Forgive me, I don’t fully understand how TLS really works. I am moving VPS and want to redirect example.com to point to the new server. At the DNS level I’ve done this, but caddy won’t serve me anything at example.com now, from what I presume is it failing to get an https certificate.
I saw a couple other topics on moving VPS, and I copied all the files from my old VPS’s certificates directory over to the new server, but I think that’s contributing to more problems.
I should also mention that caddy is working find for some of the domains that are redirecting to services, but it isn’t working on any endpoints with file_server
directive.
This is before I copied certs over.
{"level":"info","ts":1701792958.8249846,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1701792958.8311405,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1701792958.8371565,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1701792958.8378112,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1701792958.8379698,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1701792958.8380525,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv1"}
{"level":"info","ts":1701792958.8537703,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000652700"}
{"level":"info","ts":1701792958.854257,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1701792958.8569999,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1701792958.89402,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1701792958.8945768,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1701792958.8949215,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"info","ts":1701792958.895278,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1701792958.8955452,"logger":"http","msg":"enabling HTTP/3 listener","addr":":8443"}
{"level":"info","ts":1701792958.8959994,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1701792958.8963084,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1701792958.896459,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["stringcase.org","mn.rutrum.net","45.63.65.162","cloud2.rutrum.net","anki.rutrum.net","www.rutrum.net","rutrum.net"]}
{"level":"info","ts":1701792958.9024584,"logger":"tls.obtain","msg":"acquiring lock","identifier":"stringcase.org"}
{"level":"info","ts":1701792958.9037902,"logger":"tls.obtain","msg":"lock acquired","identifier":"stringcase.org"}
{"level":"info","ts":1701792958.9053376,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"stringcase.org"}
{"level":"info","ts":1701792958.9068308,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["stringcase.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"davepurdum@pm.me"}
{"level":"info","ts":1701792958.9069858,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["stringcase.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"davepurdum@pm.me"}
{"level":"warn","ts":1701792959.0552335,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [45.63.65.162]: no OCSP server specified in certificate","identifiers":["45.63.65.162"]}
{"level":"info","ts":1701792959.0558188,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1701792959.0560489,"msg":"serving initial configuration"}
{"level":"info","ts":1701792959.1545413,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"stringcase.org","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1701792959.7733595,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"stringcase.org","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]}}
{"level":"error","ts":1701792959.7736707,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"stringcase.org","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1446778836/227075318996","attempt":1,"max_attempts":3}
{"level":"info","ts":1701792960.9103184,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"stringcase.org","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1701792961.239697,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"stringcase.org","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"45.63.65.16: Invalid response from http://stringcase.org/.well-known/acme-challenge/a7xpkF4b6QDGqntlR1V3YeR9HY9afexoY2Z4QS167Ws: 404","instance":"","subproblems":[]}}
{"level":"error","ts":1701792961.2401223,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"stringcase.org","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"45.63.65.16: Invalid response from http://stringcase.org/.well-known/acme-challenge/a7xpkF4b6QDGqntlR1V3YeR9HY9afexoY2Z4QS167Ws: 404","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1446778836/227075324876","attempt":2,"max_attempts":3}
{"level":"error","ts":1701792961.2404008,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"stringcase.org","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 403 urn:ietf:params:acme:error:unauthorized - 45.63.65.16: Invalid response from http://stringcase.org/.well-known/acme-challenge/a7xpkF4b6QDGqntlR1V3YeR9HY9afexoY2Z4QS167Ws: 404"}
{"level":"info","ts":1701792961.2411015,"logger":"tls.issuance.zerossl","msg":"waiting on internal rate limiter","identifiers":["stringcase.org"],"ca":"https://acme.zerossl.com/v2/DV90","account":"davepurdum@pm.me"}
{"level":"info","ts":1701792961.2412953,"logger":"tls.issuance.zerossl","msg":"done waiting on internal rate limiter","identifiers":["stringcase.org"],"ca":"https://acme.zerossl.com/v2/DV90","account":"davepurdum@pm.me"}
