[SOLVED]Caddy json not auto redirecting to ssl
v2.5.0 h1:eRHzZ4l3X6Ag3kUt8nj5IxATprhqKq/wToP7OHlXWA0=
Build caddy using the following command:
xcaddy build --with github.com/caddyserver/ntlm-transport --with github.com/caddyserver/certmagic --with github.com/lolPants/caddy-requestid --with github.com/chukmunnlee/caddy-openapi --with github.com/mholt/caddy-l4 --with github.com/greenpau/caddy-security --with github.com/vrongmeal/caddygit/module/git --with github.com/caddy-dns/cloudflare
Built caddy executable is moved to /usr/bin/caddy
Caddy is then launched via systemd as a service. To configure I use the AdminAPI for CI/CD (config stored in a github repo, and webhook to jenkins to trigger deployment)
Ubuntu 22.04, caddy installed directly on the host (not containerized)
systemctl start caddy-api
# caddy-api.service
# For using Caddy with its API.
# This unit is "durable" in that it will automatically resume
# the last active configuration if the service is restarted.
Type=notify
ExecStart=/usr/bin/caddy run --environ --resume
  "apps": {
    "http": {
      "servers": {
        "main": {
          "listen": [
            ":80",
            ":443"
          "routes": [
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "handler": "reverse_proxy",
                          "upstreams": [
                              "dial": "docker.system32.uk:5055"
                          "transport": {
                            "protocol": "http_ntlm"
              "match": [
                  "host": [
                    "media.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.228:443"
                          "transport": {
                            "protocol": "http_ntlm",
                            "tls": {
                              "insecure_skip_verify": true
              "match": [
                  "host": [
                    "hrvy.uk",
                    "*.hrvy.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.1.245:32400"
              "match": [
                  "host": [
                    "plex.media.system32.uk",
                    "plex.media.jordanharvey.xyz"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.1.245:8181"
              "match": [
                  "host": [
                    "manage.media.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "10.10.2.202:8123"
              "match": [
                  "host": [
                    "apps-homeassistant.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.32:10000"
              "match": [
                  "host": [
                    "apps-budibase.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.42:9090"
                          "transport": {
                            "tls": {
              "match": [
                  "host": [
                    "apps-cockpit.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.30:80"
              "match": [
                  "host": [
                    "apps-passman.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "10.20.1.8:80"
              "match": [
                  "host": [
                    "apps-zabbix.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.29:443"
                          "transport": {
                            "tls": {
              "match": [
                  "host": [
                    "assets.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.22:80"
              "match": [
                  "host": [
                    "git.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.223:80"
              "match": [
                  "host": [
                    "live-tv.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.220:10000"
                          "transport": {
                            "tls": {
              "match": [
                  "host": [
                    "apps-wsadmin.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "docker.system32.uk:9443"
                          "transport": {
                            "tls": {
              "match": [
                  "host": [
                    "apps-portainer.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "resvmdocker02.docker.system32.uk:49154"
                          "transport": {
              "match": [
                  "host": [
                    "jenkins.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.225:80"
                          "transport": {
              "match": [
                  "host": [
                    "hrm.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.1.52:5001"
                          "transport": {
                            "tls": {
              "match": [
                  "host": [
                    "phone.hrvy.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "resvmdocker02.docker.system32.uk:30080"
                          "transport": {
              "match": [
                  "host": [
                    "apps-baserow.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "resvmdocker02.docker.system32.uk:28080"
                          "transport": {
              "match": [
                  "host": [
                    "support.system32.uk"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.190:443"
                          "transport": {
                            "tls": {
              "match": [
                  "host": [
                    "jordanharvey.space",
                    "*.jordanharvey.space"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.113.220:443"
                          "transport": {
                            "tls": {
              "match": [
                  "host": [
                    "apps-ipam.system32.uk",
                    "e-learn.system32.uk"
              "terminal": true
          "automatic_https": {
            "disable": false,
            "disable_redirects": false,
            "disable_certificates": false
          "experimental_http3": true,
          "allow_h2c": false
    "tls": {
      "automation": {
        "policies": [{
          "renewal_window_ratio": 20,
          "issuers": [{
            "module": "acme",
            "email": "REDACTED",
            "acme_timeout": "1h",
            "challenges": {
              "http": {
                "disabled": false
              "tls-alpn": {
                "disabled": false
              "dns": {
                "provider": {
                  "name": "cloudflare",
                  "api_token": "REDACTED"
                "resolvers": ["8.8.8.8", "8.8.4.4"]
Output from curl -v:
root@resvmcaddy01:/home/netjo# curl -v http://apps-portainer.system32.uk
*   Trying 192.168.113.42:80...
