Sonarr reverse proxy issues on 2.4.4
v2.4.4
Reverse proxy on a Windows box pointing various subdomains to their internal servers/services.
Windows 10, Caddy installed as a service.
nssm start caddy
N/A
sonarr.domain.tld {
		output file	C:/Caddy/logs/caddy_sonarr.log
	reverse_proxy http://localhost:8989 {
		header_up X-Real-IP {http.request.remote}
		header_up X-Forwarded-Proto {http.request.scheme}
		header_up X-Forwarded-Ssl {on}
On upgrading to Caddy v2.4.4 and trying to visit my Sonarr install via external hostname, I’m presented with a blank white page in the browser.
I am using form based authentication for Sonarr and the internal server is supposed to redirect to /login?returnUrl=/ when trying to access it unauthenticated. If I browse to this URL extension directly, then I can view the page and login. Browsing to the root sub-domain white screens.
  • If I try when already authenticated to Sonarr, it is fine.
  • If I disable authentication in Sonarr, it is fine.
  • If I revert back to v2.4.3 the problem goes away.
  • As soon as I upgrade to v2.4.4 the login page white screens and doesn’t seem to redirect correctly.
According to Caddy logs, the server is providing a blank 303 response:-
213.31.143.222 - - [01/Sep/2021:17:34:01 +0100] "GET /favicon.ico HTTP/2.0" 303 0
213.31.143.222 - - [01/Sep/2021:17:34:01 +0100] "GET / HTTP/2.0" 303 0
  • I have downgraded to 2.4.3 to resolve the problem.
  • Looked at changelogs for v2.4.4 but it isn’t clear to me if anything I am doing has been deprecated/broken in any way.
N/A
You’re likely hitting this regression which has already been fixed on master: Content-Encoding header missing with reverse-proxied chunked response · Issue #4314 · caddyserver/caddy · GitHub
Please try it out if you can!
Thanks @matt, will take a look.
@matt - installed 2.4.5 and seems to have done the trick. Thanks again.
