I’m trying to visit a SonarQube installation I have installed behind the Caddy web server. When I visit the site I don’t get a response. I’ve tried proxying 8999(secure) and 9000(unsecure) with Caddy.
Caddyfile
https://52.176.62.43 {
tls self_signed
gzip
proxy / 127.0.0.1:8999
http://52.176.62.43 {
tls off
gzip
proxy / 127.0.0.1:9000
sonar.properties
# Binding IP address. For servers with more than one IP address, this property specifies which
# address will be used for listening on the specified ports.
# By default, ports will be used on all IP addresses associated with the server.
sonar.web.host=127.0.0.1
# Web context. When set, it must start with forward slash (for example /sonarqube).
# The default value is root context (empty value).
#sonar.web.context=
# TCP port for incoming HTTP connections. Default value is 9000.
#sonar.web.port=9000
sonar.web.https.port=8999
curl
curl -I https://52.176.62.43/
curl: (7) Failed to connect to 52.176.62.43 port 443: Operation timed out
