I am trying to build caddy server with two modules - Cloudflare-dns and caddy-maxmind-geolocation but I am getting some error.
Dockerfile
FROM caddy:builder-alpine as builder
RUN xcaddy build --with github.com/caddy-dns/cloudflare github.com/porech/caddy-maxmind-geolocation
FROM caddy:alpine
Here are the logs
Log
Sending build context to Docker daemon 4.608kB
Step 1/4 : FROM caddy:builder-alpine as builder
---> c6d72fd43a1d
Step 2/4 : RUN xcaddy build --with github.com/caddy-dns/cloudflare github.com/porech/caddy-maxmind-geolocation
---> Running in c25981e9a9b5
2021/10/20 13:26:07 [INFO] Temporary folder: /tmp/buildenv_2021-10-20-1326.2222301904
2021/10/20 13:26:07 [INFO] Writing main module: /tmp/buildenv_2021-10-20-1326.2222301904/main.go
2021/10/20 13:26:07 [INFO] Initializing Go module
2021/10/20 13:26:07 [INFO] exec (timeout=10s): /usr/local/go/bin/go mod init caddy
go: creating new go.mod: module caddy
go: to add module requirements and sums:
go mod tidy
2021/10/20 13:26:08 [INFO] Pinning versions
2021/10/20 13:26:08 [INFO] exec (timeout=0s): /usr/local/go/bin/go get -d -v github.com/caddyserver/caddy/v2@github.com/porech/caddy-maxmind-geolocation
go get: github.com/caddyserver/caddy/v2@github.com/porech/caddy-maxmind-geolocation: invalid version: version "github.com/porech/caddy-maxmind-geolocation" invalid: disallowed version string
2021/10/20 13:26:08 [FATAL] exit status 1
Is it possible to build caddy with multiple modules?
