SSL ERROR UNRECOGNIZED NAME ALERT when trying to use https
I have recently changed modem and now I have a new public IP. After this I changed where my domain name is pointing and now I am getting a “SSL_ERROR_UNRECOGNIZED_NAME_ALERT” error when trying to load my pages.
*   Trying 184.170.81.72:443...
* Connected to jellyfin.nathans.live (184.170.81.72) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Unknown (21):
* TLSv1.3 (IN), TLS alert, unrecognized name (624):
* error:0A000458:SSL routines::tlsv1 unrecognized name
* Closing connection 0
curl: (35) error:0A000458:SSL routines::tlsv1 unrecognized name
Ubuntu 22.04.4 LTS (This is the Server edition of Ubuntu)
I am using the Caddy file, so the only command I use is
systemctl restart caddy
https://jellyfin.nathans.live {
     php_fastcgi unix//run/php/php8.2-fpm.sock
     reverse_proxy :8096
https://browser.nathans.live {
     reverse_proxy :3000
Hi @Nathan5471,
I am unable to connect to the site as it would seem a firewall is filtering Ports 80 & 443.
$ nmap -Pn -p80,443 jellyfin.nathans.live
Starting Nmap 7.80 ( https://nmap.org ) at 2024-05-21 01:11 UTC
Nmap scan report for jellyfin.nathans.live (184.170.81.72)
Host is up.
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.49 seconds
Thanks, it seems that the default firewall setting is medium. I will change that in the morning.
Hi @Nathan5471,
Presently I am seeing Port 80 & 443 Open. :slight_smile:
Starting Nmap 7.80 ( https://nmap.org ) at 2024-05-21 20:36 UTC
Host is up (0.094s latency).
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 0.54 seconds
Side note: I am not sure the proper HTTP Response Codes are being used.
Here is what I see using curl. If others say different than what I’ve said, I suggest following their advice over mine.
Here I would have thought a HTTP Response Code of 301
$ curl -i http://jellyfin.nathans.live/
HTTP/1.1 308 Permanent Redirect
Connection: close
Server: Caddy
Date: Tue, 21 May 2024 20:44:35 GMT
Content-Length: 0
Here too I would have thought a HTTP Response Code of 301
$ curl -i https://jellyfin.nathans.live/
HTTP/2 302
alt-svc: h3=":443"; ma=2592000
date: Tue, 21 May 2024 20:44:41 GMT
server: Caddy
server: Kestrel
content-length: 0
This seems fine to me.
$ curl -Ii https://jellyfin.nathans.live/web/
HTTP/2 200
accept-ranges: bytes
content-type: text/html
date: Tue, 21 May 2024 20:44:45 GMT
etag: "1daa89c6396023f"
last-modified: Fri, 17 May 2024 20:54:20 GMT
server: Caddy
server: Kestrel
x-response-time-ms: 0.1615
content-length: 9279
And here is an online tool
Is it important for me to try and change any of the responses, I am mostly the only one who uses it?
@Nathan5471 probably not. Just more of a FYI.
Ok, thanks for all of the help
You are welcome @Nathan5471 :slightly_smiling_face:
This doesn’t really make sense Jellyfin isn’t PHP, so you shouldn’t have php_fastcgi in there. And either way, reverse_proxy has a higher directive order so it never runs anyway (unless you used request matchers to split the traffic apart).
Anyway, your Jellyfin seems to load just fine for me. Is there really still a problem?
I think the php thing is from when I was originally setting up the reverse proxy, I was trying things I found on the Jellyfin Forum. And my problem is solved now.
What fixed it?
The Arris Surfboard app has a section for port forwarding and when you add a rule, it doesn’t turn on port forwarding for some reason. The app does not tell you port forwarding is off, so you have to go on the web UI and turn on port forwarding.
