Slow load (5 seconds) only with png-images
Hi.
1. Problem
I am running a caddy-reverse-proxy in a podman-container serving contents of a podman-apache-container. Loading a png-image (less than 100kB; either inside html and as raw file) results in loading and displaying 12% of the image as fast as expected. Then it hangs for about 5 to 6 seconds, then the rest of the file will be loaded as fast as expected.
The issue occurs with all browsers, I tested with chromium, firefox, curl and wget.
The issue occurs only with png, not with jpg, gif or html-content.
Once the image lies in cache, loading time is as expected.
I think it’s because of caddy as loading the png-image is
→ fast with development-apache-container (podman) directly connected
→ fast with production-apache-container (podman) directly connected to the port on server
→ slow as described with production-apache-container (podman) behind caddy-reverse-proxy running in a container (podman) on server
Somewhere I read about KeepAlive. I switched it off in apache and caddy: no success.
As there is no systemd in container, I cannot use journalctl for logging.
Here is the output of “podman pod logs”. You can see the delay of 6s between loading the image and the final loading of favicon.ico:
podman pod logs
> eae0b030cf95 10.0.2.100 - - [16/Nov/2023:00:19:09 +0000] "GET /storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png HTTP/1.1" 200 86772 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/117.0"
> eae0b030cf95 10.0.2.100 - - [16/Nov/2023:00:19:15 +0000] "GET /favicon.ico HTTP/1.1" 200 1250 "https://wikicardia.de/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/117.0"
curl log
curl -vL wikicardia.de/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png > out.png
* processing: wikicardia.de/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1
* Connected to wikicardia.de (90.187.109.81) port 80
> Host: wikicardia.de
> User-Agent: curl/8.2.1
< Connection: close
< Location: https://wikicardia.de/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png
< Server: Caddy
< Date: Thu, 16 Nov 2023 00:25:53 GMT
< Content-Length: 0
* Closing connection
* Issue another request to this URL: 'https://wikicardia.de/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png'
*   Trying 90.187.109.81:443...
* Connected to wikicardia.de (90.187.109.81) port 443
* ALPN: offers h2,http/1.1
* ALPN: server accepted h2
*  subject: CN=wikicardia.de
*  start date: Oct 30 00:00:00 2023 GMT
*  expire date: Jan 28 23:59:59 2024 GMT
*  subjectAltName: host "wikicardia.de" matched cert's "wikicardia.de"
*  issuer: C=AT; O=ZeroSSL; CN=ZeroSSL ECC Domain Secure Site CA
* using HTTP/2
* h2 [:method: GET]
* h2 [:scheme: https]
* h2 [:authority: wikicardia.de]
* h2 [:path: /storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png]
* h2 [user-agent: curl/8.2.1]
* h2 [accept: */*]
* Using Stream ID: 1
> GET /storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png HTTP/2
> Host: wikicardia.de
{ [5 bytes data]
< HTTP/2 200
< accept-ranges: bytes
< content-type: image/png
< date: Thu, 16 Nov 2023 00:25:53 GMT
< etag: "1520b-607bb34a24eb2"
< last-modified: Sun, 15 Oct 2023 06:14:43 GMT
< server: Caddy
< server: Apache/2.4.54 (Debian)
< content-length: 86539
{ [11203 bytes data]
100 86539  100 86539    0     0  16749      0  0:00:05  0:00:05 --:--:-- 13675
* Connection #1 to host wikicardia.de left intact
caddy debug log:
{"level":"debug","ts":1700321689.566036,"logger":"events","msg":"event","name":"tls_get_certificate","id":"8b2045c7-be4d-48d9-a338-fab458002e0d","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,4868,49196,49200,52393,52392,49325,49195,49199,49324,49187,49191,49162,49172,49161,49171,157,49309,156,49308,61,60,53,47,159,52394,49311,158,49310,107,103,57,51,255],"ServerName":"wikicardia.de","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"Conn":{}}}}
{"level":"debug","ts":1700321689.56612,"logger":"tls.handshake","msg":"choosing certificate","identifier":"wikicardia.de","num_choices":1}
{"level":"debug","ts":1700321689.5661445,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"wikicardia.de","subjects":["wikicardia.de"],"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"81c72b079e2dc74073c45ae2e0599f67332fdc913046b2b3e4eade153d8eb47c"}
