I’m writing a custom log within caddy and, in order to rotate it, I need to restart the daemon daily (which I have configured in a logrotate file using systemctl restart caddy.service).
However, every once in a while the start part times out (even when the daemon is starting) and systemd kills the recently started caddy.
If you check the log below, at 00:01:26 systemd starts stopping caddy, and by 00:01:29 it succeeds and starts starting caddy.
Caddy actually starts and by 00:01:31 it is already handling requests.
However, systemd doesn’t seem to acknowledge this and, by 00:02:59 (90 seconds after it started) it says that the start operation timed out and sends a SIGTERM. Even when caddy does acknowledge this and shuts down, systemd doesn’t detect this and sends a SIGKILL.
Looks like systemd is loosing track of the controlled caddy process.
Apr 03 00:01:25 ep-it-010 caddy[1006405]: {"level":"info","ts":1712113285.912979,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"51.222.253.1","remote_port":"31990","proto":"HTTP/1.1","method":"GET","host":"bibliotecadigital.cin.edu.ar","uri":"/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=REVISTA&filter_field_2=subject&filter_type_2=equals&filter_value_2=CIENCIA&filter_field_3=subject&filter_type_3=equals&filter_value_3=ALIMENTOS&filter_field_4=subject&filter_type_4=equals&filter_value_4=CIN&filter_field_5=subject&filter_type_5=equals&filter_value_5=SALUD&etal=0&filtername=subject&filterquery=Conferencia+de+Rectores+de+las+Universidades+Espa%C3%B1olas+%28CRUE%29&filtertype=equals","headers":{"User-Agent":["Mozilla/5.0(compatible; AhrefsBot/7.0; +http://ahrefs.com/robot/)"],"Accept":["*/*"],"Accept-Encoding":["deflate, gzip, br"]}},"user_id":"" ,"duration":0.000102638,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://bibliotecadigital.cin.edu.ar/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=REVISTA&filter_field_2=subject&filter_type_2=equals&filter_value_2=CIENCIA&filter_field_3=subject&filter_type_3=equals&filter_value_3=ALIMENTOS&filter_field_4=subject&filter_type_4=equals&filter_value_4=CIN&filter_field_5=subject&filter_type_5=equals&filter_value_5=SALUD&etal=0&filtername=subject&filterquery=Conferencia+de+Rectores+de+las+Universidades+Espa%C3%B1olas+%28CRUE%29&filtertype=equals"],"Content-Type":[]}}
Apr 03 00:01:26 ep-it-010 caddy[1006405]: {"level":"info","ts":1712113286.5010617,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
Apr 03 00:01:26 ep-it-010 caddy[1006405]: {"level":"warn","ts":1712113286.5013669,"msg":"exiting; byeee!! <F0><9F><91><8B>","signal":"SIGTERM"}
Apr 03 00:01:26 ep-it-010 systemd[1]: Stopping Caddy...
Apr 03 00:01:26 ep-it-010 caddy[1006405]: {"level":"error","ts":1712113286.5397124,"logger":"http.log","msg":"setting HTTP/3 Alt-Svc header","error":"no port can be announced, specify it explicitly using Server.Port or Server.Addr"}
Apr 03 00:01:26 ep-it-010 caddy[1006405]: {"level":"error","ts":1712113286.6919575,"logger":"http.log","msg":"setting HTTP/3 Alt-Svc header","error":"no port can be announced, specify it explicitly using Server.Port or Server.Addr"}
Apr 03 00:01:26 ep-it-010 caddy[1006405]: {"level":"error","ts":1712113286.7689574,"logger":"http.log","msg":"setting HTTP/3 Alt-Svc header","error":"no port can be announced, specify it explicitly using Server.Port or Server.Addr"}
Apr 03 00:01:29 ep-it-010 caddy[1006405]: {"level":"error","ts":1712113289.2034917,"logger":"http.log.error.log5","msg":"dial tcp: lookup ep-wb-002.siu.edu.ar: i/o timeout","request":{"remote_ip":"85.208.96.205","remote_port":"37468","proto":"HTTP/1.1","method":"GET","host":"encuestas.siu.edu.ar","uri":"/aplicacion.php?ah=st6607021933b756.73731163&ai=kolla%7C%7C12000094","headers":{"Accept":["text/html, application/rss+xml, application/atom+xml, text/xml, text/rss+xml, application/xhtml+xml"],"Accept-Encoding":["gzip,deflate"],"Connection":["close"],"User-Agent":["Mozilla/5.0 (compatible; SemrushBot/7~bl; +http://www.semrush.com/bot.html)"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"","server_name":"encuestas.siu.edu.ar"}},"duration":3.000732449,"status":502,"err_id":"u6jsd2hih","err_trace":"reverseproxy.statusError (reverseproxy.go:1299)"}
Apr 03 00:01:29 ep-it-010 caddy[1006405]: {"level":"info","ts":1712113289.6887517,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0001ecfc0"}
Apr 03 00:01:29 ep-it-010 caddy[1006405]: {"level":"info","ts":1712113289.6890624,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Apr 03 00:01:29 ep-it-010 caddy[1006405]: {"level":"info","ts":1712113289.6891007,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
Apr 03 00:01:29 ep-it-010 systemd[1]: caddy.service: Succeeded.
Apr 03 00:01:29 ep-it-010 systemd[1]: Stopped Caddy.
Apr 03 00:01:29 ep-it-010 systemd[1]: caddy.service: Consumed 1h 28min 35.446s CPU time.
Apr 03 00:01:29 ep-it-010 systemd[1]: Starting Caddy...
Apr 03 00:01:29 ep-it-010 caddy[1015084]: caddy.HomeDir=/var/lib/caddy
Apr 03 00:01:29 ep-it-010 caddy[1015084]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Apr 03 00:01:29 ep-it-010 caddy[1015084]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Apr 03 00:01:29 ep-it-010 caddy[1015084]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Apr 03 00:01:29 ep-it-010 caddy[1015084]: caddy.Version=v2.6.4 h1:2hwYqiRwk1tf3VruhMpLcYTg+11fCdr8S3jhNAdnPy8=
Apr 03 00:01:29 ep-it-010 caddy[1015084]: runtime.GOOS=linux
Apr 03 00:01:29 ep-it-010 caddy[1015084]: runtime.GOARCH=amd64
Apr 03 00:01:29 ep-it-010 caddy[1015084]: runtime.Compiler=gc
Apr 03 00:01:29 ep-it-010 caddy[1015084]: runtime.NumCPU=8
Apr 03 00:01:29 ep-it-010 caddy[1015084]: runtime.GOMAXPROCS=8
Apr 03 00:01:29 ep-it-010 caddy[1015084]: runtime.Version=go1.20.5
Apr 03 00:01:29 ep-it-010 caddy[1015084]: os.Getwd=/
Apr 03 00:01:29 ep-it-010 caddy[1015084]: LANG=en_US.UTF-8
Apr 03 00:01:29 ep-it-010 caddy[1015084]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Apr 03 00:01:29 ep-it-010 caddy[1015084]: NOTIFY_SOCKET=/run/systemd/notify
Apr 03 00:01:29 ep-it-010 caddy[1015084]: HOME=/var/lib/caddy
Apr 03 00:01:29 ep-it-010 caddy[1015084]: LOGNAME=caddy
Apr 03 00:01:29 ep-it-010 caddy[1015084]: USER=caddy
Apr 03 00:01:29 ep-it-010 caddy[1015084]: INVOCATION_ID=117630af1d70495c9f6c5987385707db
Apr 03 00:01:29 ep-it-010 caddy[1015084]: JOURNAL_STREAM=8:155783553
Apr 03 00:01:29 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113289.8104048,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Apr 03 00:01:29 ep-it-010 caddy[1015084]: {"level":"warn","ts":1712113289.8803763,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":10}
Apr 03 00:01:29 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113289.9338868,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
Apr 03 00:01:29 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113289.9374,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00039ee00"}
Apr 03 00:01:29 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113289.9402037,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Apr 03 00:01:29 ep-it-010 caddy[1015084]: {"level":"warn","ts":1712113289.9404554,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"warn","ts":1712113290.000977,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0014095,"msg":"warning: \"certutil\" is not available, install \"certutil\" with \"apt install libnss3-tools\" or \"yum install nss-tools\" and try again"}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.001463,"msg":"define JAVA_HOME environment variable to use the Java trust"}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"error","ts":1712113290.0069468,"logger":"pki.ca.local","msg":"failed to install root certificate","error":"failed to execute sudo: exit status 