I’ve setup Caddy on a server running Jellyfin and Tailscale. Following this video for help: https://www.youtube.com/watch?v=Vt4PDUXB_fg.
I’ve done the following:
- Custom build caddy using xcaddy with the cloudflare dns module
- Setup domain on cloudflare
- Setup Caddyfile (pasted below)
- Run caddy, all logs look fine
It worked for a moment… the page resolved. But something changed, and now I just get ERR_CONNECTION_CLOSED. The output of curl -vL https://jellyfin.media.keencloud.co.za is: curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to jellyfin.media.keencloud.co.za:443.
The caddy run output is:
2024/11/26 14:22:26.821 INFO using config from file {"file": "/etc/caddy/Caddyfile"}
2024/11/26 14:22:26.822 INFO adapted config to JSON {"adapter": "caddyfile"}
2024/11/26 14:22:26.825 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2024/11/26 14:22:26.825 INFO http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/11/26 14:22:26.825 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0004ae780"}
2024/11/26 14:22:26.825 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2024/11/26 14:22:26.825 INFO http enabling HTTP/3 listener {"addr": ":443"}
2024/11/26 14:22:26.825 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/11/26 14:22:26.826 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2024/11/26 14:22:26.826 INFO http enabling automatic TLS certificate management {"domains": ["jellyfin.media.keencloud.co.za"]}
2024/11/26 14:22:26.826 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2024/11/26 14:22:26.826 INFO serving initial configuration
2024/11/26 14:22:26.828 INFO tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/root/.local/share/caddy", "instance": "9c7613f6-0336-4eea-b4e9-7db2324662f2", "try_again": "2024/11/27 14:22:26.828", "try_again_in": 86399.999999624}
2024/11/26 14:22:26.828 INFO tls finished cleaning storage units
v2.8.4
I used xcaddy to build a custom caddy with the cloudflare dns module.
xcaddy build \
OS: Linux Mint 22 x86_64
Host: MINI S
Kernel: 6.8.0-49-generic
CPU: Intel N100 (4) @ 3.400G
GPU: Intel Alder Lake-N [UHD
Memory: 4083MiB / 15772MiB
I run the xcaddy build with ./caddy run --config /etc/caddy/Caddyfile
(cloudflare) {
dns cloudflare token
# jellyfin
jellyfin.media.keencloud.co.za {
reverse_proxy http://127.0.0.1:8096
import cloudflare
