I used debug mode in Node to see what it says when trying to fetch()
api proxied by Caddy:
FetchError: request to https://caddy/api/auth/prepared-signup failed, reason: write EPROTO 104003B8FFFF0000:error:0A000438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1584:SSL alert number 80
at ClientRequest.<anonymous> (/app/.yarn/cache/@remix-run-web-fetch-npm-4.2.0-c89374c10b-ecd91b6942.zip/node_modules/@remix-run/web-fetch/src/fetch.js:111:11)
at ClientRequest.emit (node:events:513:28)
at TLSSocket.socketErrorListener (node:_http_client:494:9)
at TLSSocket.emit (node:events:513:28)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3)
at processTicksAndRejections (node:internal/process/task_queues:82:21)
In the same time, looking at the full Caddy log, I cannot see any requests to prepared-signup
. Ideas?
Attaching to bot_caddy_1
caddy_1 | {"level":"info","ts":1663122125.7924685,"msg":"using provided configuration","config_file":"/etc/caddy/.caddyfile","config_adapter":"caddyfile"}
caddy_1 | {"level":"warn","ts":1663122125.7933064,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/.caddyfile","line":17}
caddy_1 | {"level":"info","ts":1663122125.7937667,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy_1 | {"level":"info","ts":1663122125.7938762,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x40003d4310"}
caddy_1 | {"level":"info","ts":1663122125.7997603,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy_1 | {"level":"info","ts":1663122125.799777,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy_1 | {"level":"warn","ts":1663122125.8075402,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
caddy_1 | {"level":"info","ts":1663122125.8077123,"msg":"Warning: \"certutil\" is not available, install \"certutil\" with \"apt install libnss3-tools\" or \"yum install nss-tools\" and try again"}
caddy_1 | {"level":"info","ts":1663122125.8077157,"msg":"define JAVA_HOME environment variable to use the Java trust"}
caddy_1 | {"level":"info","ts":1663122125.825468,"msg":"certificate installed properly in linux trusts"}
caddy_1 | {"level":"debug","ts":1663122125.8256543,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
caddy_1 | {"level":"debug","ts":1663122125.8256783,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
caddy_1 | {"level":"info","ts":1663122125.8256807,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["bot.127.0.0.1.nip.io"]}
caddy_1 | {"level":"info","ts":1663122125.8256876,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy_1 | {"level":"warn","ts":1663122125.8325648,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [bot.127.0.0.1.nip.io]: no OCSP server specified in certificate","identifiers":["bot.127.0.0.1.nip.io"]}
caddy_1 | {"level":"debug","ts":1663122125.8325808,"logger":"tls.cache","msg":"added certificate to cache","subjects":["bot.127.0.0.1.nip.io"],"expiration":1663155366,"managed":true,"issuer_key":"local","hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7","cache_size":1,"cache_capacity":10000}
caddy_1 | {"level":"info","ts":1663122125.8344803,"logger":"tls","msg":"finished cleaning storage units"}
caddy_1 | {"level":"info","ts":1663122125.8365893,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy_1 | {"level":"info","ts":1663122125.8366196,"msg":"serving initial configuration"}
caddy_1 | {"level":"info","ts":1663122125.8371675,"logger":"watcher","msg":"watching config file for changes","config_file":"/etc/caddy/.caddyfile"}
caddy_1 | {"level":"debug","ts":1663122147.6842191,"logger":"tls.handshake","msg":"choosing certificate","identifier":"bot.127.0.0.1.nip.io","num_choices":1}
caddy_1 | {"level":"debug","ts":1663122147.6842763,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"bot.127.0.0.1.nip.io","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"issuer_key":"local","hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122147.6842895,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"expiration":1663155366,"hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122147.686909,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.21.0.1:62560: remote error: tls: unknown certificate"}
caddy_1 | {"level":"debug","ts":1663122147.6911447,"logger":"tls.handshake","msg":"choosing certificate","identifier":"bot.127.0.0.1.nip.io","num_choices":1}
caddy_1 | {"level":"debug","ts":1663122147.6913388,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"bot.127.0.0.1.nip.io","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"issuer_key":"local","hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122147.6914988,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"expiration":1663155366,"hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122147.6942685,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"web:3000","total_upstreams":1}
caddy_1 | {"level":"debug","ts":1663122147.7962182,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"caddy"}