1","certificate_file":"storage:pki/authorities/local/root.crt"}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0074062,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0075202,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0078375,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0081155,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0083115,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0083733,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["idear.siu.edu.ar","marcademo.siu.edu.ar","planves.siu.edu.ar","simulacionclinica.siu.edu.ar","desarrollouniv.siu.edu.ar","gestorinformes.siu.edu.ar","informacion.siu.edu.ar","sinergia.siu.edu.ar","posgradosasociados.siu.edu.ar","piesci.siu.edu.ar","abrealas.siu.edu.ar","mapadeproyectoscsu.siu.edu.ar","informacion.cin.edu.ar","contextoencierro.siu.edu.ar","portal.comunidad.siu.edu.ar","fortalecimientoext.siu.edu.ar","proyectocin.siu.edu.ar","guaranivirtual.siu.edu.ar","sied.siu.edu.ar","arfagri.siu.edu.ar","perhid-becas.siu.edu.ar","promce.siu.edu.ar","doctorados.siu.edu.ar","proyectos.marca.siu.edu.ar","proav.siu.edu.ar","esps.siu.edu.ar","kiwi.siu.edu.ar","conveniosfrance.siu.edu.ar","joomlahuarpe.siu.edu.ar","odsuniversidades.siu.edu.ar","simulacionodonto.siu.edu.ar","evc.siu.edu.ar","voluntariado.siu.edu.ar","generoydiversidad.siu.edu.ar","ies.siu.edu.ar","calchaquitest.siu.edu.ar","cytuniversidades.siu.edu.ar","calidaduniversitaria.siu.edu.ar","cuaa-dahz.siu.edu.ar","precalchaqui.siu.edu.ar","idear2017.siu.edu.ar","px00.siu.edu.ar","csuencarceles.siu.edu.ar","spusceu.siu.edu.ar","ppuaadmin.siu.edu.ar","preinscripcion.guarani.siu.edu.ar","info.siu.edu.ar","chat.siu.edu.ar","formarte.siu.edu.ar","semilla2017.siu.edu.ar","mapavoluntariado.siu.edu.ar","mundou.siu.edu.ar","unagranlibertadmas.siu.edu.ar","ofertasuperior.siu.edu.ar","demogestor.siu.edu.ar","disenioydesarrollo.siu.edu.ar","xn--diseoydesarrollo-9tb.siu.edu.ar","proun.siu.edu.ar","ed-wb-002-forodocker.siu.edu.ar","practicaseducativas.siu.edu.ar","cargaconveniosfrance.siu.edu.ar","estudiarenargentina.siu.edu.ar","rtfsimulador.siu.edu.ar","eei-desarrollo.siu.edu.ar","sipes.siu.edu.ar","pueep.siu.edu.ar","csucontextosdeprivacion.siu.edu.ar","200.123.128.68","compromisosocialuniv.siu.edu.ar","culturaysociedad.siu.edu.ar","laboratoriosremotos.siu.edu.ar","nube.cin.edu.ar","universidadydesarrollo.siu.edu.ar","forocultural.siu.edu.ar","autogestion.guarani.siu.edu.ar","prombiogen.siu.edu.ar","idear2014.siu.edu.ar","agregandovalor.siu.edu.ar","snraregistro.siu.edu.ar","perhid-becas.cin.edu.ar","protocolos2019.siu.edu.ar","registrograduados.siu.edu.ar","usc.siu.edu.ar","cienciaytecnologia.siu.edu.ar","bancodeevaluadores.cin.edu.ar","siu.edu.ar","siac.siu.edu.ar","disenoydesarrollo.siu.edu.ar","graduadosuniversitarios.siu.edu.ar","conveniospu.siu.edu.ar","nochedelareforma.siu.edu.ar","fortalecimientoosc.siu.edu.ar","111mil.siu.edu.ar","sicerconsulta.siu.edu.ar","marca.siu.edu.ar","csu.siu.edu.ar","cpres.siu.edu.ar","sacau.siu.edu.ar","gestion.guarani.siu.edu.ar","universocial.siu.edu.ar","doblecarrera.siu.edu.ar","calchaqui.siu.edu.ar","www.siu.edu.ar","encuestas.siu.edu.ar","guarani.siu.edu.ar","nomina.siu.edu.ar","cafp.siu.edu.ar","postgradosasociados.siu.edu.ar","extension.siu.edu.ar","innovacionsocial.siu.edu.ar","sirvat.siu.edu.ar","infraestructura.siu.edu.ar","172.27.100.240","redesemprendedoras.siu.edu.ar","sigamosestudiando.siu.edu.ar","inscripciones.siu.edu.ar","perhid-redes.siu.edu.ar","kollaspu.siu.edu.ar","querandies.siu.edu.ar","moodlevinculacion.siu.edu.ar","csucontextosvulnerables.siu.edu.ar","genero.siu.edu.