[SOLVED] Caddy changes my ip in reverse proxy
hey hi
I have ifconfig.co docker container
Docker Hub
with this command:
docker run -p 10080:8080 -d -v /tmp/geo/:/tmp/geo/ mpolden/echoip -c /tmp/geo/GeoLite2-City.mmdb -f /tmp/geo/GeoLite2-Country.mmdb -a /tmp/geo/GeoLite2-ASN.mmdb
it works when i connect this directly
curl -s  srv5.69b.ir:10080/json|jq
  "ip": "80.75.9.153",
  "ip_decimal": 1347094937,
  "country": "Iran",
  "country_iso": "IR",
  "country_eu": false,
  "latitude": 35.698,
  "longitude": 51.4115,
  "time_zone": "Asia/Tehran",
  "asn": "AS25184",
  "asn_org": "Afranet",
  "user_agent": {
    "product": "curl",
    "version": "7.80.0",
    "raw_value": "curl/7.80.0"
but when i use caddy with reverse_proxy it shows my docker ip
my caddy config is:
root@mobin-13991227:/etc/caddy# cat Caddyfile
        root * /usr/share/caddy
reverse_proxy ip.69b.ir  {
        to 127.0.0.1:10080
  header_up Host {host} # redundant
        header_up X-Real-IP {remote}
        header_up X-Forwarded-For {remote}  # redundant
        header_up X-Forwarded-Port {server_port} # redundant
Your Caddyfile doesn’t make much sense – there’s no use to use both file_server and reverse_proxy at the same time, without request matchers. And you don’t need any of the header_up lines, they’re actually harmful in many cases. You can simplify it to this:
	reverse_proxy 127.0.0.1:100080
That said, the reason you’re seeing Docker’s IP is because Docker often puts a userland proxy in front of containers, which transforms the TCP packets before they reach Caddy, making it look like the requests came from Docker itself. You can turn this off in Docker’s settings.
Next time, please fill out the help topic template. There’s bits missing from your post which make it confusing, e.g. how are you running the Caddy container, which version of Caddy are you running, etc.
According to GitHub - mpolden/echoip: IP address lookup service you have to apply an option to specify which header should be used to get the ip address (else the command doesn’t use any of the headers):
  -H value
    	Header to trust for remote IP, if present (e.g. X-Real-IP)
So the command to start the ifconfig.co container should be:
docker run -p 10080:8080 -d -v /tmp/geo/:/tmp/geo/ mpolden/echoip -c /tmp/geo/GeoLite2-City.mmdb -f /tmp/geo/GeoLite2-Country.mmdb -a /tmp/geo/GeoLite2-ASN.mmdb -H X-Forwarded-For
thanks sorry i`m not so much familiar with web servers,
how I can have separated reverse_proxy base on domains?
without caddy it works
saeb@work ~/V/T/sudoer.ir> curl -s http://srv5.69b.ir:10080/json|jq
  "country": "Iran",
  "latitude": 35.698,
  "asn": "AS25184",
  "user_agent": {
    "product": "curl",
i`ll :sweat_smile:
I changed docker run command to
docker run -p 10080:8080 -d -v /tmp/geo/:/tmp/geo/ dockerhub.ir/mpolden/echoip -c /tmp/geo/GeoLite2-City.mmdb -f /tmp/geo/GeoLite2-Country.mmdb -a /tmp/geo/GeoLite2-ASN.mmdb -H X-Forwarded-For
still https://ip.69b.ir does not work right
Did you update your Caddyfile as I wrote above?
yes and now it is working. thanks
cat /etc/caddy/Caddyfile
        to 127.0.0.1:10080
FYI this probably won’t do what you expect. This will configure two upstreams, one being ip.69b.ir and the other 127.0.0.1:10080. Caddy will randomly pick one for each request.
In this case, I don’t think you mean to use two. So change it to just reverse_proxy 127.0.0.1:10080.
how I can set different reverse proxies for different domains?
By using site addresses for each site block.
See how the Caddyfile is structured.
saeb@mobin-13991227 ~> cat /etc/caddy/Caddyfile
# domain name.
ip.saeb.sbs:80 {
reverse_proxy localhost:10080
it worked thanks