{"level":"debug","ts":1700321689.5661566,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.2.100","remote_port":"34040","subjects":["wikicardia.de"],"managed":true,"expiration":1706486400,"hash":"81c72b079e2dc74073c45ae2e0599f67332fdc913046b2b3e4eade153d8eb47c"}
{"level":"debug","ts":1700321689.608357,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"fiducit-0-performance-server:18002","total_upstreams":1}
{"level":"debug","ts":1700321689.6137106,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"fiducit-0-performance-server:18002","duration":0.005303351,"request":{"remote_ip":"10.0.2.100","remote_port":"34040","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"headers":{"Accept-Ranges":["bytes"],"Content-Length":["86539"],"Content-Type":["image/png"],"Date":["Sat, 18 Nov 2023 15:34:49 GMT"],"Server":["Apache/2.4.54 (Debian)"],"Last-Modified":["Sun, 15 Oct 2023 06:14:43 GMT"],"Etag":["\"1520b-607bb34a24eb2\""]},"status":200}
Caddy version:
v2.7.5
docker image via podman:
Client: Podman Engine
Version: 4.3.1
API Version: 4.3.1
Go Version: go1.19.8
Built: Thu Jan 1 01:00:00 1970
OS/Arch: linux/amd64
#podman ps
cd9d004c848e  docker.io/library/caddy:latest  caddy run --confi...  7 minutes ago  Up 7 minutes ago  0.0.0.0:14001->443/tcp, 0.0.0.0:18001->80/tcp  reverse-proxy_caddy
a. System environment
uname -r
6.1.0-13-amd64
neofetch
app_001_infra_reverse-proxy@fiducit-0-performance-server
OS: Debian GNU/Linux 12 (bookworm) x86_64
Kernel: 6.1.0-13-amd64
Uptime: 4 days, 18 hours, 23 mins
Packages: 906 (dpkg)
Shell: bash 5.2.15
Terminal: /dev/pts/0
CPU: AMD Ryzen Threadripper 2990WX (64) @ 3.000GHz
GPU: NVIDIA GeForce GT 1030
Memory: 1760MiB / 31990MiB
/usr/bin/podman container run \
        --cidfile=%t/%n.ctr-id \
        --cgroups=no-conmon \
        --rm \
        --pod-id-file %t/pod-reverse-proxy.pod-id \
        --sdnotify=conmon \
        -d \
        --replace \
        --name reverse-proxy_caddy \
        -v /data/apps/001_infra_reverse-proxy/data/caddy/Caddyfiles/:/etc/caddy/ \
        -v /data/apps/001_infra_reverse-proxy/data/caddy/config/:/config/ \
        -v /data/apps/001_infra_reverse-proxy/data/caddy/data/:/data/ \
        caddy:latest
# container-reverse-proxy_caddy.service
# autogenerated by Podman 4.3.1
# Mon Oct 30 01:22:01 CET 2023
Description=Podman container-reverse-proxy_caddy.service
Documentation=man:podman-generate-systemd(1)
Wants=network-online.target
After=network-online.target
RequiresMountsFor=%t/containers
BindsTo=pod-reverse-proxy.service
After=pod-reverse-proxy.service
Environment=PODMAN_SYSTEMD_UNIT=%n
Restart=on-failure
TimeoutStopSec=70
ExecStartPre=/bin/rm \
        -f %t/%n.ctr-id
ExecStart=/usr/bin/podman container run \
        --rm \
        --sdnotify=conmon \
        -d \
        --replace \
        caddy:latest
        email   kontakt@fiducit.de
        cert_issuer zerossl APIID
import etc_conf.d/*.caddy
import 0-performance_conf.d/*.caddy
import 1-storage_conf.d/*.caddy
cat 0-performance_conf.d/002_egbert.jacobs_wikicardia.caddy
wikicardia.de {
        reverse_proxy fiducit-0-performance-server:18002
www.wikicardia.de {
        redir https://wikicardia.de{uri}
none
Thanks for your debug logs, that’s a good start.
From opening that PNG in a browser, I notice that the image half loads and then pauses, then completes a few seconds later.
This shows that the proxy roundtrip was fast (5 milliseconds) so the problem doesn’t seem to be with your upstream. So this is certainly strange.
Please also add the log directive to your site block, to enable access logs. I’m curious to see what the request duration shows there.
If access logs also show that it’s fast, then the problem is probably at the networking layer for whatever reason.
I’m not an expert at low level TCP networking settings, but there might be something funky going on at that layer. :thinking:
Thanks for your reply and the time you spent.
Below the log lines (systemd of hosting the caddy-container) while request.
There is the 5-seconds-leap between the last two lines.