ar","infosiu.siu.edu.ar","titulosoficiales.siu.edu.ar","pedidosciie.siu.edu.ar","api-app.guarani.siu.edu.ar","kollacin.siu.edu.ar","demo.guarani.siu.edu.ar","bibliotecadigital.cin.edu.ar","toba-usuarios.guarani.siu.edu.ar","fortalecimientovt.siu.edu.ar","normativa.cin.edu.ar","acompaniarsinide.siu.edu.ar","ppua.siu.edu.ar","studyinargentina.siu.edu.ar","spupedidos.siu.edu.ar","emprendedorismo.siu.edu.ar"]}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.0885773,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"51.222.253.4","remote_port":"21964","proto":"HTTP/1.1","method":"GET","host":"bibliotecadigital.cin.edu.ar","uri":"/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=EDUCACI%C3%93N&filter_field_2=author&filter_type_2=equals&filter_value_2=Garc%C3%ADa+de+Fanelli%2C+Ana+Mar%C3%ADa&filter_field_3=subject&filter_type_3=equals&filter_value_3=CALIDAD+DE+LA+EDUCACI%C3%93N&filter_field_4=subject&filter_type_4=equals&filter_value_4=EMISION+DE+TITULOS&filter_field_5=subject&filter_type_5=equals&filter_value_5=ENSENANZA+EN+EL+EXTRANJERO&etal=0&filtername=subject&filterquery=ESTUDIOS+DE+POSTGRADO&filtertype=equals","headers":{"User-Agent":["Mozilla/5.0 (compatible; AhrefsBot/7.0; +http://ahrefs.com/robot/)"],"Accept":["*/*"],"Accept-Encoding":["deflate, gzip, br"]}},"user_id":"","duration":0.000122208,"size":0,"status":308,"resp_headers":{"Content-Type":[],"Server":["Caddy"],"Connection":["close"],"Location":["https://bibliotecadigital.cin.edu.ar/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=EDUCACI%C3%93N&filter_field_2=author&filter_type_2=equals&filter_value_2=Garc%C3%ADa+de+Fanelli%2C+Ana+Mar%C3%ADa&filter_field_3=subject&filter_type_3=equals&filter_value_3=CALIDAD+DE+LA+EDUCACI%C3%93N&filter_field_4=subject&filter_type_4=equals&filter_value_4=EMISION+DE+TITULOS&filter_field_5=subject&filter_type_5=equals&filter_value_5=ENSENANZA+EN+EL+EXTRANJERO&etal=0&filtername=subject&filterquery=ESTUDIOS+DE+POSTGRADO&filtertype=equals"]}}
Apr 03 00:01:30 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113290.1191974,"logger":"tls","msg":"finished cleaning storage units"}
Apr 03 00:01:31 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113291.9665122,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"51.222.253.16","remote_port":"31214","proto":"HTTP/1.1","method":"GET","host":"bibliotecadigital.cin.edu.ar","uri":"/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=EDUCACI%C3%93N&filter_field_2=author&filter_type_2=equals&filter_value_2=Labont%C3%A9%2C+Huguette&filter_field_3=dateIssued&filter_type_3=equals&filter_value_3=1993&filter_field_4=subject&filter_type_4=equals&filter_value_4=COSTA+RICA&filter_field_5=subject&filter_type_5=equals&filter_value_5=ARGENTINA&filter_field_6=subject&filter_type_6=equals&filter_value_6=AM%C3%89RICA+DEL+NORTE&etal=0&filtername=subject&filterquery=ECUADOR&filtertype=equals","headers":{"User-Agent":["Mozilla/5.0 (compatible; AhrefsBot/7.0; +http://ahrefs.com/robot/)"],"Accept":["*/*"],"Accept-Encoding":["deflate, gzip, br"]}},"user_id":"","duration":0.000106944,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://bibliotecadigital.cin.edu.ar/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=EDUCACI%C3%93N&filter_field_2=author&filter_type_2=equals&filter_value_2=Labont%C3%A9%2C+Huguette&filter_field_3=dateIssued&filter_type_3=equals&filter_value_3=1993&filter_field_4=subject&filter_type_4=equals&filter_value_4=COSTA+RICA&filter_field_5=subject&filter_type_5=equals&filter_value_5=ARGENTINA&filter_field_6=subject&filter_type_6=equals&filter_value_6=AM%C3%89RICA+DEL+NORTE&etal=0&filtername=subject&filterquery=ECUADOR&filtertype=equals"],"Content-Type":[]}}
