Binary installed from Github release.
$ caddy version
$ caddy run -watch
ChromeOS, inside the penguin
“Linux” container (although Caddy isn’t being “containerised” here!)
$ caddy run -watch
2021/08/15 18:03:18.747 INFO using adjacent Caddyfile
2021/08/15 18:03:18.751 WARN admin admin endpoint disabled
2021/08/15 18:03:18.751 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00035c700"}
2021/08/15 18:03:18.762 INFO tls cleaning storage unit {"description": "FileStorage:/home/user/.local/share/caddy"}
2021/08/15 18:03:18.765 INFO tls finished cleaning storage units
2021/08/15 18:03:18.762 DEBUG http starting server loop {"address": "[::]:8443", "http3": false, "tls": true}
2021/08/15 18:03:18.767 INFO http enabling automatic TLS certificate management {"domains": ["*"]}
2021/08/15 18:03:18.777 WARN tls stapling OCSP {"error": "no OCSP stapling for [*]: no OCSP server specified in certificate"}
2021/08/15 18:03:18.779 WARN pki.ca.local root certificate trust store installation disabled; unconfigured clients may show warnings {"path": "storage:pki/authorities/local/root.crt"}
2021/08/15 18:03:18.781 INFO autosaved config (load with --resume flag) {"file": "/home/user/.config/caddy/autosave.json"}
2021/08/15 18:03:18.782 INFO serving initial configuration
2021/08/15 18:03:18.783 INFO watcher watching config file for changes {"config_file": "Caddyfile
auto_https disable_redirects
admin off
local_certs
skip_install_trust
#default_sni wibble
https://*:8443 {
tls internal
file_server browse
I’m trying to figure out an unopinionated, works-in-all-situations, TLS-enabling Caddyfile to give to the devs I work with, for embedding into some non-internet-connected containers (i.e. ACME isn’t an option).
Basically, when an app they’re working with doesn’t have TLS out of the box, I’d like to reverse-proxy its localhost:8080
(or whatever port its listening on) and add TLS to their container mix with zero changes needed apart from the backend port that’s being proxied.
But! I’m very very aware that the Caddyfile I’ve posted above doesn’t bring any identity assurance to the party! I know that what I’ve posted is snake-oil, and that’s just fine! This config will be used behind TLS-terminating load balancers, and is for “securing” the load-balancer-to-backend connection, alone. I am 100% aware of the security downgrade I’m injecting, here!
What I’m trying to convince Caddy to do is this:
- Listen on port 8443 (and only that port; no http redirects, please!)
- Serve a snake-oil/internal/etc TLS certificate that Caddy itself has created (either on demand, or on startup, either’s fine)
- Inject X-F-For, X-F-Proto, & X-F-Host headers as appropriate, matching whatever was received
- Reverse-proxy to a localhost port
I can’t seem to figure out how to tell Caddy to care a little less about the site address. When testing with https://nip.io/ dynamic DNS hostnames, and the above config, I get:
DEBUG http.stdlib http: TLS handshake error from 100.115.92.199:38542: no certificate available for '100-115-92-199.nip.io'
I can fix this for my machine, here, by adding that specific site into my config, but that’s not going to help my colleagues out there in Azure land …
How do I wildcard TLS on a particular listener port, when I really don’t care about the identity provision of the TLS connection?
As above, I see lots of this:
I’ve tried putting host-/SNI-specific names in the site address, and that works with the above config. My problem is how to decouple the Caddyfile from the requests that’ll hit the containers, so that (apart from the container’s reverse-proxy port) the same config can be bolted onto arbitrary containers.
I’ve tried commenting the various tls
/ local_certs
/ default_sni
options in and out, with all the binary combinations I can think of. No dice, thus far!
Thanks for any pointers or help, folks - much appreciated
