): aur/caddy2 2.3.0-2 (Arch Linux)
I am running caddy on a personal server hosting within my home. The box has 2 NICs. (192.168.1.5 and 192.168.1.6). When I start caddy, it appears to be linked to both NICs and I need it to be limited to 192.168.1.5 only so that I can attach the IP/NIC to a docker container. Caddy is installed on the host system and NOT in a docker.
a. System environment: Arch Linux
Linux banshee 5.10.7-arch1-1 #1 SMP PREEMPT Wed, 13 Jan 2021 12:02:01 +0000 x86_64 GNU/Linux
systemctl --version
systemd 247 (247.2-1-arch)
+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid
I am running caddy from a systemd service (see below)
User=http
Group=http
Type=exec
ExecStop=/usr/bin/caddy stop
d. My complete Caddyfile or JSON config: (i know it says not to redact, but the site in irrelevant as I am dealing with a configuration issue)
As seen below, the Caddyfile config is not using 192.68.1.6, so I think it’s another configuration issue.
www.SITE.net, SITE.net {
root * /srv/http/SITE.net
php_fastcgi unix//var/run/php-fpm/php-fpm.sock
output file /var/log/SITE.access.log
git.SITE.net {
reverse_proxy 192.168.1.5:3000
cloud.SITE.net {
reverse_proxy 192.168.1.5:10025
As stated above, I need caddy to limit it’s hosting to a single IP instead of system-wide.
When I run fuser
to see which process is using a port:
[roberts@banshee caddy]$ sudo fuser 443/tcp
443/tcp: 13923
I check the process and it’s caddy:
[roberts@banshee caddy]$ sudo ls -l /proc/13923/exe
lrwxrwxrwx 1 http http 0 Jan 18 10:27 /proc/13923/exe -> /usr/bin/caddy
Any help would be appreciated, and thanks!