<SNIP>
Apr 03 00:02:56 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113376.6805432,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"51.222.253.13","remote_port":"51438","proto":"HTTP/1.1","method":"GET","host":"bibliotecadigital.cin.edu.ar","uri":"/handle/123456789/2198/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=author&filter_type_1=equals&filter_value_1=Correa%2C+Mar%C3%ADa+Laura&filter_field_2=author&filter_type_2=equals&filter_value_2=Higa%2C+Diego&filter_field_3=author&filter_type_3=equals&filter_value_3=Morales%2C+Mariana&filter_field_4=subject&filter_type_4=equals&filter_value_4=SOFTWARE+PARA+UNIVERSIDADES&filter_field_5=subject&filter_type_5=equals&filter_value_5=INTEROPERABILIDAD&etal=0&filtername=dateIssued&filterquery=2016&filtertype=equals","headers":{"Accept-Encoding":["deflate, gzip, br"],"User-Agent":["Mozilla/5.0 (compatible; AhrefsBot/7.0; +http://ahrefs.com/robot/)"],"Accept":["*/*"]}},"user_id":"","duration":0.000101577,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://bibliotecadigital.cin.edu.ar/handle/123456789/2198/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=author&filter_type_1=equals&filter_value_1=Correa%2C+Mar%C3%ADa+Laura&filter_field_2=author&filter_type_2=equals&filter_value_2=Higa%2C+Diego&filter_field_3=author&filter_type_3=equals&filter_value_3=Morales%2C+Mariana&filter_field_4=subject&filter_type_4=equals&filter_value_4=SOFTWARE+PARA+UNIVERSIDADES&filter_field_5=subject&filter_type_5=equals&filter_value_5=INTEROPERABILIDAD&etal=0&filtername=dateIssued&filterquery=2016&filtertype=equals"],"Content-Type":[]}}Apr 03 00:02:58 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113378.2061694,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"51.222.253.10","remote_port":"48444","proto":"HTTP/1.1","method":"GET","host":"bibliotecadigital.cin.edu.ar","uri":"/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=author&filter_type_1=equals&filter_value_1=Lafforgue+%28dir.%29&filter_field_2=subject&filter_type_2=equals&filter_value_2=ACREDITACI%C3%93N+INSTITUCIONES&filter_field_3=subject&filter_type_3=equals&filter_value_3=CALIDAD+DE+LA+EDUCACI%C3%93N&etal=0&filtername=subject&filterquery=DOCENCIA&filtertype=equals","headers":{"Accept-Encoding":["deflate, gzip, br"],"User-Agent":["Mozilla/5.0 (compatible; AhrefsBot/7.0; +http://ahrefs.com/robot/)"],"Accept":["*/*"]}},"user_id":"","duration":0.000096715,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://bibliotecadigital.cin.edu.ar/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=author&filter_type_1=equals&filter_value_1=Lafforgue+%28dir.%29&filter_field_2=subject&filter_type_2=equals&filter_value_2=ACREDITACI%C3%93N+INSTITUCIONES&filter_field_3=subject&filter_type_3=equals&filter_value_3=CALIDAD+DE+LA+EDUCACI%C3%93N&etal=0&filtername=subject&filterquery=DOCENCIA&filtertype=equals"],"Content-Type":[]}}
Apr 03 00:02:59 ep-it-010 systemd[1]: caddy.service: start operation timed out. Terminating.
