SSL certificate location on Ubuntu Caddy v2
v2
I built it from source.
Ubuntu 18.04
caddy start
paste full file contents here
I am not being able to find the location where caddy stores its ssl certificates. I want my web application to use them too.
Looking in $CADDYPATH. There’s just a uuid file in there. I have searched for hidden files and folders as well.
It depends how you’re running it, based on whether you have XDG_DATA_HOME set or whatever user you run Caddy with’s HOME is set to.
Also FYI, they’re TLS certificates, SSL is the old deprecated term :wink:
Thank you so much!
