I have just manually installed caddy v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=. I picked the caddy_2.8.4_linux_amd64.tar.gz from Github packages and there is simply a caddy executable inside.
I followed the instructions from the manual installation documentation.
I have run
$ sudo setcap cap_net_bind_service=+ep $(which caddy)
In the error messages, there are these specific lines:
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: caddy.service: Failed to locate executable /usr/bin/caddy: Permission denied
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: caddy.service: Failed at step EXEC spawning /usr/bin/caddy: Permission denied
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Child 3169 belongs to caddy.service.
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Main process exited, code=exited, status=203/EXEC
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Failed with result 'exit-code'.
However, I have eXecutable right for all users.
$ ls -al /usr/bin/caddy
-rwxr-xr-x. 1 root root 40681624 Jun 2 20:10 /usr/bin/caddy
And I can manually run caddy as the caddy user using
$ sudo -u caddy whoami
caddy
$ sudo -u caddy /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
2024/09/25 11:26:22.449 INFO using config from file {"file": "/etc/caddy/Caddyfile"}
2024/09/25 11:26:22.449 INFO adapted config to JSON {"adapter": "caddyfile"}
2024/09/25 11:26:22.450 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2024/09/25 11:26:22.451 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00035fe80"}
2024/09/25 11:26:22.452 WARN tls stapling OCSP {"error": "no OCSP stapling for [hk]: no OCSP server specified in certificate"}
2024/09/25 11:26:22.452 INFO http.auto_https automatic HTTP->HTTPS redirects are disabled {"server_name": "srv0"}
2024/09/25 11:26:22.452 INFO http enabling HTTP/3 listener {"addr": ":8000"}
2024/09/25 11:26:22.452 INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details.
2024/09/25 11:26:22.452 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/09/25 11:26:22.452 INFO autosaved config (load with --resume flag) {"file": "/var/lib/caddy/.config/caddy/autosave.json"}
2024/09/25 11:26:22.452 INFO serving initial configuration
2024/09/25 11:26:22.453 INFO tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/var/lib/caddy/.local/share/caddy", "instance": "89d4c866-0f96-46f2-a41f-8eda924f30a4", "try_again": "2024/09/26 11:26:22.453", "try_again_in": 86399.999999803}
2024/09/25 11:26:22.453 INFO tls finished cleaning storage units
$ [user@localhost ~]$ curl -k -D- https://localhost:8000
HTTP/2 200
alt-svc: h3=":8000"; ma=2592000
content-type: text/html; charset=utf-8
date: Wed, 25 Sep 2024 11:28:53 GMT
etag: W/"c9-tkH+OagGKX3eLy85A53ATPJW+TE"
server: Caddy
x-powered-by: Express
content-length: 201
$ journalctl -u caddy --no-pager | less +G
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Trying to enqueue job caddy.service/restart/replace
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Installed new job caddy.service/restart as 779
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Enqueued job caddy.service/restart as 779
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Job 779 caddy.service/restart finished, result=done
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Converting job caddy.service/restart -> caddy.service/start
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Passing 0 fds to service
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: About to execute /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Forked /usr/bin/caddy as 3169
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Changed failed -> start
Sep 25 19:17:12 localhost.localdomain systemd[1]: Starting Caddy...
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: User lookup succeeded: uid=982 gid=982
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Bind-mounting / on /run/systemd/unit-root (MS_BIND|MS_REC "")...
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/boot
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/efi
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/etc
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Bind-mounting /run/systemd/unit-root/etc on /run/systemd/unit-root/etc (MS_BIND|MS_REC "")...
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Successfully mounted /run/systemd/unit-root/etc to /run/systemd/unit-root/etc
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/run/credentials
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Bind-mounting /run/systemd/inaccessible/dir on /run/systemd/unit-root/run/credentials (MS_BIND|MS_REC "")...
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Successfully mounted /run/systemd/inaccessible/dir to /run/systemd/unit-root/run/credentials
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/run/systemd/incoming
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Followed source symlinks /run/systemd/propagate/caddy.service → /run/systemd/propagate/caddy.service.
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Bind-mounting /run/systemd/propagate/caddy.service on /run/systemd/unit-root/run/systemd/incoming (MS_BIND "")...
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Successfully mounted /run/systemd/propagate/caddy.service to /run/systemd/unit-root/run/systemd/incoming
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/tmp
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Bind-mounting /tmp/systemd-private-f69532597e214c06939989bffc9584c4-caddy.service-GQU48b/tmp on /run/systemd/unit-root/tmp (MS_BIND|MS_REC "")...
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Successfully mounted /tmp/systemd-private-f69532597e214c06939989bffc9584c4-caddy.service-GQU48b/tmp to /run/systemd/unit-root/tmp
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/usr
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Bind-mounting /run/systemd/unit-root/usr on /run/systemd/unit-root/usr (MS_BIND|MS_REC "")...
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Successfully mounted /run/systemd/unit-root/usr to /run/systemd/unit-root/usr
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Applying namespace mount on /run/systemd/unit-root/var/tmp
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Bind-mounting /var/tmp/systemd-private-f69532597e214c06939989bffc9584c4-caddy.service-DIGXdO/tmp on /run/systemd/unit-root/var/tmp (MS_BIND|MS_REC "")...
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Successfully mounted /var/tmp/systemd-private-f69532597e214c06939989bffc9584c4-caddy.service-DIGXdO/tmp to /run/systemd/unit-root/var/tmp
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Remounted /run/systemd/unit-root/boot/efi.
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Remounted /run/systemd/unit-root/boot.
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Remounted /run/systemd/unit-root/etc.
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Remounted /run/systemd/unit-root/run/credentials.
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Remounted /run/systemd/unit-root/run/systemd/incoming.
Sep 25 19:17:12 localhost.localdomain (caddy)[3169]: Remounted /run/systemd/unit-root/usr.
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Service will not restart (restart setting)
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Changed start -> failed
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Job 779 caddy.service/start finished, result=failed
Sep 25 19:17:12 localhost.localdomain systemd[1]: Failed to start Caddy.
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Unit entered failed state.
Sep 25 19:17:12 localhost.localdomain systemd[1]: caddy.service: Releasing resources...
Manually installation with reference to the official manual installation documentation and running as a systemd service.
OS=openEuler 22.03 LTS-SP3 (treat it as CentOS-7 with more up-to-date kernel)
Architecture=amd x86
$ systemctl --version=systemd 249 (v249-80.oe2203sp3)
[user@localhost ~]$ sudo systemctl restart caddy
Job for caddy.service failed because the control process exited with error code.
See "systemctl status caddy.service" and "journalctl -xeu caddy.service" for details.
# /etc/systemd/system/caddy.service
Type=notify
# /etc/caddy/Caddyfile
auto_https disable_redirects
:8000 {
reverse_proxy localhost:3000
tls "/etc/caddy/cert/server_cert.crt" "/etc/caddy/cert/server_key.key" {
key_type rsa4096
format console
output file /var/log/caddy.log {
roll_size 100MiB
roll_local_time
roll_keep 10
roll_keep_for 30d
This post seems related but it doesn’t help.
