I've been wrestling with this issue since 8 AM, and now it's 4 AM the next day.I’m running Docuseal inside a container, along with Caddy and PostgreSQL containers for support. Docuseal is accessible, but I’m hitting a 503 Error about 30% of the time. I suspect that Caddy isn’t properly utilizing the Caddyfile, which includes a reverse proxy setup for redirecting certain requests to Apache2.
Additionally, in a moment of desperation during this troubleshooting marathon, I decided to reinstall MySQL. That’s when the errors started to escalate, leading me to believe I might have botched something with the databases, making them incompatible. Everything was running smoothly with the Caddyfile setup until my attempted MySQL “fix.” . I installed, deinstalled and tampered with a lot of Settings until I realized that I broke something in the system. Any insights or advice on where I might have gone wrong would be greatly appreciated.
When I run docker ps i get the following:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
b2ed4da4a542 caddy:latest "caddy run --config …" 3 hours ago Up 50 minutes 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp, 0.0.0.0:443->443/udp, :::443->443/udp, 2019/tcp docuseal_caddy_1
2cb7162fdf8a docuseal/docuseal:latest "/app/bin/rails serv…" 3 hours ago Up 46 minutes 0.0.0.0:3000->3000/tcp, :::3000->3000/tcp docuseal_app_1
51b44314af0c postgres:15 "docker-entrypoint.s…" 3 hours ago Up 50 minutes (healthy) 5432/tcp docuseal_postgres_1
Firstly the log file from the caddy docker:
{"level":"info","ts":1709857499.6908562,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1709857499.6920455,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1709857499.6928616,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1709857499.6930435,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1709857499.6930964,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1709857499.6931388,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000459700"}
{"level":"info","ts":1709857499.6934469,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1709857499.6934643,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1709857499.6935391,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1709857499.6936135,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"info","ts":1709857499.6938457,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1709857499.6938586,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["freepbx.staffconnect.agency","docuseal.staffconnect.agency"]}
{"level":"info","ts":1709857499.6943157,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1709857499.695106,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1709857499.6951191,"msg":"serving initial configuration"}
{"level":"error","ts":1709857507.8034132,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/templates/26","headers":{"Vnd.prefetch":["true"],"Sec-Fetch-Dest":["empty"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":[],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["cors"],"If-None-Match":["W/\"863823ebbd2b9d56879cc97a54f835f2\""],"Accept":["text/html, application/xhtml+xml"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Referer":["https://docuseal.staffconnect.agency/"],"Accept-Encoding":["gzip, deflate, br, zstd"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001531383,"status":502,"err_id":"9m72bptd6","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857508.4188697,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/","headers":{"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Referer":["https://docuseal.staffconnect.agency/"],"Cookie":[],"If-None-Match":["W/\"0986e8a65bf27fa8f219edccd21e53b9\""],"Accept":["text/html, application/xhtml+xml"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Mode":["cors"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Dest":["empty"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001125914,"status":502,"err_id":"sujkzytqa","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857512.4713018,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/","headers":{"Accept":["text/html, application/xhtml+xml"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Referer":["https://docuseal.staffconnect.agency/templates/26"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Site":["same-origin"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Cookie":[],"If-None-Match":["W/\"f8d91c5628ac134973f8014e8185a19a\""],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Dest":["empty"],"Vnd.prefetch":["true"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Sec-Fetch-Mode":["cors"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001351834,"status":502,"err_id":"s8d3rbejf","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857512.701204,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/","headers":{"Sec-Fetch-Site":["same-origin"],"Referer":["https://docuseal.staffconnect.agency/templates/26"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Cookie":[],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Dest":["document"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001232025,"status":502,"err_id":"bcxi3axqm","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857515.1383793,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/","headers":{"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-Dest":["document"],"Referer":["https://docuseal.staffconnect.agency/templates/26"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":[],"Cache-Control":["max-age=0"],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Sec-Fetch-Site":["same-origin"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-User":["?1"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"Windows\""],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001545654,"status":502,"err_id":"yzk9yq4aw","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857516.7814813,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/templates/25","headers":{"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-Dest":["empty"],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Sec-Fetch-Mode":["cors"],"Vnd.prefetch":["true"],"Sec-Fetch-Site":["same-origin"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":[],"Accept":["text/html, application/xhtml+xml"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Referer":["https://docuseal.staffconnect.agency/"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001406184,"status":502,"err_id":"0yxyh52ww","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857516.922504,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/templates/21","headers":{"Sec-Fetch-Mode":["cors"],"Referer":["https://docuseal.staffconnect.agency/"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":[],"If-None-Match":["W/\"bc4753070d1c1e195c1383f803b4c6b8\""],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Vnd.prefetch":["true"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Dest":["empty"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Accept":["text/html, application/xhtml+xml"],"Sec-Ch-Ua-Mobile":["?0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001235384,"status":502,"err_id":"wa1sjfbef","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857518.1394527,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/submissions/27","headers":{"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Sec-Fetch-Site":["same-origin"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":[],"If-None-Match":["W/\"cc085c1e5304546d52585ade90cceb76\""],"Vnd.prefetch":["true"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Sec-Fetch-Mode":["cors"],"Sec-Fetch-Dest":["empty"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Accept":["text/html, application/xhtml+xml"],"Referer":["https://docuseal.staffconnect.agency/templates/21"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001306194,"status":502,"err_id":"a9q5wbug2","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
{"level":"error","ts":1709857519.5850296,"logger":"http.log.error","msg":"dial tcp: lookup to on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"95.91.242.170","remote_port":"50634","client_ip":"95.91.242.170","proto":"HTTP/2.0","method":"GET","host":"docuseal.staffconnect.agency","uri":"/templates/27","headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Referer":["https://docuseal.staffconnect.agency/"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Accept":["text/html, application/xhtml+xml"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-Mode":["cors"],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Google Chrome\";v=\"122\""],"Sec-Ch-Ua-Mobile":["?0"],"Vnd.prefetch":["true"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Dest":["empty"],"Cookie":[]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"docuseal.staffconnect.agency"}},"duration":0.001267675,"status":502,"err_id":"f2eek8u15","err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"}
There is a lot more to the docker caddy logs but I suppose those are consequent errors.
as a dockerwith a docker-compose file
Ubuntu 22.04. Linux VPS
docker-compose up -d
version: '3'
app:
depends_on:
postgres:
condition: service_healthy
image: docuseal/docuseal:latest
- .:/data
FORCE_SSL: 'true'
DATABASE_URL: postgresql://postgres:postgres@postgres:5432/docuseal
postgres:
image: postgres:15
- './pg_data:/var/lib/postgresql/data'
POSTGRES_USER: postgres
POSTGRES_PASSWORD: postgres
POSTGRES_DB: docuseal
healthcheck:
test: ["CMD-SHELL", "pg_isready -U postgres"]
interval: 5s
timeout: 5s
retries: 5
image: caddy:latest
- 443:443
- 443:443/udp
- ./data:/data
- ./config:/config
- HOST=docuseal.staffconnect.agency
- CADDY_HTTP_TIMEOUT=30s # Adjust the HTTP timeout as needed
- CADDY_READ_TIMEOUT=30s # Adjust the read timeout as needed
- CADDY_WRITE_TIMEOUT=30s
extra_hosts:
- "host.docker.internal:host-gateway"
The Timeouts were set because I read somehwhere that this fixes the DNS 503 Error issue.
freepbx.staffconnect.agency {
reverse_proxy host.docker.internal:50000
docuseal.staffconnect.agency {
reverse_proxy to app:3000
Apache2 is listening in Port 50000. This setup used to work earlier today.