The second to last line comes from
logger: http.handlers.reverse_proxy
The last line comes from
logger: http.log.access.wikicardia-logger
The duration of the request in this line shows nearly exactly 5 seconds everytime I try:
duration: 5.000923963
duration: 5.001239373
duration: 5.000024392
duration: 5.000670855
duration: 5.000489334
Somewhere there seems to be a configured (?) delay of 5 seconds.
Nov 18 19:13:34 fiducit-0-performance-server reverse-proxy_caddy[848792]: {"level":"debug","ts":1700331214.4199002,"logger":"tls.handshake","msg":"choosing certificate","identifier":"wikicardia.de","num_choices":1}
Nov 18 19:13:34 fiducit-0-performance-server reverse-proxy_caddy[848792]: {"level":"debug","ts":1700331214.419927,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"wikicardia.de","subjects":["wikicardia.de"],"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"81c72b079e2dc74073c45ae2e0599f67332fdc913046b2b3e4eade153d8eb47c"}
Nov 18 19:13:34 fiducit-0-performance-server reverse-proxy_caddy[848792]: {"level":"debug","ts":1700331214.41994,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.2.100","remote_port":"34826","subjects":["wikicardia.de"],"managed":true,"expiration":1706486400,"hash":"81c72b079e2dc74073c45ae2e0599f67332fdc913046b2b3e4eade153d8eb47c"}
Nov 18 19:13:34 fiducit-0-performance-server reverse-proxy_caddy[848792]: {"level":"debug","ts":1700331214.4450545,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"fiducit-0-performance-server:18002","total_upstreams":1}
Nov 18 19:13:34 fiducit-0-performance-server reverse-proxy_caddy[848792]: {"level":"debug","ts":1700331214.449749,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"fiducit-0-performance-server:18002","duration":0.004583204,"request":{"remote_ip":"10.0.2.100","remote_port":"34826","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"],"Accept":["*/*"],"User-Agent":["curl/8.2.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"headers":{"Content-Length":["86539"],"Content-Type":["image/png"],"Date":["Sat, 18 Nov 2023 18:13:34 GMT"],"Server":["Apache/2.4.54 (Debian)"],"Last-Modified":["Sun, 15 Oct 2023 06:14:43 GMT"],"Etag":["\"1520b-607bb34a24eb2\""],"Accept-Ranges":["bytes"]},"status":200}
Nov 18 19:13:39 fiducit-0-performance-server reverse-proxy_caddy[848792]: {"level":"info","ts":1700331219.445193,"logger":"http.log.access.wikicardia-logger","msg":"handled request","request":{"remote_ip":"10.0.2.100","remote_port":"34826","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"bytes_read":0,"user_id":"","duration":5.000199546,"size":86539,"status":200,"resp_headers":{"Accept-Ranges":["bytes"],"Content-Length":["86539"],"Content-Type":["image/png"],"Server":["Caddy","Apache/2.4.54 (Debian)"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Date":["Sat, 18 Nov 2023 18:13:34 GMT"],"Last-Modified":["Sun, 15 Oct 2023 06:14:43 GMT"],"Etag":["\"1520b-607bb34a24eb2\""]}}
One more thing to try. Enable verbose_logs in your proxy (new feature added in v2.7.5 to spit out lots of logs in the proxy).
wikicardia.de {
	reverse_proxy fiducit-0-performance-server:18002 {
		verbose_logs
This might show more info about timing for response body copying/streaming.
