Specifying an SSL certificate for one domain breaks on demand TLS
Ubuntu 18.04.5 LTS
caddy run --environ --config /etc/caddy/Caddyfile
# caddy.service
# for your installation.
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile
  on_demand_tls {
    ask https://www.example.com/verify
  admin "0.0.0.0:2019"
  storage redis {
    host         "10.0.1.1"
    port         6379
    db           2
    key_prefix   "caddytls"
    value_prefix "caddy-storage-redis"
    timeout      5
    tls_enabled  "false"
    tls_insecure "true"
*.example.com, www.example.com, example.com {
  tls /etc/ssl/private/example.cert.pem /etc/ssl/private/example.key.pem
  reverse_proxy 10.0.0.1:80 10.0.0.2:80 10.0.0.3:80 {
    lb_policy least_conn
    health_path /status
    health_interval 10s
    health_timeout 10s
    health_path /status
    health_interval 10s
    health_timeout 10s
:443 {
  tls support@example.com  {
    on_demand
  reverse_proxy 10.0.0.1:80 10.0.0.2:80 10.0.7.3:80 {
    health_path /status
    health_interval 10s
    health_timeout 10s
My main site certificate works as expected. However, on demand TLS certificates are never requested and no log messages printed. The configuration works in our staging environment with the exact same configuration except that instead of *.example.com, www.example.com, example.com we have *.example.com, staging.example.com.
This appears to be a repeat of this issue and this issue, but I don’t see the TLS handshake error messages in the logs.
When I make a request to a custom domain pointing to our IP I receive this error:
curl https://www.somecustomdomain.com
Requests made using HTTP work however.
I have tried simplifying my configuration as much as possible. In the config posted above I removed handle_errors blocks that I used to serve custom error pages and a couple other matchers to block bots. On demand TLS fails with or without these blocks in the config. I also tried combining the :80 and :443 blocks.
Based on the error from curl I can tell that Caddy isn’t serving my example.com certificate. Instead it recognizes that the custom domain doesn’t match this certificate and fails during the handshake.
These Github issues appear to be related to the same issue, but I am still having this problem with v2.2.1.
Issue #3004
Issue #3670
What is in the logs when you enable debug mode?
By debug mode you do mean DEBUG log level for the default log? If so, here’s the log on startup:
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: caddy.HomeDir=/var/lib/caddy
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: caddy.Version=v2.2.1
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: runtime.GOOS=linux
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: runtime.GOARCH=amd64
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: runtime.Compiler=gc
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: runtime.NumCPU=8
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: runtime.GOMAXPROCS=8
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: runtime.Version=go1.14.5
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: os.Getwd=/
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: LANG=en_US.UTF-8
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: HOME=/var/lib/caddy
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: LOGNAME=caddy
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: USER=caddy
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: INVOCATION_ID=e892a3b7bfb640d48c736f9e2f30c5f1
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: JOURNAL_STREAM=9:3237814
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8677168,"msg":"using provided configuration","config_file":"/etc/caddy/caddy.json","config_adapter":"jsonc"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8704653,"logger":"admin","msg":"admin endpoint started","address":"tcp/0.0.0.0:2019","enforce_origin":false,"origins":["0.0.0.0:2019"]}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"warn","ts":1607967367.8705032,"logger":"admin","msg":"admin endpoint on open interface; host checking disabled","address":"tcp/0.0.0.0:2019"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"debug","ts":1607967367.8711243,"logger":"caddy.storage.redis","msg":"GetConfigValue [pre]:{\"Client\":null,\"ClientLocker\":null,\"Logger\":{},\"address\":\"\",\"host\":\"10.0.1.1\",\"port\":\"6379\",\"db\":2,\"password\":\"\",\"timeout\":5,\"key_prefix\":\"caddytls\",\"value_prefix\":\"caddy-storage-redis\",\"aes_key\":\"\",\"tls_ena
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"debug","ts":1607967367.871183,"logger":"caddy.storage.redis","msg":"GetConfigValue [post]:{\"Client\":null,\"ClientLocker\":null,\"Logger\":{},\"address\":\"10.0.1.102:6379\",\"host\":\"10.0.1.1\",\"port\":\"6379\",\"db\":2,\"password\":\"\",\"timeout\":5,\"key_prefix\":\"caddytls\",\"value_prefix\":\"caddy-storage-redis\",\"aes_key\"
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8712072,"logger":"caddy.storage.redis","msg":"TLS Storage are using Redis, on 10.0.1.1:6379"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8744164,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00019c0e0"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8763702,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"*.example.com","server_name":"srv0"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8764188,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"www.example.com","server_name":"srv0"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8764448,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"example.com","server_name":"srv0"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8764656,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8765042,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"warn","ts":1607967367.8765576,"logger":"http","msg":"user server is listening on same interface as automatic HTTP->HTTPS redirects; user-configured routes might override these redirects","server_name":"srv1","interface":"tcp/:80"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"debug","ts":1607967367.878186,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"debug","ts":1607967367.878518,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8786993,"msg":"autosaved config","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.878729,"msg":"serving initial configuration"}
Dec 14 12:36:07 haproxy2.example.com caddy[23028]: {"level":"info","ts":1607967367.8803988,"logger":"tls","msg":"cleaned up storage units"}
And still no log messages are printed when clients try to connect and it fails? Re:
To clarify, by debug mode, we mean the global option:
I.e.:
I enabled debug mode. It looks like the on_demand ask URL is returning a 403 even though when I make a manual request to the verification URL using HTTPie or Curl it returns a 200. The 403s appear to be coming a response from Caddy itself because I can’t find the requests in the application logs. i.e. the verification requests are routed back through Caddy but aren’t making it all the way to the backend application, but do when I manually make the same request.
{"level":"debug","ts":1607978300.2067528,"logger":"http.stdlib","msg":"http: TLS handshake error from 62.114.32.26:50556: certificate for hostname 'validcustomdomain.com' not allowed; non-2xx status code 403 returned from https://www.example.com/verify"}
Compared to:
❯ http https://www.example.com/verify\?domain\=validcustomdomain.com
HTTP/1.1 200 OK
I figured it out the problem. The www version of our domain is behind Cloudflare. If I change the verification URL to a different subdomain (e.g. domains.example.com) which bypasses Cloudflare’s proxy the verification request succeeds and a certificate is successfully issued for the custom domain.
My guess is that the Host or Location header isn’t set properly for those verification requests so Cloudflare doesn’t know how to route the request and is returning the 403.
It’s always cloudflare :joy:
Great, thanks for following up with your findings!