{"level":"error","ts":1701792961.640618,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"stringcase.org","issuer":"acme.zerossl.com-v2-DV90","error":"[stringcase.org] creating new order: fetching new nonce from server: HTTP 504: (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1701792961.6407313,"logger":"tls.obtain","msg":"will retry","error":"[stringcase.org] Obtain: [stringcase.org] creating new order: fetching new nonce from server: HTTP 504: (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":2.736753416,"max_duration":2592000}
{"level":"info","ts":1701793021.64127,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"stringcase.org"}
{"level":"info","ts":1701793021.915543,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"stringcase.org","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1701793022.5375707,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"stringcase.org","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"45.63.65.16: Invalid response from http://stringcase.org/.well-known/acme-challenge/ftKVpUsjW09p-VADWMOAsNLha2KO1NtBImyBjavF6vE: 404","instance":"","subproblems":[]}}
{"level":"error","ts":1701793022.5378966,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"stringcase.org","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"45.63.65.16: Invalid response from http://stringcase.org/.well-known/acme-challenge/ftKVpUsjW09p-VADWMOAsNLha2KO1NtBImyBjavF6vE: 404","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/127644284/12768769804","attempt":1,"max_attempts":3}
{"level":"info","ts":1701793023.6464005,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"stringcase.org","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1701793023.9950287,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"stringcase.org","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]}}
{"level":"error","ts":1701793023.9950871,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"stringcase.org","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/127644284/12768770414","attempt":2,"max_attempts":3}
{"level":"error","ts":1701793023.995122,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"stringcase.org","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 403 urn:ietf:params:acme:error:unauthorized - Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge"}
{"level":"error","ts":1701793024.0136251,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"stringcase.org","issuer":"acme.zerossl.com-v2-DV90","error":"[stringcase.org] creating new order: fetching new nonce from server: HTTP 504: (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1701793024.0137148,"logger":"tls.obtain","msg":"will retry","error":"[stringcase.org] Obtain: [stringcase.org] creating new order: fetching new nonce from server: HTTP 504: (ca=https://acme.zerossl.com/v2/DV90)","attempt":2,"retrying_in":120,"elapsed":65.109736803,"max_duration":2592000}
{"level":"info","ts":1701793067.0382657,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1701793067.0383441,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"
This is after I moved certs over.
{"level":"info","ts":1701795758.3542159,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1701795758.3592465,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1701795758.3638856,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
{"level":"info","ts":1701795758.364507,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv1"}
{"level":"info","ts":1701795758.3647475,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1701795758.3648446,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1701795758.3729105,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1701795758.3768833,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1701795758.373466,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000668d80"}
{"level":"info","ts":1701795758.3989737,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1701795758.3995905,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1701795758.3998492,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"info","ts":1701795758.400291,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1701795758.4004915,"logger":"http","msg":"enabling HTTP/3 listener","addr":":8443"}
{"level":"info","ts":1701795758.4007652,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1701795758.4009483,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1701795758.4010582,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["stringcase.org","mn.rutrum.net","45.63.65.162","anki.rutrum.net","www.rutrum.net","cloud2.rutrum.net","rutrum.net"]}
{"level":"warn","ts":1701795758.4048553,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [45.63.65.162]: no OCSP server specified in certificate","identifiers":["45.63.65.162"]}
{"level":"info","ts":1701795758.4053142,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1701795758.4054346,"msg":"serving initial configuration"}
v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q
Docker image.
Debian 6.1.55-1 (2023-09-29) x86_64 GNU/Linux
Docker version 24.0.7, build afdd53b
docker compose up -d
image: caddy:alpine
- ./config:/config
- ./data:/data
network_mode: "host"
email <my email>
https://cloud2.rutrum.net:443 {
header Strict-Transport-Security max-age=31536000;
reverse_proxy localhost:11000
https://cloud2.rutrum.net:8443 {
reverse_proxy https://localhost:8080 {
tls_insecure_skip_verify
anki.rutrum.net {
reverse_proxy :27701
www.rutrum.net, rutrum.net {
root * /home/rutrum/src/rutrum.net/public
stringcase.org {
root * /home/rutrum/src/stringcase.org/public
mn.rutrum.net {
root * /home/rutrum/src/mn-svelte/build
