v2.0.0-rc.1 h1:DxUlg4kMisXwXVnWND7KEPl1f+vjFpIOzYpKpfmwyj8=
caddy start
Distributor ID: Debian
Description: Debian GNU/Linux 9.9 (stretch)
Release: 9.9
Codename: stretch
ts.hasinet.at {
reverse_proxy * {
to 172.16.56.40:80
read_buffer 8192
This is an Rails application which has its own Unicorn Server, so Caddy is only here for Reverse Proxy and SSL, Unicorn does Basic Auth for the application. If i try to update an record inside the Rails application i get the following Error:
[ERROR] disposals#update (ActionController::InvalidAuthenticityToken) "ActionController::InvalidAuthenticityToken"
Do I have to set some headers for Reverse proxying?
Rails debug log:
Request:
* URL : http://ts.hasinet.at/admin/disposals/9615
* HTTP Method: PATCH
* IP address : 127.0.0.1
* Parameters : {"utf8"=>"✓", "_method"=>"patch", "authenticity_token"=>"kUKiq0RsWOnvr/ajTp/a0aV2dyYB2khWpwH9ji6j/y91lAs8ynlHstk+IBERxnSr+tBuueO7eoRlCl7C+6AFJw==", "commit"=>"Speichern", "disposal"=>{"notes"=>"angeliefertes Gewicht 1000 kg", "waste_information_id"=>"20202020", "cleared"=>"1", "material"=>"Beton", "source"=>"Gseeb Gem Seebenstein"}, "printer"=>"1 terminal", "controller"=>"admin/disposals", "action"=>"update", "id"=>"9615"}
* Timestamp : 2020-04-08 16:59:51 +0200
* Server : wwdh
* Rails root : /home/app/wwdh/releases/20160903071427
* Process: 1896
Session:
* session id: "2b2875b4a776ad956fbc70db90f5de9a"
* data: {"session_id"=>"2b2875b4a776ad956fbc70db90f5de9a",
"_csrf_token"=>"5Napl44VH1s2kdayX1muel+mGZ/iYTLSwgujTNUD+gg="}
Environment:
* CONTENT_LENGTH : 402
* CONTENT_TYPE : application/x-www-form-urlencoded
* HTTP_ACCEPT : text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
* HTTP_ACCEPT_ENCODING : gzip, deflate, br
* HTTP_ACCEPT_LANGUAGE : en-US,en;q=0.5
* HTTP_AUTHORIZATION : Basic d3dkaDp3d2Ro
* HTTP_CONNECTION : close
* HTTP_COOKIE : experimentation_subject_id=ImYyYzA2Zjg2LWY2Y2MtNDI4NS1hOWE3LTRmY2QwYmEyYjc3MiI%3D--7f07ab7079a4364138c4294d67d6e242a63d8098; _wwdh_session=MzZGY2t6MnNIenRRQTJLVUpXeWVNeEpjeTRabnlHcVlIR2Q0OGlhK3hvdFI1dkMwcm82NUJYN2V5SkNONUk1SUlYUm1xQ3NMTXd0WkpjaGpxa1g1ZWhveVZob3hzM21ZVnBUZnZwMzBJTUhkUWNCcXJnS3hMQzN5TW9qRG42NTBQUENJTzdTNXJKVkxhSzdmQkJXdzhBPT0tLTVtNmNxTTNmVnRpMFJaMXRKVldDOWc9PQ%3D%3D--4c912bc41476652a84128948be4226ebaf8619dc
* HTTP_DNT : 1
* HTTP_HOST : ts.hasinet.at
* HTTP_ORIGIN : https://ts.hasinet.at
* HTTP_REFERER : https://ts.hasinet.at/admin/disposals/9615/edit
* HTTP_TE : trailers
* HTTP_UPGRADE_INSECURE_REQUESTS : 1
* HTTP_USER_AGENT : Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:76.0) Gecko/20100101 Firefox/76.0
* HTTP_VERSION : HTTP/1.0
* HTTP_X_FORWARDED_FOR : 172.16.0.1, 172.16.0.2
* ORIGINAL_FULLPATH : /admin/disposals/9615
* ORIGINAL_SCRIPT_NAME :