Apr 03 00:02:59 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113379.8983665,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
Apr 03 00:02:59 ep-it-010 caddy[1015084]: {"level":"warn","ts":1712113379.898576,"msg":"exiting; byeee!! <F0><9F><91><8B>","signal":"SIGTERM"}
Apr 03 00:03:00 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113380.0814826,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"51.222.253.20","remote_port":"45574","proto":"HTTP/1.1","method":"GET","host":"bibliotecadigital.cin.edu.ar","uri":"/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=author&filter_type_1=equals&filter_value_1=Labont%C3%A9%2C+Huguette&filter_field_2=dateIssued&filter_type_2=equals&filter_value_2=1997&filter_field_3=subject&filter_type_3=equals&filter_value_3=AM%C3%89RICA+CENTRAL&filter_field_4=subject&filter_type_4=equals&filter_value_4=COSTA+RICA&etal=0&filtername=subject&filterquery=AM%C3%89RICA+LATINA&filtertype=equals","headers":{"Accept":["*/*"],"Accept-Encoding":["deflate, gzip, br"],"User-Agent":["Mozilla/5.0 (compatible; AhrefsBot/7.0; +http://ahrefs.com/robot/)"]}},"user_id":"","duration":0.000098032,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://bibliotecadigital.cin.edu.ar/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=author&filter_type_1=equals&filter_value_1=Labont%C3%A9%2C+Huguette&filter_field_2=dateIssued&filter_type_2=equals&filter_value_2=1997&filter_field_3=subject&filter_type_3=equals&filter_value_3=AM%C3%89RICA+CENTRAL&filter_field_4=subject&filter_type_4=equals&filter_value_4=COSTA+RICA&etal=0&filtername=subject&filterquery=AM%C3%89RICA+LATINA&filtertype=equals"],"Content-Type":[]}}
<SNIP>
Apr 03 00:03:03 ep-it-010 caddy[1015084]: {"level":"info","ts":1712113383.4083805,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"51.222.253.1","remote_port":"34018","proto":"HTTP/1.1","method":"GET","host":"bibliotecadigital.cin.edu.ar","uri":"/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=ENSE%C3%91ANZA+SUPERIOR&filter_field_2=dateIssued&filter_type_2=equals&filter_value_2=%5B1970+TO+1979%5D&filter_field_3=author&filter_type_3=equals&filter_value_3=Cea%2C+Rosa+Marta+de&filter_field_4=subject&filter_type_4=equals&filter_value_4=EDUCACI%C3%93N&etal=0&filtername=subject&filterquery=CREACI%C3%93N+DE+UNIVERSIDADES&filtertype=equals","headers":{"Accept-Encoding":["deflate, gzip, br"],"User-Agent":["Mozilla/5.0 (compatible; AhrefsBot/7.0; +http://ahrefs.com/robot/)"],"Accept":["*/*"]}},"user_id":"","duration":0.000105358,"size":0,"status":308,"resp_headers":{"Connection":["close"],"Location":["https://bibliotecadigital.cin.edu.ar/simple-search?query=&sort_by=score&order=desc&rpp=10&filter_field_1=subject&filter_type_1=equals&filter_value_1=ENSE%C3%91ANZA+SUPERIOR&filter_field_2=dateIssued&filter_type_2=equals&filter_value_2=%5B1970+TO+1979%5D&filter_field_3=author&filter_type_3=equals&filter_value_3=Cea%2C+Rosa+Marta+de&filter_field_4=subject&filter_type_4=equals&filter_value_4=EDUCACI%C3%93N&etal=0&filtername=subject&filterquery=CREACI%C3%93N+DE+UNIVERSIDADES&filtertype=equals"],"Content-Type":[],"Server":["Caddy"]}}
Apr 03 00:03:05 ep-it-010 systemd[1]: caddy.service: State 'stop-sigterm' timed out. Killing.
Apr 03 00:03:05 ep-it-010 systemd[1]: caddy.service: Killing process 1015084 (caddy) with signal SIGKILL.
Apr 03 00:03:05 ep-it-010 systemd[1]: caddy.service: Killing process 1015086 (caddy) with signal SIGKILL.
