I would like to express my sincere gratitude to the community for the invaluable support provided throughout my journey.
Currently, I am facing an issue with slow transfer speeds on my Caddy and Nextcloud setup. To provide some context, I am running two Ubuntu cloud-init VMs on Proxmox, each residing in separate VLANs and equipped with Docker. One VM hosts a Caddy container, with the QUIC protocol configured, while the other hosts a Nextcloud container. I have them in separate VMs incase i have to restore my Nextcloud all of my site redirects/services will still work while im fixing my Nextclod
Interestingly, individual speed tests conducted on both VMs demonstrate the full utilization of the 1 Gig bandwidth. Moreover, remote clients, equipped with a 1 Gig internet connection, report similar speed test results to mine.
However, during actual transfers to clients, the speed does not exceed 120 Mbps.
It’s worth noting that I utilize Cloudflare for DNS management, operating in DNS mode only without proxying for my domains.
Regarding firewall configurations, there are no speed or bandwidth restrictions imposed on the Nextcloud and Caddy VMs. Specifically, the firewall settings allow the Nextcloud VM to communicate with the Caddy VM over ports 443 and 80, and the Caddy VM can communicate with Nextcloud on all ports.
I would appreciate insights on whether any unnecessary configurations exist in my Caddyfile or Nextcloud setup, and if there are recommendations for optimizing the container setup or composing a more efficient configuration.
2. Caddy version: v2.7.6
3. How I installed and ran Caddy: Docker
VM in serprate vlan on Pro
b. My complete Caddy config:
test.example.com, test2.example.com, test1.example.com {
reverse_proxy 192.168.1.16:8443
root * /var/www/html
encode zstd gzip
redir /.well-known/carddav /remote.php/dav/ 301
redir /.well-known/caldav /remote.php/dav/ 301
redir /.well-known/webfinger /index.php/.well-known/webfinger 301
redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
# disable FLoC tracking
Permissions-Policy interest-cohort=()
# enable HSTS
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
handle @forbidden {
respond 404
c. Caddy Docker compose file:
version: "3.8"
image: caddy:latest
- 443:443
- 443:443/udp
- /home/ubuntu/docker/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/ubuntu/docker/caddy/site:/srv
- /home/ubuntu/docker/caddy/caddy_data:/data
- /home/ubuntu/docker/caddy/caddy_config:/config
labels:
- com.centurylinklabs.watchtower.monitor-only=true
network_mode: host
d. My Nextcloud Docker Compose:
version: '3'
db:
image: mariadb:11.3.2
container_name: nc_db
command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW --innodb-file-per-table=1 --innodb-read-only-compressed=OFF
- /home/nc/docker/nextcloud/nextca/db:/var/lib/mysql
- MYSQL_ROOT_PASSWORD=password
- MYSQL_PASSWORD=password
- MYSQL_DATABASE=db
- MYSQL_USER=nc
labels:
- dmz_net
redis:
image: redis:7.2.4
container_name: nc_redis
command: redis-server --requirepass password
# ports:
# - 6378:6378
labels:
- dmz_net
app:
image: nextcloud:28.0.4
container_name: nc
links:
- db
- redis
- /home/nc/docker/nextcloud/nextca/data:/var/www/html
- /home/nc/cloud:/ext_next
- /home/nc/docker/nextcloud/nextca/nextcloud-apache.conf:/etc/apache2/conf-enabled/nextcloud-apache.conf:ro
- MYSQL_DATABASE=db
- MYSQL_USER=nc
- MYSQL_HOST=nc_db
- REDIS_HOST=nc_redis
- REDIS_HOST_PASSWORD=password
- NEXTCLOUD_INIT_HTACCESS=true
- TZ=America/NewYork
labels:
extra_hosts:
- test.example.com:192.168.60.60 #host and ip
depends_on:
- db
- redis
- dmz_net
dmz_net:
external: true