* PATH_INFO : /admin/disposals/9615
* QUERY_STRING :
* REMOTE_ADDR : 127.0.0.1
* REQUEST_METHOD : PATCH
* REQUEST_PATH : /admin/disposals/9615
* REQUEST_URI : /admin/disposals/9615
* ROUTES_70038129124980_SCRIPT_NAME :
* SCRIPT_NAME :
* SERVER_NAME : ts.hasinet.at
* SERVER_PORT : 80
* SERVER_PROTOCOL : HTTP/1.0
* SERVER_SOFTWARE : Unicorn 5.0.1
* action_controller.instance : #<Admin::DisposalsController:0x007f660f8fa468>
* action_dispatch.backtrace_cleaner : #<Rails::BacktraceCleaner:0x007f66099a8758>
* action_dispatch.cookies : #<ActionDispatch::Cookies::CookieJar:0x007f660f8eb418>
* action_dispatch.cookies_digest :
* action_dispatch.cookies_serializer : json
* action_dispatch.encrypted_cookie_salt : encrypted cookie
* action_dispatch.encrypted_signed_cookie_salt : signed encrypted cookie
* action_dispatch.http_auth_salt : http authentication
* action_dispatch.key_generator : #<ActiveSupport::CachingKeyGenerator:0x007f660d5d9dd0>
* action_dispatch.logger : #<ActiveSupport::Logger:0x007f660b8e9680>
* action_dispatch.parameter_filter : [:password]
* action_dispatch.redirect_filter : []
* action_dispatch.remote_ip : 127.0.0.1
* action_dispatch.request.content_type : application/x-www-form-urlencoded
* action_dispatch.request.formats : [#<Mime::Type:0x007f6609a121d0 @synonyms=["application/xhtml+xml"], @symbol=:html, @string="text/html", @hash=-4165152267936131272>]
* action_dispatch.request.parameters : {"utf8"=>"✓", "_method"=>"patch", "authenticity_token"=>"kUKiq0RsWOnvr/ajTp/a0aV2dyYB2khWpwH9ji6j/y91lAs8ynlHstk+IBERxnSr+tBuueO7eoRlCl7C+6AFJw==", "commit"=>"Speichern", "disposal"=>{"notes"=>"angeliefertes Gewicht 1000 kg", "waste_information_id"=>"20202020", "cleared"=>"1", "material"=>"Beton", "source"=>"Gseeb Gem Seebenstein"}, "printer"=>"1 terminal", "controller"=>"admin/disposals", "action"=>"update", "id"=>"9615"}
* action_dispatch.request.path_parameters : {:controller=>"admin/disposals", :action=>"update", :id=>"9615"}
* action_dispatch.request.query_parameters : {}
* action_dispatch.request.request_parameters : {"utf8"=>"✓", "_method"=>"patch", "authenticity_token"=>"kUKiq0RsWOnvr/ajTp/a0aV2dyYB2khWpwH9ji6j/y91lAs8ynlHstk+IBERxnSr+tBuueO7eoRlCl7C+6AFJw==", "commit"=>"Speichern", "disposal"=>{"notes"=>"angeliefertes Gewicht 1000 kg", "waste_information_id"=>"20202020", "cleared"=>"1", "material"=>"Beton", "source"=>"Gseeb Gem Seebenstein"}, "printer"=>"1 terminal"}
* action_dispatch.request.unsigned_session_cookie: {"session_id"=>"2b2875b4a776ad956fbc70db90f5de9a", "_csrf_token"=>"5Napl44VH1s2kdayX1muel+mGZ/iYTLSwgujTNUD+gg="}
* action_dispatch.request_id : fa1a6188-7909-4acf-a793-bdba0453e03c
* action_dispatch.routes : #<ActionDispatch::Routing::RouteSet:0x007f660b9d4ce8>