Apr 03 00:03:05 ep-it-010 systemd[1]: caddy.service: Main process exited, code=killed, status=9/KILL
Apr 03 00:03:05 ep-it-010 systemd[1]: caddy.service: Failed with result 'timeout'.
Apr 03 00:03:05 ep-it-010 systemd[1]: Failed to start Caddy.
Apr 03 00:03:05 ep-it-010 systemd[1]: caddy.service: Consumed 2.092s CPU time.
sudo apt-get install caddy
Plus, I added the transform-encoder module using caddy add-package
Debian 11 running in a proxmox VM.
systemd version 247.3-7+deb11u2
sudo systemctl start caddy.service
Actually, this daily process is triggered by the following logrotate configuration:
# Este archivo debe ir en /etc/logrotate.d
/var/log/caddy/analisis.log {
daily
rotate 60
compress
delaycompress
missingok
notifempty
create 0640 caddy caddy
sharedscripts
postrotate
sudo systemctl restart caddy.service
caddylog_404_error_report.sh /var/log/caddy/analisis.log.1 /var/log/caddy/reportes
endscript
Type=notify
PrivateDevices=yes
The full Caddyfile is so long that the forum kept rejecting my post for being over 32K chars long.
I uploaded the complete file here
email it+tls-caddy@siu.edu.ar
default_sni px00.siu.edu.ar
# snippets
(REDES_INTERNAS_EXTERNAS) {
@redes_internas {
remote_ip 172.16.0.0/12 192.168.0.0/16 100.64.0.0/10 10.0.1.0/24 10.0.2.0/23 10.0.4.0/22 10.0.8.0/21 10.0.16.0/20 10.0.32.0/19 10.0.64.0/18 10.0.128.0/17 10.1.0.0/16 10.2.0.0/15 10.4.0.0/14 10.8.0.0/13 10.16.0.0/12 10.32.0.0/11 10.64.0.0/10 10.128.0.0/9
@redes_externas {
not remote_ip 172.16.0.0/12 192.168.0.0/16 100.64.0.0/10 10.0.1.0/24 10.0.2.0/23 10.0.4.0/22 10.0.8.0/21 10.0.16.0/20 10.0.32.0/19 10.0.64.0/18 10.0.128.0/17 10.1.0.0/16 10.2.0.0/15 10.4.0.0/14 10.8.0.0/13 10.16.0.0/12 10.32.0.0/11 10.64.0.0/10 10.128.0.0/9
(LOG_ANALISIS) {
output file /var/log/caddy/analisis.log {
roll_disabled
format transform `{ts},{request>remote_ip},{request>host},{request>uri},method:{request>method},proto:{request>proto},status:{status},size:{size},referer:{request>headers>Referer},user-agent:{request>headers>User-Agent}` {
time_format "rfc3339"
(LOG_FLAT) {
output file /var/log/caddy/caddy-access.log
format transform `{request>remote_ip} - {request>host} - [{ts}] - {request>headers>User-Agent} "{request>method} {request>uri} {request>proto}" status:{status} size:{size} referer:{request>headers>Referer}` {
time_format "common_log"
(LOG_FLAT_NOBLOCK) {
output file /var/log/caddy/noblock-caddy-access.log
px00.siu.edu.ar,
200.123.128.68:80,
200.123.128.68,
172.27.100.240:80,
172.27.100.240 {
redir https://www.siu.edu.ar/
import LOG_ANALISIS
siu.edu.ar {
redir https://www.siu.edu.ar{uri}
import LOG_ANALISIS
infosiu.siu.edu.ar,
info.siu.edu.ar {
redir https://www.siu.edu.ar/infosiu permanent
import LOG_ANALISIS
inscripciones.siu.edu.ar {
redir https://www.siu.edu.ar/eventos permanent
import LOG_ANALISIS
estudiarenargentina.siu.edu.ar,
studyinargentina.siu.edu.ar {
redir https://estudia-en-argentina.com.ar permanent
import LOG_ANALISIS
encuestas.siu.edu.ar,
