Snippet Issue, works outside snippet
v2.4.0-beta.2
Docker
N/A - Docker
See above, use docker.
	default_sni dulanic.com
	acme_ca https://acme-v02.api.letsencrypt.org/directory
	email {$ACMEEMAIL}
	# debug
(proxyheaders) {
	flush_interval -1
	header_up X-Real-IP {http.request.header.CF-Connecting-IP}
	header_up X-Forwarded-For {http.request.header.CF-Connecting-IP}
	header_up X-Forwarded-Host {hostport}
(main) {
		on_demand
		Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
		Content-Security-Policy "upgrade-insecure-requests"
		X-Frame-Options "SAMEORIGIN"
		output file /logs/caddy.json {
			roll_size 100MiB
			roll_keep 20
			roll_keep_for 365d
		level INFO
		format filter {
			wrap json
			fields {
				size delete
				duration delete
				request>headers>Sec-Fetch-Site delete
				request>headers>Sec-Fetch-Mode delete
				request>headers>Connection delete
				request>headers>Authorization delete
				request>headers>Cf-Ray delete
				request>headers>Accept delete
				request>headers>Accept-Encoding delete
				request>headers>Cookie delete
				request>headers>Cf-Request-Id delete
				request>headers>Sec-Fetch-User delete
				request>headers>Content-Length delete
				request>headers>Sec-Fetch-Dest delete
				request>headers>Cdn-Loop delete
				request>headers>Cf-Visitor delete
				request>headers>Accept-Language delete
				request>headers>X-Forwarded-Proto delete
				request>headers>Sec-Ch-Ua delete
				request>headers>Dnt delete
				request>tls delete
				resp_headers delete
(jwt_protected) {
	route {
		jwt {
			trusted_tokens {
				static_secret {
					token_secret {env.token_shared_secret}
			allow roles verified
			auth_url https://auth.dulanic.com/auth/
https://subdomain.dulanic.com {
	import main
	import jwt_protected
	reverse_proxy test:4000 {
		import proxyheaders
This code works placed directly before the reverse_proxy, but not as import jwt_protected. I’d prefer it to be a import as I want to reuuse the snippet in multiple subdomains.
	route {
		jwt {
			trusted_tokens {
				static_secret {
{"level":"error","ts":1619101882.4429889,"logger":"http.handlers.authentication","msg":"auth provider returned error","provider":"jwt","error":"jwt-87: token keys and secrets must be defined either via environment variables or via token_ configuration element"}
It works if I put the snippet directly under the path, but not as a snippet. I worked /w @greenpau here. https://github.com/greenpau/caddy-auth-portal/issues/122#issuecomment-824913704
I’m confused. Could you compare the adapted JSON to see where it differs?
Run caddy adapt --pretty on your Caddyfile and compare.
Looks like it isn’t pulling in the token when it’s in the snippet.
This is the diff between the 2, just moved to the snippet.
Interesting, I can replicate the issue.
I think this was a side effect of this feature:
I think {env.*} is being replaced here when it shouldn’t be, so if you don’t have the environment variable set when you’re adapting/running Caddy, import replaces it with an empty string. I’ll take a look at fixing it.
Easy enough:
That was a fast fix :grinning:
So I’m not sure that fixed it. It is passing the env var name instyead of the value of the env value. This is from the autosave.json, all other env variables show the value except this one.
As I wrote on the PR, that’s working as intended:
