v2.2.1
I am running caddy as a reverse proxy on a proxmox vm. which houses my docker containers.
Proxmox virtual environment, caddy is running in a ubuntu vm.
systemctl start caddy
jellyfin.scserver.us{
reverse_proxy 172.17.0.4:8096
mc.scserver.us{
reverse_proxy 172.17.0.5:25567
if I run caddy without the second subdomain it runs just fine and I can access my jellyfin server from the url. but if i add my minecraft server subdomain it breaks it and i cant find out why.
root@Ubuntu:/etc/caddy# systemctl status caddy
- caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2020-11-20 01:45:08 UTC; 15min ago
Docs: Welcome — Caddy Documentation
Main PID: 30950 (caddy)
Tasks: 11 (limit: 4915)
Memory: 12.0M
`-30950 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Nov 20 01:45:08 Ubuntu caddy[30950]: INVOCATION_ID=62beac6944094550826781fa4e6c1cf8
Nov 20 01:45:08 Ubuntu caddy[30950]: JOURNAL_STREAM=9:25341879
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.3811297,“msg”:“using provided configuration”,“config_file”:"/etc/caddy/Caddyfile",“config_adapter”:""}
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.3832564,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“tcp/localhost:2019”,“enforce_origin”:f>
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.3835042,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc0>
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.3835359,“logger”:“http”,“msg”:“server is listening only on the HTTPS port but has no TLS connection polic>
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.383556,“logger”:“http”,“msg”:“enabling automatic HTTP->HTTPS redirects”,“server_name”:“srv0”}
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.3843129,“msg”:“autosaved config”,“file”:”/var/lib/caddy/.config/caddy/autosave.json”}
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.3843331,“msg”:“serving initial configuration”}
Nov 20 01:45:08 Ubuntu caddy[30950]: {“level”:“info”,“ts”:1605836708.385553,“logger”:“tls”,“msg”:“cleaned up storage units”}
I didn’t have the brackets at one point so i fixed that. I have double checked ports on my router. Made sure my domain was pointing to my dynamic dns through duckdns. I have pinged the server and gotten my ip address as well.
