving initial configuration"}
{"level":"info","ts":1669661966.5917335,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"104.237.252.57"}
{"level":"info","ts":1669661966.5918114,"logger":"tls.obtain","msg":"releasing lock","identifier":"104.237.252.57"}
{"level":"warn","ts":1669661966.592534,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [104.237.252.57]: no OCSP server specified in certificate","identifiers":["104.237.252.57"]}
I tried using zerossl-bot
but no luck.
