1. Output of caddy version
caddy:alpine
Docker on Ubuntu 20.04
version: '3.8'
# Docs ########################################################################
# https://github.com/nextcloud/docker
# Volumes #####################################################################
nextcloud_caddy_data:
external: true
nextcloud_data:
external: true
nextcloud_db_data:
external: true
# Networks ####################################################################
net:
# Services ####################################################################
# Caddy ---------------------------------------------------------------------
image: caddy:alpine
- 443:443
DOMAIN: "${DOMAIN:?DOMAIN not set}"
ADMIN_EMAIL: "${ADMIN_EMAIL:?ADMIN_EMAIL not set}"
- net
- nextcloud_caddy_data:/data
volumes_from:
- app
# Postgres ------------------------------------------------------------------
db:
image: postgres:${POSTGRES_VERSION:?POSTGRES_VERSION not set}
- net
- nextcloud_db_data:/var/lib/postgresql/data
healthcheck:
test: ["CMD-SHELL", "pg_isready -U ${POSTGRES_USER:?POSTGRES_USER not set} -d ${POSTGRES_DB:?POSTGRES_DB not set}"]
interval: 10s
timeout: 5s
retries: 5
start_period: 5s
POSTGRES_DB: ${POSTGRES_DB:?POSTGRES_DB not set}
POSTGRES_USER: ${POSTGRES_USER:?POSTGRES_USER not set}
POSTGRES_PASSWORD: ${POSTGRES_PASSWORD:?POSTGRES_PASSWORD not set}
# command:
# postgres
# -c max_connections=100
# -c shared_buffers=1GB
# -c effective_cache_size=3GB
# -c maintenance_work_mem=256MB
# -c checkpoint_completion_target=0.9
# -c wal_buffers=16MB
# -c default_statistics_target=100
# -c random_page_cost=1.1
# -c effective_io_concurrency=200
# -c work_mem=10485kB
# -c min_wal_size=2GB
# -c max_wal_size=8GB
# -c max_worker_processes=2
# -c max_parallel_workers_per_gather=1
# -c max_parallel_workers=2
# -c max_parallel_maintenance_workers=1
# Redis ---------------------------------------------------------------------
redis:
image: redis:alpine
- net
# Nextcloud -----------------------------------------------------------------
app:
image: nextcloud:${NEXTCLOUD_VERSION:?NEXTCLOUD_VERSION not set}
- net
- nextcloud_data:/var/www/html
NEXTCLOUD_TRUSTED_DOMAINS: ${DOMAIN:?DOMAIN not set}
NEXTCLOUD_ADMIN_USER: ${NEXTCLOUD_ADMIN_USER:?NEXTCLOUD_ADMIN_USER not set}
NEXTCLOUD_ADMIN_PASSWORD: ${NEXTCLOUD_ADMIN_PASSWORD:?NEXTCLOUD_ADMIN_PASSWORD not set}
REDIS_HOST: redis
POSTGRES_HOST: db
PHP_MEMORY_LIMIT: '512M'
PHP_UPLOAD_LIMIT: '16G'
TZ: 'America/SaoPaulo'
depends_on:
db:
condition: service_healthy
redis:
condition: service_started
# Cron ----------------------------------------------------------------------
cron:
- net
volumes_from:
- app
entrypoint: /cron.sh
depends_on:
db:
app:
redis:
# Collabora ---------------------------------------------------------------------
collabora:
image: collabora/code
- net
- "9980:9980"
- /etc/localtime:/etc/localtime
- /etc/timezone:/etc/timezone
- username=admin
- password=${COLLABORA_PASSWORD}
- server_name=${DOMAIN:?DOMAIN not set}
- dictionaries=en_US
- extra_params=--o:ssl.enable=true --o:ssl.termination=false # Set SSL options
cap_add:
- MKNOD
tty: true
# SSL
email {$ADMIN_EMAIL}
# Enable to see header set by upstream
{$DOMAIN} {
# Static content
root * /var/www/html
# PHP fast cgi
php_fastcgi app:9000 {
env front_controller_active true
# Redirects for DAV apps
redir /.well-known/carddav /remote.php/carddav 301
redir /.well-known/caldav /remote.php/caldav 301
respond /.well-known/acme-challenge 404
respond /.well-known/pki-validation 404
# redir /.well-known/* /index.php/.well-known/webfinger 301
# redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
redir /.well-known/* /index.php{uri} 301
# Headers
# If staging acme_ca is enabled, this needs to be commented out!
# Otherwise, it is not possible to add exception
# More security hardening headers
Referrer-Policy "no-referrer"
X-Download-Options "noopen"
X-Frame-Options "SAMEORIGIN"
X-Permitted-Cross-Domain-Policies "none"
X-Robots-Tag "none"
Permissions-Policy "interest-cohort=()"
# Remove X-Powered-By header, which is an information leak
-X-Powered-By
# Replace http with https in any Location header
Location http:// https://
# Cache control
@static {
file
header @static {
Cache-Control "max-age=360"
@fonts {
path /core/fonts
header @fonts {
Cache-Control "max-age=604800"
# gzip encoding
encode {
gzip 4
minimum_length 256
match {
header Content-Type text/*
header Content-Type application/json*
header Content-Type application/javascript*
header Content-Type application/xhtml+xml*
header Content-Type application/atom+xml*
header Content-Type application/rss+xml*
header Content-Type image/svg+xml*
header Content-Type application/ld+json*
header Content-Type application/manifest+json*
header Content-Type application/vnd.geo+json*
header Content-Type application/vnd.ms-fontobject*
header Content-Type application/x-font-ttf*
header Content-Type application/x-web-app-manifest+json*
header Content-Type application/xml*
header Content-Type font/opentype*
header Content-Type image/bmp*
header Content-Type image/x-icon*
header Content-Type text/cache-manifest*
@collabora {
path /browser/* # Loleaflet is the client part of LibreOffice Online
path /hosting/discovery # WOPI discovery URL
path /hosting/capabilities # Show capabilities as json
path /cool/* # Main websocket, uploads/downloads, presentations
reverse_proxy @collabora collabora:9980 {
header_up Host "maraujo.rio.br"
tls_insecure_skip_verify
@forbidden {
path /build/*
path /tests/*
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
path /autotest
path /issue
path /indie
path /db_
path /console
respond @forbidden 404
Caddy is not able to assign the certificate to my domain, and I am not able to find out why.
{"level":"info","ts":1659116172.3981483,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1659116172.4000545,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1659116172.401214,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
{"level":"info","ts":1659116172.4014409,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1659116172.4014585,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1659116172.403151,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00036b960"}
{"level":"info","ts":1659116172.4046707,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["maraujo.rio.br"]}
{"level":"info","ts":1659116172.4050379,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1659116172.4051213,"msg":"serving initial configuration"}
{"level":"info","ts":1659116172.4051425,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1659116172.4052994,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1659116172.4063444,"logger":"tls.obtain","msg":"acquiring lock","identifier":"maraujo.rio.br"}
{"level":"info","ts":1659116172.4073715,"logger":"tls.obtain","msg":"lock acquired","identifier":"maraujo.rio.br"}
{"level":"info","ts":1659116172.7562346,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["maraujo.rio.br"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":"dev@maraujo.rio.br"}
{"level":"info","ts":1659116172.7562716,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["maraujo.rio.br"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":"dev@maraujo.rio.br"}
{"level":"info","ts":1659116172.9021325,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"maraujo.rio.br","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"info","ts":1659116173.2747335,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"maraujo.rio.br","challenge":"http-01","remote":"18.158.72.241:36052","distributed":false}
{"level":"info","ts":1659116173.8287554,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"maraujo.rio.br","challenge":"http-01","remote":"23.178.112.107:53656","distributed":false}
{"level":"info","ts":1659116174.0030735,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"maraujo.rio.br","challenge":"http-01","remote":"52.35.116.194:13908","distributed":false}
{"level":"info","ts":1659116174.2166562,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/62634104/3416610204"}
{"level":"info","ts":1659116174.512387,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":1,"first_url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/fad197662a10617da715fbdc31efc77a8aa2"}
{"level":"info","ts":1659116174.5133917,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"maraujo.rio.br"}
{"level":"info","ts":1659116174.5134177,"logger":"tls.obtain","msg":"releasing lock","identifier":"maraujo.rio.br"}
{"level":"error","ts":1659121960.7102084,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"http2: stream closed"}
{"level":"error","ts":1659124544.342186,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"next.maraujo.rio.br","error":"no information found to solve challenge for identifier: next.maraujo.rio.br"}
{"level":"error","ts":1659124544.3422573,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"next.maraujo.rio.br","error":"no information found to solve challenge for identifier: next.maraujo.rio.br"}
curl -v
* Trying 140.82.13.234:443...
* TCP_NODELAY set
* Connected to maraujo.rio.br (140.82.13.234) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
how to fix it, please visit the web page mentioned above
I tried to configure the acme_server and tls internal inside the Caddyfile, but it didn’t work.