* action_dispatch.secret_key_base : a7b959ead12b283ae385bd904eb439513d013467cafc02a368f32858ffea5dc30ea40c052eb0e6a385acb839bdebd13ecc18f4fdc0882d88ca90abb3287c41ec
* action_dispatch.secret_token :
* action_dispatch.show_detailed_exceptions : false
* action_dispatch.show_exceptions : true
* action_dispatch.signed_cookie_salt : signed cookie
* rack.errors : #<File:0x007f6608649b30>
* rack.hijack : #<Unicorn::HttpParser:0x007f6608c46fd8>
* rack.hijack? : true
* rack.input : #<Unicorn::TeeInput:0x007f660f90ba60>
* rack.logger : #<Logger:0x007f66090eab70>
* rack.methodoverride.original_method : POST
* rack.multiprocess : true
* rack.multithread : false
* rack.request.cookie_hash : {"experimentation_subject_id"=>"ImYyYzA2Zjg2LWY2Y2MtNDI4NS1hOWE3LTRmY2QwYmEyYjc3MiI=--7f07ab7079a4364138c4294d67d6e242a63d8098", "_wwdh_session"=>"MzZGY2t6MnNIenRRQTJLVUpXeWVNeEpjeTRabnlHcVlIR2Q0OGlhK3hvdFI1dkMwcm82NUJYN2V5SkNONUk1SUlYUm1xQ3NMTXd0WkpjaGpxa1g1ZWhveVZob3hzM21ZVnBUZnZwMzBJTUhkUWNCcXJnS3hMQzN5TW9qRG42NTBQUENJTzdTNXJKVkxhSzdmQkJXdzhBPT0tLTVtNmNxTTNmVnRpMFJaMXRKVldDOWc9PQ==--4c912bc41476652a84128948be4226ebaf8619dc"}
* rack.request.cookie_string : experimentation_subject_id=ImYyYzA2Zjg2LWY2Y2MtNDI4NS1hOWE3LTRmY2QwYmEyYjc3MiI%3D--7f07ab7079a4364138c4294d67d6e242a63d8098; _wwdh_session=MzZGY2t6MnNIenRRQTJLVUpXeWVNeEpjeTRabnlHcVlIR2Q0OGlhK3hvdFI1dkMwcm82NUJYN2V5SkNONUk1SUlYUm1xQ3NMTXd0WkpjaGpxa1g1ZWhveVZob3hzM21ZVnBUZnZwMzBJTUhkUWNCcXJnS3hMQzN5TW9qRG42NTBQUENJTzdTNXJKVkxhSzdmQkJXdzhBPT0tLTVtNmNxTTNmVnRpMFJaMXRKVldDOWc9PQ%3D%3D--4c912bc41476652a84128948be4226ebaf8619dc
* rack.request.form_hash : {"utf8"=>"✓", "_method"=>"patch", "authenticity_token"=>"kUKiq0RsWOnvr/ajTp/a0aV2dyYB2khWpwH9ji6j/y91lAs8ynlHstk+IBERxnSr+tBuueO7eoRlCl7C+6AFJw==", "commit"=>"Speichern", "disposal"=>{"notes"=>"angeliefertes Gewicht 1000 kg", "waste_information_id"=>"20202020", "cleared"=>"1", "material"=>"Beton", "source"=>"Gseeb Gem Seebenstein"}, "printer"=>"1 terminal"}
* rack.request.form_input : #<Unicorn::TeeInput:0x007f660f90ba60>
* rack.request.form_vars : [FILTERED]
* rack.request.query_hash : {}
* rack.request.query_string :
* rack.run_once : false
* rack.session : #<ActionDispatch::Request::Session:0x007f660f8fb570>
* rack.session.options : #<ActionDispatch::Request::Session::Options:0x007f660f8fb4f8>
* rack.tempfiles : []
* rack.url_scheme : http
* rack.version : [1, 2]
* unicorn.socket : #<Kgio::Socket:0x007f660f90be20>
Not much really since with Nginx reverse Proxy’ing it did work.
old NGINX config:
proxy_set_header Accept-Encoding "";
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
Which headers are set in reverse_proxy directive in caddy?
maybe i have to add some explicitly?