kollacin.siu.edu.ar,
kollaspu.siu.edu.ar {
reverse_proxy ep-wb-002.siu.edu.ar
import LOG_ANALISIS
www.siu.edu.ar,
joomlahuarpe.siu.edu.ar,
portal.comunidad.siu.edu.ar {
reverse_proxy ep-wb-003.siu.edu.ar
import LOG_ANALISIS
firmadigital.siu.edu.ar {
import REDES_INTERNAS_EXTERNAS
reverse_proxy @redes_internas ep-wb-003.siu.edu.ar
redir @redes_externas https://www.siu.edu.ar/
import LOG_ANALISIS
guarani.siu.edu.ar {
import LOG_ANALISIS
gestion.guarani.siu.edu.ar {
reverse_proxy daldoelectico.siu.edu.ar:7271
import LOG_ANALISIS
autogestion.guarani.siu.edu.ar {
reverse_proxy daldoelectico.siu.edu.ar:7272
import LOG_ANALISIS
preinscripcion.guarani.siu.edu.ar {
reverse_proxy daldoelectico.siu.edu.ar:7273
import LOG_ANALISIS
api-app.guarani.siu.edu.ar {
reverse_proxy daldoelectico.siu.edu.ar:7274
import LOG_ANALISIS
toba-usuarios.guarani.siu.edu.ar {
redir https://gestion.guarani.siu.edu.ar/toba_usuarios/03201{uri}
import LOG_ANALISIS
demo.guarani.siu.edu.ar {
import LOG_ANALISIS
infraestructura.siu.edu.ar,
querandies.siu.edu.ar {
reverse_proxy ep-wb-006.siu.edu.ar
import LOG_ANALISIS
pedidosciie.siu.edu.ar {
reverse_proxy ep-wb-001.siu.edu.ar
import LOG_ANALISIS
cpres.siu.edu.ar {
reverse_proxy ep-wb-008.siu.edu.ar
import LOG_ANALISIS
ppua.siu.edu.ar,
ppuaadmin.siu.edu.ar {
reverse_proxy ep-wb-009.siu.edu.ar
import LOG_ANALISIS
cafp.siu.edu.ar,
proyectos.marca.siu.edu.ar,
sicerconsulta.siu.edu.ar {
reverse_proxy ep-wb-013.siu.edu.ar
import LOG_ANALISIS
bibliotecadigital.cin.edu.ar {
reverse_proxy agnito.siu.edu.ar
import LOG_ANALISIS
informacion.cin.edu.ar,
informacion.siu.edu.ar,
acompaniarsinide.siu.edu.ar,
spupedidos.siu.edu.ar {
reverse_proxy lechuga.siu.edu.ar
import LOG_ANALISIS
conveniosfrance.siu.edu.ar,
cargaconveniosfrance.siu.edu.ar {
import LOG_ANALISIS
guaranivirtual.siu.edu.ar {
import LOG_ANALISIS
moodlevinculacion.siu.edu.ar {
import LOG_ANALISIS
normativa.cin.edu.ar,
http://normativa.siu.edu.ar {
reverse_proxy ep-wb-012.siu.edu.ar
import LOG_ANALISIS
posgradosasociados.siu.edu.ar,
postgradosasociados.siu.edu.ar {
import LOG_ANALISIS
graduadosuniversitarios.siu.edu.ar {
redir https://registrograduados.siu.edu.ar{uri}
import LOG_ANALISIS
titulosoficiales.siu.edu.ar {
redir https://sipes.siu.edu.ar/buscar_titulos.php
import LOG_ANALISIS
sied.siu.edu.ar {
redir https://sipes.siu.edu.ar/consulta_sied.php
import LOG_ANALISIS
sirvat.siu.edu.ar {
redir https://sipes.siu.edu.ar{uri}
import LOG_ANALISIS
bancodeevaluadores.cin.edu.ar,
calchaqui.siu.edu.ar,
conveniospu.siu.edu.ar,
cytuniversidades.siu.edu.ar,
demogestor.siu.edu.ar,
generoydiversidad.siu.edu.ar,
marcademo.siu.edu.ar,
nomina.siu.edu.ar,
ofertasuperior.siu.edu.ar,
precalchaqui.siu.edu.ar,
registrograduados.siu.edu.ar,
rtfsimulador.siu.edu.ar,
sipes.siu.edu.ar,
snraregistro.siu.edu.ar,
spusceu.siu.edu.ar
reverse_proxy emperador.siu.edu.ar
import LOG_ANALISIS
<SNIP>
Note: redacted for LENGTH. The forum wouldn’t let me write a topic longer than 32K chars
