Specify TLSv1.2 cipher in JSON?
Need the TLS app to use a specific cipher for generating keys. ECDHE-RSA-AES256-GCM-SHA384 instead of what it did by default which was ECDHE-ECDSA-AES256-GCM-SHA384. Using Caddy to manage certificates for a MQTT server, and the client can only handle specific ciphers (Tasmota).
Not sure if this is something I need to worry about, but according to multiple users on Tasmota forums, it matters.
General question at this point, not an error.
installed Caddy on Ubuntu 22.04 according to official guide
Ubuntu 22.04
    "apps": {
        "http": {
            "servers": {
                "srv0": {
                    "listen": [
                        ":443"
                    "routes": [
                            "handle": [
                                    "handler": "subroute",
                                    "routes": [
                                            "handle": [
                                                    "handler": "reverse_proxy",
                                                    "upstreams": [
                                                           "dial": "127.0.0.1:38096"
                            "match": [
                                    "host": [
                                        "subdomain.example.com"
                            "terminal": true
                            "handle": [
                                    "routes": [
                                            "handle": [
                                                    "handler": "vars",
                                                    "root": "/usr/share/caddy"
                                                    "handler": "file_server",
                                                    "hide": [
                                                        "/etc/caddy/caddy.json"
                            "match": [
                                    "host": [
                                        "example.com"
                            "terminal": true
        "tls": {
                        "certificates": {
                                "automate": [
                                        "mqtt.example.com"
                        "automation": {
                                "policies": [
                                                "issuers": [{
                                                        "module": "acme",
                                                        "email": "emailaddy@gmail.com"
You’ll create a TLS connection policy:
So in your server, adjacent to “routes”, create a new tls_connection_policies key as an array with an object that sets the cipher_suites property, with an array having a value of “ECDHE_RSA_AES256_GCM_SHA384”
So that array would be in apps->http->servers->tls_connection_policies->cipher_suites.
That would affect the ciphers used in apps->tls?
And would that restrict the ciphers used in all other TLS connections?
Again, just getting started with Caddy, so my big-picture knowledge isn’t great yet.
edit tried it and got a error on restart: “building standard TLS config: unsupported cipher suite: ECDHE_RSA_AES256_GCM_SHA384”
Sorry, that’s what I get for replying on mobile.
Proper name is: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
From tls (Caddyfile directive) — Caddy Documentation (we use the IANA identifiers)
Cipher suites are determined per-handshake, so you configure this where handshakes are established; that is the connection policies. It only affects the TLS connections that use that connection policy.
That fixed it! Thanks.
I said “That fixed it” since Caddy service restarted without error. However, when I check the ciphers used after changing my caddy.json with nmap --script ssl-enum-ciphers -p 8883 mqtt.example.com it still shows
PORT     STATE SERVICE
8883/tcp open  secure-mqtt
| ssl-enum-ciphers:
|   TLSv1.2:
|     ciphers:
|       TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (ecdh_x25519) - A
|     compressors:
|       NULL
|     cipher preference: server
|_  least strength: A
Do I need to somehow force the certificates to get regenerated?
edit I manually deleted the certificates, and they regenerated after a few minutes, but cipher check still shows the same. Maybe I need to specify “rsa2048” in apps › tls › automation › policies › key_type?
Answered my own question. Yes. Specifying “rsa2048” gives me the cipher I need for Tasmota to connect to my Mosquitto broker successfully.
Yeah; Caddy can’t use a cipher suite that’s incompatible with the certificate’s cryptography. Glad you figured it out!