caddy_1 | {"level":"debug","ts":1663122147.7962415,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*"}
caddy_1 | {"level":"debug","ts":1663122147.7962444,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","sni":"caddy"}
caddy_1 | {"level":"debug","ts":1663122147.7962477,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","server_name":"caddy","remote":"172.21.0.6:50984","identifier":"caddy","cipher_suites":[4866,4867,4865,49199,49195,49200,49196,158,49191,103,49192,107,163,159,52393,52392,52394,49327,49325,49315,49311,49245,49249,49239,49235,162,49326,49324,49314,49310,49244,49248,49238,49234,49188,106,49187,64,49162,49172,57,56,49161,49171,51,50,157,49313,49309,49233,156,49312,49308,49232,61,60,53,47,255],"cert_cache_fill":0.0001,"load_if_necessary":true,"obtain_if_necessary":true,"on_demand":false}
caddy_1 | {"level":"debug","ts":1663122147.7962894,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.21.0.6:50984: no certificate available for 'caddy'"}
caddy_1 | {"level":"debug","ts":1663122147.8304703,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"web:3000","duration":0.136091333,"request":{"remote_ip":"172.21.0.1","remote_port":"62562","proto":"HTTP/2.0","method":"GET","host":"bot.127.0.0.1.nip.io","uri":"/signup","headers":{"Accept-Language":["en-AU,en;q=0.7"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"],"Sec-Fetch-Mode":["navigate"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-Host":["bot.127.0.0.1.nip.io"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Site":["cross-site"],"Accept-Encoding":["gzip, deflate, br"],"X-Forwarded-For":["172.21.0.1"],"Sec-Gpc":["1"],"Sec-Fetch-Dest":["document"],"Cache-Control":["max-age=0"],"X-Forwarded-Proto":["https"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"bot.127.0.0.1.nip.io"}},"headers":{"Content-Type":["text/html; charset=utf-8"],"Vary":["Accept-Encoding"],"Content-Encoding":["gzip"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"],"Date":["Wed, 14 Sep 2022 02:22:27 GMT"]},"status":500}
caddy_1 | {"level":"debug","ts":1663122147.8534358,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"web:3000","total_upstreams":1}
caddy_1 | {"level":"debug","ts":1663122147.860412,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"web:3000","duration":0.006924917,"request":{"remote_ip":"172.21.0.1","remote_port":"62562","proto":"HTTP/2.0","method":"GET","host":"bot.127.0.0.1.nip.io","uri":"/favicon.ico","headers":{"X-Forwarded-Proto":["https"],"Sec-Fetch-Mode":["no-cors"],"Referer":["https://bot.127.0.0.1.nip.io/signup"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"X-Forwarded-For":["172.21.0.1"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36"],"Accept-Language":["en-AU,en;q=0.7"],"X-Forwarded-Host":["bot.127.0.0.1.nip.io"],"Sec-Fetch-Dest":["image"],"Sec-Gpc":["1"],"Sec-Fetch-Site":["same-origin"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"bot.127.0.0.1.nip.io"}},"headers":{"Accept-Ranges":["bytes"],"Content-Encoding":["gzip"],"Keep-Alive":["timeout=5"],"Cache-Control":["public, max-age=3600"],"Etag":["W/\"423e-18313800ab0\""],"Date":["Wed, 14 Sep 2022 02:22:27 GMT"],"Connection":["keep-alive"],"Vary":["Accept-Encoding"],"Last-Modified":["Tue, 06 Sep 2022 15:51:42 GMT"],"Content-Type":["image/x-icon"]},"status":200}
caddy_1 | {"level":"debug","ts":1663122986.481453,"logger":"tls.handshake","msg":"choosing certificate","identifier":"bot.127.0.0.1.nip.io","num_choices":1}
caddy_1 | {"level":"debug","ts":1663122986.4817808,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"bot.127.0.0.1.nip.io","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"issuer_key":"local","hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122986.4817975,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"expiration":1663155366,"hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122986.4878454,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.21.0.1:62568: remote error: tls: unknown certificate"}
caddy_1 | {"level":"debug","ts":1663122986.4913292,"logger":"tls.handshake","msg":"choosing certificate","identifier":"bot.127.0.0.1.nip.io","num_choices":1}
caddy_1 | {"level":"debug","ts":1663122986.4913647,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"bot.127.0.0.1.nip.io","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"issuer_key":"local","hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122986.4915278,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"expiration":1663155366,"hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663122986.4976053,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"web:3000","total_upstreams":1}
