Somes issues from the docs
Hello here !
After watching the github page for month ! I’ve joined the adventure and deployed my first caddy 2 instance ! :grinning:
Still i’ve some issue with the doc. :thinking:
I’m using the latest release of caddy 2
caddy version
v2.0.0-rc.3 h1:z2H/QnaRscip6aZJxwTbghu3zhC88Vo8l/K57WUce4Q=
On the Caddyfile tutorial part (Caddyfile Tutorial — Caddy Documentation) :
When using the template directive with the sample html file the date displayed is still 2006 instead of the date of today as expected.
I have the same issue on Windows or Debian OS
This is the caddy file i used, the same as the docs
localhost
encode zstd gzip
templates
file_server browse
On the log directive part in the documentation (log (Caddyfile directive) — Caddy Documentation)
I want to keep logs for 1 years so i’ve crafted this Caddyfile
domain.name.fr
        output file /var/log/caddy/access.json {
                roll_size 1gib
                roll_keep 5
                roll_keep_for 365 days
root * /var/www/bookstack/public
encode zstd gzip
The result ? this seem to not working :thinking:
From the doc it’s saying :
output file <filename> {
	roll_disabled
	roll_size     <size>
	roll_keep     <num>
	roll_keep_for <days>
roll_keep_for is how long to keep rolled files. Default: 90 days
From the caddy log :
journalctl -u caddy
Error during parsing: parsing roll_keep_for duration: time: unknown unit days in duration 365days
What is the expected unit ? I am doing wrong ?
Thank ! I hope my remark will help to make better docs !
I think you need to just set roll_keep_for 365 in this case. You’re right that it can be clarified in the docs.
Edit: Made a quick docs PR to fix it:
I’m not sure what the issue is with the templating. I think @matt could clarify.
okay, i’ve changed my caddyfile,
This what i get
Caddyfile
                roll_size 1gib
                roll_keep 5
                roll_keep_for 365
Error :
Error during parsing: parsing roll_keep_for duration: time: missing unit in duration 365
hmm… :thinking:
i’ve seen people using hours instead, so there is different time unit ? this can be added in the docs.
Okay, I’ll look into the log issue a bit more.
Regarding the templates, can you post what contents you put in your html file exactly? I have a hunch but I just want to confirm.
I can confirm this is working when i set in hour insead of days.
Caddyfile :
                roll_size 1gib
                roll_keep 5
                roll_keep_for 8760h
For the templates part this is what i’ve done :grinning:
Launch command via powershell on Windows 10 1909 :
.\caddy.exe run -watch
Caddyfile :
localhost
encode zstd gzip
templates
file_server browse
html file :
<!DOCTYPE html>
<html>
	<head>
		<title>Caddy tutorial</title>
	</head>
	<body>
		Page loaded at: {<!-- -->{now | date "Mon Jan 2 15:04:05 MST 2006"}<!-- -->}
	</body>
</html>
Result on Microsoft Edge browser :
Ah, okay, that’s what I thought. Remove the <!-- --> and it should work. Templates use the {{ }} syntax.
The problem is that the Caddy docs website is also rendered using templates, and if the HTML comments are not there, then the docs would not have that placeholder rendered correctly. I think some change happened to the site that caused the comments to get incorrectly preserved in the rendered markdown. I’ll look into it.
oh this is simple as that ! :thinking:
HTML File ( i’ve played with templates)
<!DOCTYPE html>
<html>
	<head>
	</head>
	<body>
		<p>The Date of the day is: {{now | date "Mon 2 Jan  15:04:05 CEST 2006"}} </p>
		<p> The Date of the day as timezone is : {{dateInZone "02-01-2006" (now) "CEST"}}
		<p>The WebServer is : {{.Host}} </p>
		<p>Your IP is : {{.RemoteIP}} </p>
		<p>Here some Mutiplication. 2 X 128 = {{ mul 2 128}}
	</body>
</html>
the result :
Another topic on using Caddy with PHP
I’m running Debian 10 Buster with Caddy, MariaDB and PHP
Apache2 and nginx disabled with ( i’m dunno why apt would install nginx and apache.)
systemctl disable --now apache2
systemctl disable --now nginx
When i enable the php_fastcgi i run this following error
[ERROR 502 /info.php] dial unix/var/run/php/php7.4-fpm.sock connect: permission denied
On the doc for caddy 1 there is a solution to fix the permission
(Troubleshooting PHP FPM and FastCGI · caddyserver/caddy Wiki · GitHub)
So i’ve modified theses files :
/etc/php/7.4/fpm/pool.d/www.conf
listen.owner = caddy
listen.group = caddy
With this fix php is working great :grinning:
Maybe this is better to update the doc on the user creation part and use this instead ? :thinking:
useradd --system \
	--gid www-data\
	--create-home \
	--home-dir /var/lib/caddy \
	--shell /usr/sbin/nologin \
	--comment "Caddy web server" \
	caddy
and change the caddy.service file ?
After=network.target
Group=www-data
It’s not necessary to have Caddy run as group www-data but the caddy user can easily be added to the user group www-data. Maybe we should add that as a step to the docs for installing as a Linux service.
