SSL certificate problem: unable to get local issuer certificate on Ubuntu
I have a service reverse proxied with caddy on macOS and two clients trying to connect to it.
I get 3 certificates: root.crt, intermediate.crt, service.crt (which is leaf + intermediate).
On the macOS client (another device, not the server), I trusted root.crt in keychain access, then it works fine.
On the ubuntu client, I cannot connect to the service. I tried curl --cacert to pass several different certificates and always get the same error. curl -k works with no problem.
Combinations I’ve tried:
  • root
  • leaf + intermediate
  • leaf + intermediate + root
  • intermediate + root
curl --cacert ~/ollma.local.crt https://ollama.local:8443 -v
* Host ollama.local:8443 was resolved.
* IPv6: (none)
* IPv4: 192.168.178.48
*   Trying 192.168.178.48:8443...
* Connected to ollama.local (192.168.178.48) port 8443
*  CAfile: /home/anqi/ollma.local.crt
*  CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection
curl: (60) SSL certificate problem: unable to get local issuer certificate
v2.10.0
macOS
brew install caddy
	skip_install_trust
https://ollama.local:8443 {
	reverse_proxy 127.0.0.1:11434
	tls internal
Sorry, my bad. There is a typo that caused everything wrong. Is there any place to close the issue?
Can you share this?
echo | openssl s_client -servername ollama.local -connect 192.168.178.48:8443 2>/dev/null | sed -n '/^Certificate chain$/,/^---$/p'
I just want to see the chain your Caddy is sending
Thanks for offering the help! It’s all due to a stupid typo (how can I make it twice!).
Simply the service certificate (leaf+intermediate) works perfect now.