* Connected to apps-portainer.system32.uk (192.168.113.42) port 80 (#0)
> GET / HTTP/1.1
> Host: apps-portainer.system32.uk
> User-Agent: curl/7.81.0
< HTTP/1.1 200 OK
< Accept-Ranges: bytes
< Alt-Svc: h3=":443"; ma=2592000,h3-29=":443"; ma=2592000
< Cache-Control: max-age=31536000
< Content-Type: text/html; charset=utf-8
< Date: Fri, 06 May 2022 15:04:43 GMT
< Last-Modified: Sun, 03 Apr 2022 21:01:32 GMT
< Server: Caddy
< Vary: Accept-Encoding
< X-Content-Type-Options: nosniff
< X-Xss-Protection: 1; mode=block
< Transfer-Encoding: chunked
<!doctype html><html lang="en" ng-app="portainer" ng-strict-di><head><meta charset="utf-8"/><title>Portainer</title><meta name="description" content=""/><meta name="author" content="Portainer.io"/><base id="base"/><script>var path = window.location.pathname.replace(/^\/+|\/+$/g, '');
      var basePath = path ? '/' + path + '/' : '/';
      document.getElementById('base').href = basePath;</script><!--[if lt IE 9]>
      <script src="//html5shim.googlecode.com/svn/trunk/html5.js"></script>
    <![endif]--><link rel="apple-touch-icon" sizes="180x180" href="63a301f0574f1a696ce6.png"/><link rel="icon" type="image/png" sizes="32x32" href="2dcfc527d067d4ae3424.png"/><link rel="icon" type="image/png" sizes="16x16" href="112a479c093f4729251d.png"/><link rel="mask-icon" href="7ee8aae1b407ce0e809b.svg" color="#5bbad5"/><link rel="shortcut icon" href="data:image/vnd.microsoft.icon;base64,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"/><meta name="msapplication-config" content="6d50eaeb9f128c130ed9.xml"/><meta name="theme-color" content="#ffffff"/><script defer="defer" src="runtime.0175fd64064c5694cbe7.js"></script><script defer="defer" src="vendor.d832a8d7973ffeb155ad.js"></script><script defer="defer" src="main.c9df9695b55bbd734e82.js"></script><link href="vendor.d42617657dafd12b6ec2.css" rel="stylesheet"><link href="main.a47ce99f78f7b95e94af.css" rel="stylesheet"></head><body ng-controller="MainController"><div id="page-wrapper" ng-class="{
        open:
          toggle && ['portainer.auth', 'portainer.internal-auth', 'portainer.init.admin', 'portainer.init.endpoint', 'portainer.init.license'].indexOf($state.current.name) === -1,
        nopadding:
          ['portainer.auth', 'portainer.internal-auth', 'portainer.init.admin', 'portainer.init.endpoint', 'portainer.init.license', 'portainer.logout'].indexOf(
            $state.current.name
          ) > -1 || applicationState.loading
      }" ng-cloak><div id="sideview" ui-view="sidebar" ng-if="!applicationState.loading"></div><div id="content-wrapper"><div class="page-content* Connection #0 to host apps-portainer.system32.uk left intact
"><div class="page-wrapper" ng-if="applicationState.loading"><div class="container simple-box"><div class="col-md-6 col-md-offset-3 col-sm-6 col-sm-offset-3"><div class="row"><img ng-if="logo" ng-src="{{ logo }}" class="simple-box-logo"/> <img ng-if="!logo" src="29d4ee6d4a5c786588a7.svg" class="simple-box-logo" alt="Portainer"/></div><div class="row" style="text-align: center">Loading Portainer... <i class="fa fa-cog fa-spin" style="margin-left: 5px"></i></div></div></div></div><div id="view" ui-view="content" ng-if="!applicationState.loading"></div></div></div></div></body></html>
Caddy doesn’t appear to be redirecting from HTTP to HTTPS.. Pretty much all domains should be https. However I can still load websites over http. Not sure if thats because of the plugins installed? I can still navigate to the secured version of the website manually.
The below line is repeated every 10 minutes, for each domain in the config file above. Although SSL seems to be working?
May 06 15:05:50 resvmcaddy01 caddy[49551]: May 06 15:05:50 resvmcaddy01 caddy[49551]: {"level":"info","ts":1651849550.8699167,"logger":"tls.cache.maintenance","msg":"certificate expires  soon; queuing for renewal","identifiers":["apps-homeassistant.system32.uk"],"remaining":7531270.130083634}
Added automatic_https section under the server with no luck
Removed config routes down to 1 simple site (not protected with SSL internally)
Lots of research points to people using Caddyfile’s, which I’ve tried and no luck again.
Please post a minimally reproducible example. You redacted part of your config, so it’s hard to say with any kind of certainty that the problem wasn’t because of something in the part you redacted.
Please also show the behaviour with curl -v
Welcome to the forum. What is the full config? What requests exhibit the behavior? Please follow the help template and post output of curl -v commands that demonstrate the behavior, along with full config.
Thanks, I updated the post with what I can get…
Oh right – it’s cause you have :80 here. Remove it:
Basically, you’re overriding all automatic redirects because you’re telling Caddy to use your own routes instead for incoming connections on port 80.
If you leave out :80 here, Caddy still spins up a server on port 80, as part of Automatic HTTPS, so that ACME HTTP challenges can be solved, and for HTTP->HTTPS redirects. And that :80 server will only have routes to handle those things, and it won’t serve your actual content.
Ahhh nice, I’ll give it a go :slight_smile:
Quite used to nginx, apache, IIS etc. brought myself to Caddy because of its API and insane flexibility to easily build and add modules to it so I must have read the docs incorrectly…
When you write JSON config, you have full power at your disposal, but it’s easier to make mistakes, compared to the Caddyfile.
I recommend starting with a Caddyfile, then adapting it to JSON with caddy adapt --pretty. It’ll often give you a good, safe starting point.
