SPA index disable cache
Hi!
I’m using Caddy to host SPA. Problem is: browsers are caching my index.html file. I’ve disabled caching through the Header directive and a filter on the root url + index.html
But users are accessing my SPA from various urls such as https:/domain.tld/some/thing and won’t always access the route url (https:/domain.tld/).
How can I configure a header based on the file returned (index.html) and not the url accessed ?
3. Caddy version: 2.7.6
4. How I installed and ran Caddy: docker official image
{$SERVER_NAME}
log
@spa expression `!path(
        '/', '/static/*', '/docs*', '/api*', '/login', '/logout', '/external*', '/graphql*', '/bundles*', '/contexts*', '/_profiler*', '/_wdt*',
        '*.json*', '*.html', '*.csv', '*.yml', '*.yaml', '*.xml'
    || path('/favicon.ico', '/manifest.json', '/robots.txt', '/sitemap*')`
route {
   @index {
      path /
      path /index.html
   header @index {
      Cache-Control "max-age=0, no-cache, no-store, must-revalidate"
      Pragma "no-cache"
      Expires 0
    root @spa /srv/app/front
    root * /srv/app/public
    try_files {path} /index.html
    php_fastcgi unix//var/run/php/php-fpm.sock
    encode zstd gzip
See the third example here Common Caddyfile Patterns — Caddy Documentation (but ignore the explanation, it’s backwards, my mistake which will be fixed shortly). Basically you need to wrap your try_files inside a route and put the header after it so that the condition on /index.html is checked after the rewrite.
Thank you so much! I saw the example but didn’t understand the part “index.html” would be matched after rewriting.