caddy_1 | {"level":"debug","ts":1663122986.5097258,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"web:3000","duration":0.012050333,"request":{"remote_ip":"172.21.0.1","remote_port":"62570","proto":"HTTP/2.0","method":"GET","host":"bot.127.0.0.1.nip.io","uri":"/favicon.ico","headers":{"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["bot.127.0.0.1.nip.io"],"Sec-Fetch-Mode":["no-cors"],"X-Forwarded-For":["172.21.0.1"],"Sec-Fetch-Dest":["image"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-AU,en;q=0.9,ru;q=0.8"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Sec-Gpc":["1"],"Sec-Fetch-Site":["cross-site"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"bot.127.0.0.1.nip.io"}},"headers":{"Cache-Control":["public, max-age=3600"],"Content-Encoding":["gzip"],"Keep-Alive":["timeout=5"],"Accept-Ranges":["bytes"],"Last-Modified":["Tue, 06 Sep 2022 15:51:42 GMT"],"Etag":["W/\"423e-18313800ab0\""],"Date":["Wed, 14 Sep 2022 02:36:26 GMT"],"Connection":["keep-alive"],"Content-Type":["image/x-icon"],"Vary":["Accept-Encoding"]},"status":200}
caddy_1 | {"level":"debug","ts":1663123063.6596324,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.21.0.1:62574: remote error: tls: unknown certificate"}
caddy_1 | {"level":"debug","ts":1663123063.6643908,"logger":"tls.handshake","msg":"choosing certificate","identifier":"bot.127.0.0.1.nip.io","num_choices":1}
caddy_1 | {"level":"debug","ts":1663123063.6644871,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"bot.127.0.0.1.nip.io","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"issuer_key":"local","hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663123063.6645117,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["bot.127.0.0.1.nip.io"],"managed":true,"expiration":1663155366,"hash":"0ef46b5984c6479b13203f4ffa24af98d83fcc47ebb9c844898379a04af487e7"}
caddy_1 | {"level":"debug","ts":1663123063.6716216,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"web:3000","total_upstreams":1}
caddy_1 | {"level":"debug","ts":1663123063.7725623,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"caddy"}
caddy_1 | {"level":"debug","ts":1663123063.7725844,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*"}
caddy_1 | {"level":"debug","ts":1663123063.7725878,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","sni":"caddy"}
caddy_1 | {"level":"debug","ts":1663123063.7725909,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","server_name":"caddy","remote":"172.21.0.6:50998","identifier":"caddy","cipher_suites":[4866,4867,4865,49199,49195,49200,49196,158,49191,103,49192,107,163,159,52393,52392,52394,49327,49325,49315,49311,49245,49249,49239,49235,162,49326,49324,49314,49310,49244,49248,49238,49234,49188,106,49187,64,49162,49172,57,56,49161,49171,51,50,157,49313,49309,49233,156,49312,49308,49232,61,60,53,47,255],"cert_cache_fill":0.0001,"load_if_necessary":true,"obtain_if_necessary":true,"on_demand":false}
caddy_1 | {"level":"debug","ts":1663123063.7727156,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.21.0.6:50998: no certificate available for 'caddy'"}
caddy_1 | {"level":"debug","ts":1663123063.8098497,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"web:3000","duration":0.138129333,"request":{"remote_ip":"172.21.0.1","remote_port":"62576","proto":"HTTP/2.0","method":"GET","host":"bot.127.0.0.1.nip.io","uri":"/signup","headers":{"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-Dest":["document"],"Accept-Language":["en-AU,en;q=0.7"],"Accept-Encoding":["gzip, deflate, br"],"Cache-Control":["max-age=0"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Mode":["navigate"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"],"Sec-Gpc":["1"],"Sec-Fetch-User":["?1"],"X-Forwarded-For":["172.21.0.1"],"X-Forwarded-Host":["bot.127.0.0.1.nip.io"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"bot.127.0.0.1.nip.io"}},"headers":{"Date":["Wed, 14 Sep 2022 02:37:43 GMT"],"Keep-Alive":["timeout=5"],"Content-Type":["text/html; charset=utf-8"],"Content-Encoding":["gzip"],"Connection":["keep-alive"],"Vary":["Accept-Encoding"]},"status":500}
caddy_1 | {"level":"debug","ts":1663123063.8343945,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"web:3000","total_upstreams":1}
caddy_1 | {"level":"debug","ts":1663123063.8380742,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"web:3000","duration":0.003623458,"request":{"remote_ip":"172.21.0.1","remote_port":"62576","proto":"HTTP/2.0","method":"GET","host":"bot.127.0.0.1.nip.io","uri":"/favicon.ico","headers":{"X-Forwarded-For":["172.21.0.1"],"X-Forwarded-Host":["bot.127.0.0.1.nip.io"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["no-cors"],"Accept-Language":["en-AU,en;q=0.7"],"Sec-Fetch-Dest":["image"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Sec-Gpc":["1"],"Referer":["https://bot.127.0.0.1.nip.io/signup"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"bot.127.0.0.1.nip.io"}},"headers":{"Last-Modified":["Tue, 06 Sep 2022 15:51:42 GMT"],"Content-Type":["image/x-icon"],"Keep-Alive":["timeout=5"],"Connection":["keep-alive"],"Vary":["Accept-Encoding"],"Content-Encoding":["gzip"],"Date":["Wed, 14 Sep 2022 02:37:43 GMT"],"Accept-Ranges":["bytes"],"Cache-Control":["public, max-age=3600"],"Etag":["W/\"423e-18313800ab0\""]},"status":200}
