[SOLVED] Err_content_decoding_failed
ubuntu caddy service
local windows hosts file redirected at caddy domain
Ubuntu 20.04
PHP 7.4
service caddy start
# caddy.service
# for your installation.
# domain name.
it-svc.com, www.it-svc.com {
	root * /var/www/it-svc.com
	#encode gzip
	encode zstd
	tls internal
		output file /var/log/caddy/itsvc_access.log {
			roll true # Rotate logs, enabled by default
			roll_size_mb 5 # Set max size 5 MB
			roll_gzip true # Whether to compress rolled files
			roll_local_time true # Use localhost time
			roll_keep 2 # Keep at most 2 log files
			roll_keep_days 7 # Keep log files for 7 days
	@disallowed {
		path /xmlrpc.php
		path *.sql
		path /wp-content/uploads/*.php
	rewrite @disallowed '/index.php'
Chrome Edge and firefox return a content decoding error this is chromes result.
GET https://www.it-svc.com/ net::ERR_CONTENT_DECODING_FAILED 200
There are no errors in the access log: Headers also show content from underlying wordpress site
Tried turning on and off encoding
Tried changing from gzip to zstd and without encoding line at all.
Also tried adding https to start of domain www and non-www
What do you see when you make the request with curl -v instead of in a browser?
root@ubuntu-s-2vcpu-4gb-nyc3-01:/etc/systemd/network# curl -v --header "Host: www.it-svc.com" --head https://127.0.0.1/
*   Trying 127.0.0.1:443...
* TCP_NODELAY set
* Connected to 127.0.0.1 (127.0.0.1) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
* Closing connection 0
So as a conclusion to this issue.
This turned out to be a content encoding error of the output of wordpress w/ php
It required me to go into the php.ini for the php-fpm server and turn on
zlib.output_compression = On
