2.1.1
I run caddy via docker. See below docker compose file
alpine linux image in ubuntu linux host
My docker compose file entrypoint looks as follows
caddy run --config "/etc/caddy/Caddyfile" --adapter "caddyfile"
Docker compose file
version: "2.1"
jenkins:
image: jenkins/jenkins:2.235.3-lts-centos7
container_name: jenkins-container
# environment:
# - JENKINS_OPTS="--prefix=/"
- /home/ubuntu/app/data/jenkins/home:/var/jenkins_home
expose:
- 8080
- 50000
- 50000:50000
logging:
driver: "json-file"
options:
max-file: "5"
max-size: "10m"
image: caddy:2.1.1-alpine
container_name: caddy-container
command: caddy run --config "/etc/caddy/Caddyfile" --adapter "caddyfile"
- /home/ubuntu/app/data/caddy/data:/data
- /home/ubuntu/app/data/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/ubuntu/app/data/caddy/config:/config
- /home/ubuntu/app/data/caddy/www:/usr/share/caddy
expose:
- 80
- 443
- 443:443
logging:
driver: "json-file"
options:
max-file: "5"
max-size: "10m"
# email to use on Let's Encrypt
email <my email here>
# Uncomment for debug
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
#debug
# Add gzip compression to requests
(webconf) {
# Add forward headers to requests
(theheaders) {
header_up X-Forwarded-Ssl off
header_up Host {host}
header_up X-Real-IP {remote}
header_up X-Forwarded-For {remote}
header_up X-Forwarded-Port {server_port}
header_up X-Forwarded-Proto http
header_up X-Url-Scheme {scheme}
jenkins.app.example.com {
reverse_proxy http://jenkins-container:8080 {
import theheaders
import webconf
When accessing jenkins this way through caddy, Jenkins returns a http 500 error. HTTP ERROR 500 java.lang.RuntimeException: java.lang.NumberFormatException: For input string: “” with the following stack trace
URI: /
STATUS: 500
MESSAGE: java.lang.RuntimeException: java.lang.NumberFormatException: For input string: ""
SERVLET: -
CAUSED BY: java.lang.RuntimeException: java.lang.NumberFormatException: For input string: ""
CAUSED BY: java.lang.NumberFormatException: For input string: ""
Caused by:
at org.eclipse.jetty.server.ForwardedRequestCustomizer.customize(ForwardedRequestCustomizer.java:390)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:379)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:273)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:375)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NumberFormatException: For input string: ""
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.lang.Integer.parseInt(Integer.java:592)
at java.lang.Integer.parseInt(Integer.java:615)
at org.eclipse.jetty.server.ForwardedRequestCustomizer$Forwarded.handlePort(ForwardedRequestCustomizer.java:654)
at org.eclipse.jetty.server.ForwardedRequestCustomizer.customize(ForwardedRequestCustomizer.java:385)
... 15 more
Accessing jenkins directly via port 8080 works. However jenkins displays the following message with the following url
It appears that your reverse proxy set up is broken.
[https://wiki.jenkins.io/display/JENKINS/Jenkins+says+my+reverse+proxy+setup+is+broken](https://wiki.jenkins.io/display/JENKINS/Jenkins+says+my+reverse+proxy+setup+is+broken)
See above