Here is the output with
directive verbose_logs and directive log:
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1278777,"logger":"events","msg":"event","name":"tls_get_certificate","id":"5364d413-a8f9-4398-8ec5-011cca84e975","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,4868,49196,49200,52393,52392,49325,49195,49199,49324,49187,49191,49162,49172,49161,49171,157,49309,156,49308,61,60,53,47,159,52394,49311,158,49310,107,103,57,51,255],"ServerName":"wikicardia.de","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"Conn":{}}}}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1279802,"logger":"tls.handshake","msg":"choosing certificate","identifier":"wikicardia.de","num_choices":1}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1280065,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"wikicardia.de","subjects":["wikicardia.de"],"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"81c72b079e2dc74073c45ae2e0599f67332fdc913046b2b3e4eade153d8eb47c"}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1280189,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.2.100","remote_port":"54232","subjects":["wikicardia.de"],"managed":true,"expiration":1706486400,"hash":"81c72b079e2dc74073c45ae2e0599f67332fdc913046b2b3e4eade153d8eb47c"}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1720827,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"fiducit-0-performance-server:18002","total_upstreams":1}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1782415,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"headers":{"Server":["Apache/2.4.54 (Debian)"],"Last-Modified":["Sun, 15 Oct 2023 06:14:43 GMT"],"Etag":["\"1520b-607bb34a24eb2\""],"Accept-Ranges":["bytes"],"Content-Length":["86539"],"Content-Type":["image/png"],"Date":["Sat, 18 Nov 2023 21:52:38 GMT"]},"status":200}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1782818,"logger":"http.handlers.reverse_proxy","msg":"wrote header","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}}}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1782975,"logger":"http.handlers.reverse_proxy","msg":"waiting to read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}}}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1783104,"logger":"http.handlers.reverse_proxy","msg":"read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":3863}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1783214,"logger":"http.handlers.reverse_proxy","msg":"writing to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":3863}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1783307,"logger":"http.handlers.reverse_proxy","msg":"wrote to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":3863,"written":3863,"written_total":3863}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.178338,"logger":"http.handlers.reverse_proxy","msg":"waiting to read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}}}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.178359,"logger":"http.handlers.reverse_proxy","msg":"read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":28672}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1783688,"logger":"http.handlers.reverse_proxy","msg":"writing to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":28672}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1787384,"logger":"http.handlers.reverse_proxy","msg":"wrote to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":28672,"written":28672,"written_total":32535}
Nov 18 22:52:38 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344358.1787746,"logger":"http.handlers.reverse_proxy","msg":"waiting to read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}}}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.278182,"logger":"http.handlers.reverse_proxy","msg":"read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":32712}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.2782152,"logger":"http.handlers.reverse_proxy","msg":"writing to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":32712}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.2784207,"logger":"http.handlers.reverse_proxy","msg":"wrote to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":32712,"written":32712,"written_total":65247}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.2784505,"logger":"http.handlers.reverse_proxy","msg":"waiting to read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}}}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.2785528,"logger":"http.handlers.reverse_proxy","msg":"read from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":21292,"error":"EOF"}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.2785842,"logger":"http.handlers.reverse_proxy","msg":"writing to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":21292}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.2787623,"logger":"http.handlers.reverse_proxy","msg":"wrote to downstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"read":21292,"written":21292,"written_total":86539}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"debug","ts":1700344363.2787778,"logger":"http.handlers.reverse_proxy","msg":"closed response body from upstream","upstream":"fiducit-0-performance-server:18002","duration":0.006043263,"request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"User-Agent":["curl/8.2.1"],"Accept":["*/*"],"X-Forwarded-For":["10.0.2.100"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["wikicardia.de"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}}}
Nov 18 22:52:43 fiducit-0-performance-server reverse-proxy_caddy[871925]: {"level":"info","ts":1700344363.2788196,"logger":"http.log.access.wikicardia-logger","msg":"handled request","request":{"remote_ip":"10.0.2.100","remote_port":"54232","client_ip":"10.0.2.100","proto":"HTTP/2.0","method":"GET","host":"wikicardia.de","uri":"/storage/base/titlelogo/3d6266fed52d0a99b6cebc1a209d1c33.png","headers":{"Accept":["*/*"],"User-Agent":["curl/8.2.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"wikicardia.de"}},"bytes_read":0,"user_id":"","duration":5.106797965,"size":86539,"status":200,"resp_headers":{"Content-Type":["image/png"],"Date":["Sat, 18 Nov 2023 21:52:38 GMT"],"Last-Modified":["Sun, 15 Oct 2023 06:14:43 GMT"],"Etag":["\"1520b-607bb34a24eb2\""],"Server":["Caddy","Apache/2.4.54 (Debian)"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Accept-Ranges":["bytes"],"Content-Length":["86539"]}}
By the way: Now I have converted every png-image to webp. There is no delay anymore. So at least there is a simple workaround.
Nevertheless it would be interesting to get into the cause of the problem.
Egbert
This is where the 5-second latency is:
This is the location in the code:
This points towards it not being an issue with Caddy. However, I have a hunch. Do you know if your upstream sets the Content-Length header in its response off PNG files?
After you validate the fact about Content-Length from your upstream app, can you try adding flush_interval -1 inside the reverse_proxy block? Read about it here:
Thanks for your hints.
apache upstream sets the Content-Length header in its response:
Content-Length: 86539. That’s a correct value.
Adding flush_interval -1 inside the reverse_proxy block has no effect on the latency.
I’m very confused. I’m leaning towards it being a network issue and perhaps specific to Podman, but I’m not familiar much with Podman. To narrow it down to Podman, any chance you can try Docker?
Thank you very much for your hints.
I will try to narrow it down. It will take time. I’ll be back then.
Egbert
